Question about Pioneer VSX-406 Receiver
Poweroff indication with no output
My Pioneer VSX-406 has been in storage for three years. We recently powered up the unit which appeared to be starting up normally, but then the indication on the front panel read "POWEROFF" and there is no output from the unit. We can still scan the radio bands, and there is electrical output from the 110 volt jack on the back of the receiver. There is no sound output, and each time we select a function we get the same "POWEROFF" indication. I've checked to see if there is a battery inside that might be depleted and found none. The fuse on the circuit board checks out okay. I have downloaded the schematic and repair manual, but found no solution in that information. What should I try next?
  • Roger Maynard Jul 31, 2007
    Thanks Duncan. I agree that it may be a protector circuit function, but there is nothing in the user manual regarding this.
    Novelist:
    Champion:
  • 218 Answers
Have you tried the owners manual (not the repair manual)? It will probably have something about this. It may be that this is the generic message that the unit gives you when you have a bad output channel which would put it into a protection mode.
Posted on Jul 30, 2007
No sound from Pioneer VSX-37TX
check the caps and output transistor the power ones and resistors
May 31, 2012 | Pioneer VSX-37TX
No audio output
THE FIX - to audio problems that persist with the VSX-29TX and others using the AWX7272 DSP board is to replace the ROM on the DSP. My unit started failing on and off after 10 years of use! The intermittent DSP board is an Extremely Common and irritating Problem for this model! The replacement IC,(2) resistors + shipping and handling totaled $49.65 and my unit is finally fixed correctly! Don't believe other posts that you can get away with re-soldering; it will continue to fail again and again! Details of fix are:
Replacement for the old Pioneer ROM located at location IC 9374, should be done with the part PD6381A from Pioneer Electronics. You will also need to move (relocate) the 2 resistors (0 Ohm resistors) located at R9372 and R9371 to locations R9374 and R9373.
This component update applies to DSP boards marked as AWX7433, AWX7272.
This fix is validated (from Pioneer) on the VSX-26TX,VSX-27TX,& VSX-29TX it might also work in the VSX-908, VSX-908RDS and others as long as the same DSP board was used.
Let me caution and stress that surface mount soldering skills ARE REQUIRED to do this update! It also doesn't hurt to have excellent vision and/or an eye loop or microscope to check your work. Original ROM's were subject to timing changes internal to the part as a result of HEAT. This model does get HOT! The program was also modified as a further safeguard to re-occurrence.
Jan 30, 2010 | Pioneer VSX-29TX Receiver
VSX-D457 Display's power off and then shutdown
Most likely it needs one of the output ICs. But check for cold solder rings on the ground connections of the input board. Est. for it to be repaired $100-$120
Dec 17, 2009 | Pioneer VSX-D457 Receiver
I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Nov 29, 2009 | Pioneer VSX-D906S Receiver
I have receiver VSX-D509S. Have had it for
Check for a bad ground on the input circuit board. you will need to re-solder them. Remove top cover and rear panel (many screws on rear panel) The input board can easily be accessed and resoldered. you should also check for a bad ground on the speaker jacks. If it is not repaired, sooner or later you will probably need an output IC. good luck.
Oct 16, 2009 | Pioneer VSX-D509S Receiver
PIONEER VSX D810S POWEROFF
Hay que chequear los alambres de los parlantes..yo tuve el mismo problema..desconectè todos los alambres de los altavoces y luego los reconectè...y allì estuvo la soluciòn...
Mar 30, 2008 | Pioneer VSX-D810S Receiver
Pioneer vsx 808 rds poweroff?
Could be lots of things, could be the tray not fully loading, or power supply problem...
Dec 03, 2007 | Pioneer DVR-520H DVD Recorder
Pioneer vsx-456
I have um Acquitance Groundbreaking VSX -456 as you I turn on appears Poweroff and he turns off automatically if he may go feasible ma ajudem,pois did not what to do. thank you Awaiting recurrence for its email: domingosdsm@globo.com
Nov 20, 2007 | Pioneer VSX-456 Receiver
Vsx-d506s problem
It may be a PROTECT MODE. Check is your other equipment properly connected to receiver.
Oct 09, 2007 | Pioneer VSX-D506S Receiver
POWER OFF alert
When you turn on receiver it will power off. Poweroff shows up and than turns off. if the front panal reads over load the output ic pac001a is defective i had repaired this model before
May 29, 2007 | Pioneer VSX-D710S Receiver
465 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
