Question about Pit SSR 110CC Pro Beginner Bike
Kick jammed hi can any 1 help, my kick on my xport is jamming wen i took apart the kick shaft moves up and down,do i need a new bottom end
Hi one of the inside cogs is probably jammed try rebuilding it and it should work
Posted on Mar 22, 2009
Traction control light is on d car is making loud noice wont move
The traction control will signal when there is a difference in speed of wheel rotation from one side to the other. Sometimes an Emergency brake can come apart inside the drum and jam a wheel.
A worse case condition would be a stripped differential gear on the axle shaft. The wheel sensors may pick up the difference in rotation of the remaining shattered parts.
Only a few things to do to see how bad stuff is. Elevate both rear wheels, put transmission in neutral and try to move rear wheels. If 1 does not move, it is either jammed inside the differential or jammed
out in the brake drum.
Try getting jammed side brake drum off. If still jammed, the differential cover needs to come off.
Feb 17, 2014 | 2008 Mercury Mountaineer
Please help jammed kick start
You broke something internally. You will need to take the engine apart to see what is jamming it up.
Jun 02, 2013 | 2005 Yamaha TT-R 125 E
Praxis pump slide handle jammed
1. Get a ruler
2. Push the ruler down the barrel so the end is near the bottom of the disc
3. Jiggle the ruler from left to right
4. Shoot the gun/Press the disc eject switch
Dec 25, 2011 | Nerf Toys
Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Thumpstar kick
depends on where the metal broke off from. be more specific on where the pice broke off from? if your not sure investigate a little more.
Jan 15, 2009 | 2004 Factory bike Desert YR 250
Older A200 Reessembly
just did mine a200f. try this, if all gears are in line place bearing cap back on planitary this is the cap on top. this should hold bearing in check from moving up and down. if this works for you remember not to over tigthen bottom jam nut, lower end should move freely. post to let me know if this solves your problem. Harry Ooooooooo
Jan 13, 2009 | Hobart A200 Stand Mixer
CARRIAGE JAM
Had the same problem - it read as a paper jam first, then as a carriage jam. After a bit of playing around, I took the back panel off and manually feed a piece of A4 card (something solid) while rebooting it, it seemed to have cleared then and now is working fine.
Hope this helps :)
Nov 17, 2008 | Office Equipment & Supplies
Pit SSR 110CC Pro Beginner  Bike Logo
113 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
