Question about Ruud UBHC Air Conditioner
RUUD Furnace not coming on
Hello experts my ruud achiever 90 plus furnace is not starting. No blinking lights. No blower. I remember that once during the summer a similar problem occurred with my other unit. The problem at that time was a blown fuse. Any suggestions as to what I may check before calling the repairman. Where are the fuses located ? Any help will be appreciated.
Signed: Chilly in Georgia
  • Anonymous Feb 23, 2009
    no power ,no blinkinking leds ,no blower
  • 700 Answers
The fuse that your refering to is on the control board indie of the furnace. shjould be a 3 amp. good luck.
Posted on Jan 30, 2009
I am installing an Emerson programmable thermostat. We have a Ruud furnace achiever 90 plus that was installed 14 years ago. The thermostat mentions a power stealing switch.
The Ruud furnace is probably compatible. Power stealing is a way to recharge the thermostat battery from the 24vac control voltage used to operate the furnace. If you install the Thermostat in the "separate power supply mode" it does not need to power steal ever and will be much more reliable. Some thermostats don't get enough power in the power steal mode to keep the battery reliably recharged, especially during the cold winter months because the poiwer available to "power steal" is highest when the furnace is NOT running. You will need a separate 24 vac transformer and some wire.
Jan 06, 2018 | Ruud Heating & Cooling
Ruud achiever 90 plus furnace-water leaks from the drain pipe
This furnace should condense, as long as it goes into the drain. If it is leaking inside the furnace, there may be a seal that needs replacing in either the pvc drain pipe or concentric drain trap needs resealed.
Feb 21, 2015 | Ruud Heating & Cooling
Ruud achiever 90 plus gas furnace flame goes out after few seconds
This could be water in the hoses that connect to the pressure switch , they should just pull off and blow then out also blow out the pressure switch , this sound like a moisture problem with all the bad weather you h, check air filter is not blocked .
Feb 12, 2013 | Heating & Cooling
Ruud achiever 90 plus furnace will not start with door on.
I would try to check your return air first, making sure there is no blockage and that your air filters are clean. It almost sounds like when you take the cover off, you are pulling enough air into the system for it to run, but as soon as you close it off, it's not getting enough air flow, therefore, tripping a limit switch inside the furnace. Most furnaces will also have the codes for the flashing lights and what they mean on the inside of the door covers.
Feb 02, 2010 | LG LW1200ER Air Conditioner
I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
Aug 10, 2009 | Heating & Cooling
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
Check the data information on the unit there should be a troubleshooting guide that tells you what the two lights blinking once means. hope this helps.good luck. normally found with schematic
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Ruud Achiever 90 Plus wont start
4 blinks is "pressure switch closed" there are 2 in the system according to the wiring diagram one for the vent system  and one for the drain system ... I just wiggled them and heard one "click" the fault light quit blinking and when I pushed the safety switch back in the furnace fired right up.  That being said is there a good website for learning how to maintain your own furnace?  I'll call a pro if I have to, but shoot I can fix a jet engine... this shouldn't be much worse.
Thanks  dan
Jan 19, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
975 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
