Question about Dometic Rooftop RV Air Conditioner
Fan is slow
The fan speed on my ducted evap cooler is low. it is a good speed when it is on econ boost. it uses to be better without econ boost last year. we had a tec out to fix another problem last year and he set the remote different and when turning it on this year the fan speed is slow even ou high. but is good on eco boost. I dont know if its good to run the unit on eco boost all the time? product # 6050036GYE bONAIREmodel vsm60/65
    New Friend:
I have the same problem. You turn it on and the air speed is very low. Increasing the fan speed on the remote doesn't have any effect except when it's on boost, in which case it blasts out. Either too much or too little. Is it a remote problem?
Posted on Dec 13, 2012
I dont have a solution, but I have a similar problem with a Bonaire evap rooftop cooler which only started after a tech came to look at the unit when it stopped operating properly last summer. He said it uses less water now, but the issue is that it doesnt cool any where near as effectively with the fan speed so low. I am located in Melb Australia, and wonder if you are in the same area. I am going to call service AGAIN & get the minimum fan speed returned to what it was previously. I wonder if my original unit is too small for the house - but nevertheless, it used to work beautifully and now is a very poor example of evap cooling. The service guy said the base fan speed could be altered from the controller, but we dont know how to get into the setup menu.
Posted on Nov 11, 2009
Econ button
Econ button turns off the A/C but leave the climate control on (without A/C). The climate control will try to get to the set temperature but, obviously on hot days it never will without the A/C on. I use it during the winter and cooler temps, it saves gas not running the A/C, thus econ (economy).
Apr 04, 2014 | 2006 Volkswagen Passat
Hey, was wondering what the message center display symbols and what they mean, lost my manual
There are five trip computer displays which may be stepped through by pushing the MODE button. The information will appear in the following order:
D AVG ECON (Average Fuel Economy): This shows the average fuel economy since the last reset.
D INST ECON (Instantaneous Fuel Economy): This shows fuel economy for the most recent second of driving.
D RANGE (Trip Range): This shows the estimated distance that can be traveled with the remaining fuel. The fuel economy used to calculate range is based on the last few hours of driving. When in a low fuel condition, LO is displayed.
D FUEL USED (Trip Fuel Used): This shows the accumulated fuel used since the last reset.
D AVG SPEED (Average Speed): This shows the average speed since the last reset.
You can download a replacement Owner's Manual here: 2002 Chevrolet Impala Owner's Manual (PDF file from www.gmownercenter.com)
Oct 05, 2010 | 2002 Chevrolet Impala
Need intructions on carberator adjustments for mac-3514 35cc/cm3 runs but hard to start after using it for few minutes.
There is a low speed jet and high speed. Low speed sets the idle or stays running without feathering the throttle./// When setting high speed, hold the throttle wide open until engine revs high, then turn back in(at least ¼ turn) to slow the engine which in turn gives the engine more gas and runs cooler. If you have it too lean on the high speed, it will be hot and hard to start. Sometimes using 40 to 1 mix helps with starting, especially on older chainsaw. good luck
Sep 22, 2010 | McCulloch Garden
Display is not came and automaticaly incress the fan speed. othervise i'm check the without RAM no pip sound is came. so how to solve the problem
Pls replace the RAM chip with goods one .if issue not resolve then pls replace SMPS and check it .if still not resolve then problem with Motherboard.its better call vendor for repair .
Nov 21, 2009 | Dell OptiPlex GX280 PC Desktop
Slow sending text message
it is your sim server problem
Oct 23, 2009 | Nokia N73 Cellular Phone
I HOPE I AM USING THIS PROPERLY......MY ? IS IN MY
The indoor blower motor is sometimes a 3 speed motor.The heat usually works on low or medium speed.But the a/c is usually on high speed,this gives greater air flow across the evaporator coil to give you better cooling,also better air flow at ducts.These speeds are usually wired through a relay in the inside unit (air handler).They can be changed.If you go to thermostat and put the fan switch to "on" the blower should operate on "high" speed.With the fan switch set to "auto"the operation will determine the fan speed.Hope this helps. Gregg
Jun 04, 2009 | Heating & Cooling
2004 Audi A6 A/C permanently in econ mode
Sounds like the refrigerant has either become low or run out. May just require a regas if there aren’t any leaks.
Nov 08, 2017 | 2005 Audi A6
Air coming out of an adobeair portable evap cooler isnt cold
paula298,
A new unit will take a while for the pad to become wet and more efficient. Remember, there may be two switches: fan and water pump. The unit must be full of water and the pump ON to work correctly.
If the unit has a water pump only setting, run the pump without the fan for about 20 minutes. That will get the pads nice and wet and you should get a good result. A rule of thumb in the desert is 20 to 25 degrees of cooling compared to the ambient air.
Don't use a cooler in closed area. The cooler will simply act like a room humidifier. Use in an open garage or porch for the best result.
I hope that helps.
Ed Phillips ed@azalmanac.com
May 12, 2009 | AdobeAir Evaporative Cooler Direct Drive
Dometic Rooftop RV Air Conditioner Logo
253 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
