Question about Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White
Faucet will not pivot
I hope I am not posting this twice... My Delta 470 faucet will no longer pivot right or left. It used to pivot about 45 degrees in either direction. It was installed about 2 years ago by a professional plumber.
Now it seems jammed. I do not think I can remove the cap without damaging the finish of the faucet. It appears to be very tight. And I am a bit concerned about a bunch of loose parts coming out. However, I am pretty handy and can probably get it back together if that is the only solution. Any guidance would be appreciated.
  • rjqman Jan 31, 2009
    This is exactly what I needed to know. I suspected it, but was not certain, and I did not want to do further damage by forcing something that was not going to give way. I assume the cap unscrews in a conventional direction? I will give it a try. Thanks.
  • rjqman Feb 01, 2009
    Your solution solved my problem. It was a lot easier to turn the faucet cap when I used the rag between the vice-grips and the cap, for some reason. Once loose, I was able to raise the faucet about 1/2 inch without even disconnecting the hose, and I could easily clean out the debris that was preventing rotation. Thanks a lot.
  • 2,692 Answers
The cap has to come off. I usually use a channel lock pliers with a thick rag on the chrome cap .After the cap comes off you may have to put some kind of lub in it such as silicone spray lub.  Twist the spout back and forth while raising it up. Yes. I may take quite a bit of strength and many many back and forth motions to come loose. After you have it off you wil see the menerial deposits or damaged o-rings causing the lasck of movement. The o-rings are available at most hardware stores or a plumbing supply store for sure.    If the cap cannot come off w/o damage,would you not be willing to replace it anyway,rather than have it stay stationary?
Posted on Jan 30, 2009
  • Thomas F. Schneider Jan 31, 2009
    Thank you for the rating..
  • Thomas F. Schneider Feb 01, 2009
    Your welcome Thank you for the excellent rating. I am glad that it worked out for you.
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
I have the model 470 signature pull-out Delta faucet in my kitchen sink. It was installed about 5 years ago. I can no longer rotate the faucet without applying an extreme amount of pressure. Is there a fix...
Contact Delta at 800-345-3358 and ask for replacement parts. With the lifetime warranty Delta customer service was awesome and sent out parts I needed to fix this same faucet.
Jan 10, 2011 | Delta Model 470: Signature Kitchen...
Delta swivel faucet won't swivel. I can barely get it to move left to right.
Take handle off it has set screw that holds it on top of faucet after handle is off it has a locking collar they may have it to tight you can get a little wrench from hardware store that turns it. most are plastic so be careful if you try to move it you may try a little at a time to see if it free's up.
Apr 28, 2010 | Delta Model 470: Signature Kitchen...
Need "0" rings for delta 470 faucet
You should be able to find them at lowes or any other hardware store.
Jan 27, 2010 | Delta Faucet Delta 470-BL-DST Signature...
How to fix leak for delta faucet 470 WHRS
To fix the leak in delta faucet is have a repair kit for
Delta 470-WHRS. The repair kit consist of O-rings
replacement. Otherwise, you have to buy a replacement
for your Delta 470-WHRS.
Nov 26, 2009 | Delta 470-WHRS Signature Single Handle...
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
Replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
Apr 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Instructions for the installation of a Delta 470
Here is the owners manual and installation instructions for your particular faucet:
Delta 470
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta Model 470: Signature Kitchen...
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Dec 05, 2008 | Delta Model 470: Signature Kitchen...
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
520 people viewed this question
Top Delta Plumbing Experts
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
