Question about Whirlpool Calypso GVW9959K Top Load Washer
OB code plus water leakage
I too have the OB code displaying on my Calypso but also water leakage - flooding my garage floor.
The Sears guy said I would need the pump replaced. He also said that I would need a new Outer Wash Plate - but, I have looked at 3 other Calypso's and compared it to mine and all are the same - hmmm!
Will your suggestion be to check out the pump for any obstruction as well and will this take care of the leakage too?
Thanks,
Judy from Oregon
  • 640 Answers
Yes its most likely a defective pump...but do some homework,,,calypso was recall a couple of years ago...start a this site servicematter.com
Posted on Jan 30, 2009
What does a code o6 mean on a Whirlpool Calypso top load washing machine.
is this the code your refering to
ob" Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for Off Balance
The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
Press STOP/CANCEL to clear the display
cuz they list no code 06 hope this helps
Jul 18, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer machine
Off Balance. From the service manual (you can google error codes for these machines), if the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for off balance. The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow you to view and redistribute the load. Press STOP/CANCEL to clear the display.
Feb 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
OB Code and water leakage
this is joyce
This is probably the thing to do is to replace the pump, and yes you can replace the pump yourself if you are mecanically inclind, you can probably order the pump online if you need to and they will send to your house. you dont want the water to continue to leak onto your floor.
thanks
joyce
Jan 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Kenmore Calypso top loader
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso GVW9959K washer with OB code
This is a common problem with the Calypso washers. The problem that you are having is related to the pump. There is something in the pump that is causing the error code to occur. Since the pump isn't working right all of the water isn't draining out thus causing it to be out of balance. If you can get down to the pump and check it out chances are you will find something in it. It might just be some fabric or string from clothing caught around the pump motor. Just make sure you clamp off the hoses or you will flood your laundry room. Once you clear out the pump unplug the washer and wait a few minutes before plugging it back in. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad I could help.
Jan 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LD and OB on Calypso
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating
OB:
will shut down and display an “ob” for off balance.
Basically, it sounds like your drain pump is bad or clogged, and the extra water is throwing the spin cycle off balance
-Perry
800-Appliance San Diego
Dec 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso wont drain
Oh the dreaded calypso pump...Seen that one a million times. Pumps get clogged pretty easily. Try to get the water out manually first. Than push the washer back and lean it against the wall so that you can access the bottom. Remove the 3 screws. Bottom panel should come off. The pump is on the right, its black. Get ready with a shop vac or alot of towels, theres gonna be a flood. There are 2 clamps on black hoses that need to be taken off so that you can slide the hoses off the pump. Next remove the 3 bolts that hold the pump in place. Next lower the pump out of the hole it sits in. Youll have to follow the wiring harness up and disconnect it. Now you can try and clen out the pump or replace it. Part # is 285990. Costs about 75.00. Hope that helps. Let me know if yiu need more help. Dave www.washermd.com
Dec 11, 2008 | Kenmore 22422 Top Load Washer
I'm also having trouble with the Elite Calypso as it seems many mnay people are, what can we all do, Sears won't do a thing without charging top dollar
After discovering the high cost professional repair, I accessed this website to determine whether the problem might be a quick fix. Thank you very much for your expert advice! Thanks to you, I saved hundreds of dollars.
Symptoms: Cycle halts with little/no draining, followed by error displays, especially "ob" and "ld". Occasional leakage of several cups of water.
Problem: Several underwires from various females' undergarmets had become lodged in the last drain compartment, just before water exits to the drain hose.
Solution: Once the clog/wires were removed, the machine functioned normally.
Process: First disconnect power and water supplies to the unit. Next, determine if someting is stuck in the drain hose or in the compartment that empties into it by removing the back panel. In my case, I could see wires and clogs of lint through the translucent yellow plastic of the bottom compartment.
To acces the clog, I drained most of the water by lowering the end of the drain hose as much as possible before disconnecting it, then sucked the rest up with a wet/dry vac when I removed the hose. Then I was able to pull the wires out through the drain holes (it was necessary to disconnect the other three hoses from that compartment) using a coat hanger bent and twisted appropriately.
Total time for a "handy" amateur that had never worked on a major appliance before: 1-2 hours. $ saved on a repair housecall: $200-300
Aug 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
172 people viewed this question
Dan Webster
Dan Webster
Sal De
