Question about HP Wireless Optical Mouse
Light on mouse searches and doesn't turn off.
How do I turn off the mouse after disconnect?
  • dina70 Feb 02, 2009
    just got wireless keyboard / mouse combo the keyboard works fine, but the mouse just quit on me yesterday, try to reset it but noting happened help
  • 214 Answers
Hi, No need to turn off the mouse. Just walk away after shutting down the PC. Your mouse will "go to sleep" by itself. It usually takes my husbands mouse a few minutes but it does go to sleep. Hope this helps.
Posted on Jan 30, 2009
  • dirinda89
    dirinda89 Jan 30, 2009
    Thanks- Now speak quietly so you don't wake up that lil mouse :-)
Mouse won't function at all
Buy a new one and see if that cures the problem.
Jun 05, 2017 | Dynex Computers & Internet
The scroller on the top of the mouse does not scroll the page
Go to your control panel of the computer. Click on the tab "Change mouse whell settings" If you do nto find such tab then search for that tab by puttin word "mouse" in the search box.
There you can change scrolling setting. If it doesn't work then remove the wire of your mouse, shut down computer.
Insert the wire and restart computer. This will surely work. If not then contact I'll give you other remedy.
Sep 22, 2012 | HP Wireless Optical Mouse
Onn wrieless mouse is not working
Try replacing the batteries in the mouse. Sometimes the light will still come out of the bottom of the mouse - but the wireless signal is no good.
Also - after you replace the batteries in the mouse, click the sync button on the USB part that plugs into your computer, and then immediatly click the sync button on the bottom of the mouse.
That should do it!
Nov 14, 2011 | Computers & Internet
My logitech wireless mouse Light doesn;t stay on so I forget to turn it off thus battery will run out fast lighthouse_jmk@yahoo.com
The reason that the light does not stay on is that it only comes on to let you know that the battery is good it stays on about ten seconds, then goes into a sleep mode in order to save the battery. This happens after it does not sense motion. Since it has to transmit the motion to the receiver, this also saves battery. The only power is a small parasitic drain to the led under the bottom. The battery should last about 3 months even if you do not turn the mouse off. Of course it is better to turn the mouse off when not in use, but the small cost of a double A battery is not commensurate with the effort to remember to turn the device off.
Mar 24, 2011 | Logitech Cordless Mouse
My dell mouse wm311 quit working. i got a new dell inspiron 15 laptop Saturday and the new mouse worked. the next day it wouldn't work. the batteries test fine. it is turned on but it won't work.
Your mouse has probably lost its pairing. There should be a button that puts the mouse into answer mode so that when the computer looks for it, the mouse will be found and paired. All you should have to do is get the computer up and running, then turn on the mouse and push the button that makes it answer. (Should be a power switch and then another push button switch that allows the mouse to respond to search queries from the computer.) Then after a few seconds try moving the mouse to determine if it was found. If not found, then try going to devices to make sure it is searching. The mouse should show up on the list of devices.
I have the Microsoft 5000 Bluetooth mouse and it auto pairs. But if I turn it off, it will lose pairing. Sometimes I forget that I didn't turn it off and it is not clear which position of that tiny power switch is the ON, but when I push on the answer button, a light turns on to let me know that power is on. If the mouse is found or if it can't pair, the light goes off so the only way to tell that it is paired is to see it move the mouse pointer. So far it works quite well.
Mar 10, 2011 | Dell U0636 Mouse
I have a Mini Wireless Optical Mouse. M/N M-RAD92. I just changed batteries. The mouse is lit up, but the USB port stick's light will not light up and the mouse is no longer worker.
usb stick doesn t light also on mine but works perfectly. press once on stick button and once on mouse "setup" button and they will connect.
Jan 31, 2011 | Labtec Wireless Desktop Keyboard/Mouse...
Lights are on but mouse doesn,t work.Inland wireless mouse and keybord. Keyboard works great.
Check with fresh batteries.. Did you sync the mouse with transciever? Push tiny button on transceiver, (maybe hold for few seconds) light flashes quickly.. then push tiny button under the mouse, light stops flashing. Try few times, maybe otherway round. If still not work consider defective.
Dec 11, 2010 | Inland u-Touch wireless Keyboard/Optical...
It doesn work,no turn on - red light - it just worked days
Place batteries in right way round or replace batteries.
Feb 17, 2010 | GE Wireless Optical Mouse
How do you turn off a PS/2 compatiable mouse (touch pad) Cant do this in control panel or uninstallng driver in device manger.
If it can't be done in Control Panel you most probably will have to disable it in the BIOS.
Nov 02, 2009 | Computers & Internet
Bluetooth mouse VGP-BMS33
Turn the mouse off. While holding down the connect button, turn it on. Keep holding the connect button untill the green light starts to blink. Now try searching for the mouse.
Sep 06, 2008 | Sony VAIO VGP-BMS33/B
HP Wireless Optical Mouse Logo
137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
