Question about Intel Refurbished 301667004 INBOARD 386/PC BOARD Motherboard
Software diskette for old Intel Inboard386 PC/XT Acceleratior
I need the diskette containing ILIM386.sys and other software off the old Intel Inboard386 Accelerator card for the IBM PC/XT. I have the board but no software, so I can access the expanded memory on the board.
So can anyone provide me with the software off that install diskette?
Thanks!
DRSS
  • 81 Answers
SOURCE: sound card problem for intel desktop board D101GGC
SkullyFox give the good solution but let me tell you one thing.....
If you by mistake installed the wrong drivers in the Realtek chipset sound then you have to remove or uninstalled the sound application …..
Intel Original all the boards having the same problem ….
Over the internet one patch is available for Realtek sound drivers first you need to install that patch after this also sound not came then try re-installing the Sound application…
Posted on Dec 10, 2007
jisfy
  • 53 Answers
SOURCE: I have built-in sound card intel desktop board
Dear Friend thanks for support us.. for solving your problem, Here the link you can download the driver. Realtek Alc Sound Driver (click here) for Intel D845PESV Mother board
Posted on Mar 21, 2009
jell587
  • 447 Answers
SOURCE: i need driver for intel d946 mother board ethernet card drivers
You should be able to download that from the product support page at Intel.
Posted on Apr 05, 2009
cirocpatel
  • 524 Answers
SOURCE: Windows 7 (or compatible) drivers for Intel D845GBV
Hello
Click Here to download the drivers for D845GBV
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 04, 2010
SOURCE: Sound Card Drivers Intel PENTIUM-4 865GV mother board
problem for net solution. when we use USB net. tere is a problem of net terminate automatic or net will be disconnet
Posted on Jan 19, 2011
My operating system was accidentally deleted from my Asus netbook. I want to reboot it with a bootable pendrive but it doesnt work. It gives the message, NTLDR is missing,press ctrl+alt+del
Below is Microsofts solution to your error. Reload the OS with a Microsoft CD format it completely not the fast format option reload from sctratch. If you have no CDrom use an external.
Systems hard disk drive has FAT32 file system. Computer hard disk drive has INT-13 extensions with a system-ID type of 0C in the partition table The heads value in the FAT32 BIOS Pattern Block (BPB) is inaccurate.
To resolve the error message "NTLDR is Missing" follow the below steps: Boot the computer with a Windows 95 or Windows 98 Startup diskette or another bootable diskette with sys.com on it.
At the A:\> prompt type: sys c: <press enter> After pressing enter you should receive the prompt "System Transferred". Once the file system has been transferred reboot the computer without the diskette and attempt to reproduce the error.
Aug 23, 2011 | ASUS Eee Pc 1000Ha 160G Netbook
The power light is on, but the monitor is off
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
 - Floppy drive
 - CD drive
 - Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Or:
Cause:
This is an expected operation. In the Boot Device priority setting in BIOS, you will see Removable Dev. (floppy), Hard Drive, ATAPI CD-ROM, and typically last is Intel® UNDI PXE 2.0. This setting will attempt to boot off a remote agent using the onboard NIC. By seeing this message it means the PC cannot find a boot partition on the floppy disk, hard drive or the CD ROM to load the operating system. Solution:
Install an operating system or put in a bootable device into the floppy or CDROM. If you do not plan to boot to a remote boot host, you may disable the Intel® UNDI PXE 2.0 option from the BIOS setup utility boot order. Relevant Information: No operating system installed
C drive does not have an operating system loaded
No bootable floppy diskette in diskette drive This applies to: Intel® Desktop Board CA810E
Intel® Desktop Board D810E2CA3
Intel® Desktop Board D810E2CB
Intel® Desktop Board D815EEA/D815EPEA
Intel® Desktop Board D815EEA2/D815EPEA2
Intel® Desktop Board D815EFV/D815EPFV
Intel® Desktop Board D820LP
Intel® Desktop Board VC820
End of Interactive Support Announcement
These products are no longer being manufactured by Intel. Additionally, Intel no longer provides interactive support for these products via telephone or e-mail, nor will Intel provide any future software updates to support new operating systems or improve compatibility with third party devices and software products.
THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.compaq.com and/or developer.qompaq.com
Comment by Beni S-P, posted on Oct 26, 2007
And i forgot :
check power suplay and ram???Let me know if u get help???
Oct 30, 2007 | HP Compaq Business nx7010 Notebook
INTEL(R)GRAPHIC MEDIA ACCELERATIOR DRIVER
you can get Intel's drivers from here     http://downloadcenter.intel.com/
May 09, 2011 | Computers & Internet
It is frozen. i have a hard drive repair software but i don't know howto reboot from diskett
Insert the diskette and hit the reset button. It should load from the disk automatically.
If not, you'll have to press the button to bring up the BIOS, or 'setup' menu, and browse through to find a 'boor order' or 'boot device priority'.
Make sure the device with the diskette is at the top of the list.
I hope your freeze problems are solved by the disk.
Oct 12, 2009 | Acer Aspire X1200-B1601A PC Desktop
Have bought a second hand IBM USB Portable Diskette Drive. It worked just fine at the sellers place. Now that I try and use my own PC I load a 1.44 Mb diskette and it tells me to load disk ??? What to do...
Hi Graham,
Your Portable USB 3.5 diskette drive uses a pretty old technology that would come with software or drivers needed to run it. You would need to check on your device manager on control panel. But I would advise you upgrade yourself to better storage devices like the flash drive or the CD/DVD USB portable drives. They are a bit more expensive, but the technology is newer and have less issues. Let's face it, the 3.5 diskettes are getting pretty outdated. Don't you think so?
Cheers & Kind Regards
Sep 24, 2009 | IBM USB Portable Diskette Drive (05K9276)...
Need to download ialmnt5.sys for Intel 945 chipset on Aspire 3680 laptop
Try the driver install software from Intel: Intel 945 Express Family
Select your OS and see will it do better then the App from Acer.
May 27, 2009 | HP Compaq Evo D310v PC Desktop
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Won't power up
- Floppy drive
- CD drive
- Hard drive
All users
Or:
Cause:
THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.intel.com and/or developer.intel.com
And i forgot :
Nov 20, 2007 | IBM ThinkPad T20 Notebook
Hi pc wont start
- Floppy drive
- CD drive
- Hard drive
All users
Or:
Cause:
And i forgot :
Nov 03, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
