Question about Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 13541
Turn the unit on
Chest frezer has the electonic control pantl. Push it at +10F and it will turn OFF. Nowhere in the manual does it tell you how to turn in back ON. Left upluged, powers back up OFF. You can push buttons to make it OFF. What do you push to make it ON?
  • 42 Answers
Tried holding button for more then 4 secs? What model/make is it?
Posted on Nov 10, 2007
SOURCE:
My frezer is getting hot on the sides-why?
Its normal. The manufacturers got smart and put the condenser in the outside freezer walls. A lot of home refrigerators also have the same hot walls. Hope this helps good luck.
Oct 06, 2014 | Kenmore Freezers
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
Mar 28, 2011 | Whirlpool Freezers
Temperature
If this unit has a control it would be located on the outer left side in the lower right hand corner. There would be a dial, the higher the number the cooler the temperature. Many of these chest freezers did not have an adjustable control.
Apr 13, 2010 | Kenmore 15 cu. ft. Chest Freezer 16542
Light not working in GE chest frezer it is larger than the model below, 22 cf, it is 25 years old.
Check the bulb, check the tabs within the socket, check the door light switch.
Please, unplug fridge when testing these. We'd like to hear from you again.
Mar 27, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
GE 5CF CHEST FREEZER
I got delivery today for the same freezer and had the same question.
I just called GE's customer service number (800-626-2005) and the agent told me that GE uses this button panel (which has the green on/off light switch, the two white switches, and the round control dial) for all or most of its freezers. But the buttons do not do anything on the 5 cubic foot chest freezer. They are not connected to anything and are non-active buttons. On other freezer models above this one, the two switches serve a purpose, but not the 5CF model. This is a simple, inexpensive freezer and it doesn't have bells and whistles--but it does have the same control panel as the multi-feature freezers. Hope that helps.
Sep 05, 2009 | GE 5 cu. ft. / 142 liter Chest Freezer...
After clean, the magic chef chest frezer no linger frezen.
I think in the defrosting process, the evaporator was damaged causing refrigerant leakage. sorry... dont try to repair.. it sucks in moisture
Aug 26, 2009 | Freezers
Meat along the outside seems to be thawing out.
HI, If you want the temp warmer, move the control to the smaller #'s
If there are no #'s, turn the control clockwise and see if it shuts off. if it shuts off, that is the right direction for warmer temps.
I hope this helps you. please let me know.
Vic
May 31, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Frigidaire chest frezer kegerator conversion
The cabinet is the condensor. The lines run all around it. Unless you add an external condensor kit, the only safe place for holes is the door.
Apr 15, 2008 | Frigidaire 13 cu. ft. / 368 liter Chest...
Freezer power problems
The on/off switch, power cord, outlet, based on the little info. I have, sounds like a power problem.
Dec 25, 2007 | Freezers
Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 13541 Logo
71 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
