Question about Canon EOS-AE-1 35mm SLR Camera
My daughter is having trouble with using my old AE-1. She is trying to set the apperture manually but sees no change inside the lense. Can you tell me if there is something that she is not doing correctly or is it the lense.
  • 423 Answers
The apeture is toward the back part of the lens. Shine a light down into the front of the lens and turn the apeture ring, you should see it change size.
Rob
Posted on Mar 04, 2009
My A1 only works when the lens is off the "A" position. Manually setting the apperture it works fine, otherwise it displays a bunch of EEEEEEEEEs....
The AE-1 requires, that when the camera's shutter speed dial is set on A or Auto, that the lense must be set on the highest aperature (22, 32, whatever that lense has). In all other settings you can move around however you'd like.
Aug 14, 2011 | Canon EOS-AE-1 35mm SLR Camera
Currently have sigma 28-80mm 1:3.5-5.6 and 100-300mm 1:4.5-6.7 lenses both 55mm that I use with my Pentax MZ-50. I would like to purchase a DSLR camera and rather than waste the lenses I already own would...
before buying ask the sigma salesman or dealer about it, i know only for nikon camera- it's lenses are compatible for all camera, digital or film base slr cameras.
Feb 12, 2011 | Sigma 28-80mm Mini Zoom Macro Lens
Shutter opens, but doesn't close? I advance my film, press the shutter release, and it opens, but stays open. The only way my shutter will close is if I press the battery check button. I read a trouble...
That camera needs tobe services. The IC2 is the technicians code that tells where to start. With the problems you describe it would be best ot let a technician overhaul and recalibrate it if possible. then you will have a camera that operates like new.
Apr 28, 2010 | Canon EOS-AE-1 35mm SLR Camera
Pentax ES2; do bayonet lens fit digital Pentax SLR?
Any Pentax K-mount lens will fit any Pentax DSLR. The DSLR will fire the shutter.  There is a menu setting (RTFM) which allows the use of older lenses, but you will lose some of the automation (again RTFM). Remember to allow that the effective focal length when using a "film" lens on a DSLR body goes up by 50%.
A standard 50mm lens becomes a 75mm equivalent, but stays a large aperture.
Nov 25, 2009 | Pentax ME Super 35mm SLR Camera
Automatic aperture setting on canon FD lenses not working on AE-1
You have a case of AE(auto exposure) Unit faulty or getting bad. It suppose to register as it move within the AE unit according to the exposure calculation but somehow it is broken. Technician usualy replace the AE unit and takes care of the problem. It can also be rebuilt if new parts are not available. This requires complete disassembly and mirror box removal. The average cost of repair probably runs around $100. Yes, "A" mode is correct for most of the shots and it was a state of art electronic system and more computerized than you think. It has 3 IC chips in there for precessing and 1 chip for the exposure. All works together for good. -James
Nov 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Burning
i do not understand -/+ button and reading tell me in the simple language.My question is in white colour bird feathers are always very bight i can not see the detail in it how i cam solve this problem if i increase the shutter and apperture the picture became dark.
Oct 22, 2008 | Nikon D80 Digital Camera with 18-135mm...
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Changing my appiture
You will need to be in AV or manual mode to change your apperture.
AV is apperture priority and manual allows you full control of all settings on your camera.
Hope this helps!
May 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
I think I scratched something inportant....PLEASE HELP ASAP!
Do not worry. The part that is scratched or has some dirt on it is called fresnel lens ( or the focusing screen ) and scratches to this part will NOT effect quality of your pictures ( i.e. you will not see any of the scratches on your results ) . True it is a hassle to have to look through a dirty viewfinder but just ignore it for now and just take pictures.
Sep 18, 2007 | Canon EOS-AE-1 35mm SLR Camera
W1 Making noises....??
The W1 uses metal rings that slide in place with a tiny hole in the middle to give the required apperture it does not have a diaphram that closes and opens to give the apperture... so what you here is the sound of changing the suitable ring ( or disc) with the apperture ... You can look in the camera (lens side) and change appertures, you should be able to see this happen ... don't click with flash though :) The sound is very low though if you here a loud click there's something wrong.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Canon EOS-AE-1 35mm SLR Camera Logo
59 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
