Question about Metrologic Instruments MS9535 VoyagerBT Barcode Scanner
Cannot pair scanner to cradle
When I try to pair this, by scanning the cradle's code, it beeps three times, fairly quickly, and each beep is accompanied by the right/white led going off.
The blue led flashes a bit...and then some more, and then keeps on, forever until it shuts off.
Any ideas?
Thanks in advance
bluegreenash
  • 661 Answers
SOURCE: Double beeping
Usually Barcode devices come with a code book to program them, This is usually contained in the user manual, and will be several pages of barcodes, using these barcodes you can set the options of your handheld device, including what types of barcodes it can read and other options like output formats and seperator characters, you should also be able to change whether it beeps or not,
Posted on Jul 26, 2007
  • 3 Answers
SOURCE: Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Posted on Aug 23, 2007
  • 18 Answers
SOURCE: Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Posted on Apr 02, 2009
  • 38 Answers
SOURCE: trying to restore MS5145 Ecclipse scanner to factory defaults
Hello brett62. I can help you with this. I have the Metrologic Configuration Guide hosted on my website for my clients (www.shiftintoblue.com/resources/metrologic_config.pdf). Go ahead and download that pdf and you'll find the barcodes to recall the unit's defaults. I hope this helps. Good luck!
Posted on Jan 07, 2010
codabar
  • 4 Answers
SOURCE: When trigger is pulled, no red light blinks. Model has power
there is illumination board problem. replace it and your scanner working properly the illumination board which three lights on its top.
Posted on Dec 27, 2010
Hi, I need to know how to program the DB Power barcode scanner model # BCE0008
Unfortunately, this is all I can find for instructions.
Operation Instructions:
1. Connect the USB receiver to the host (e.g.: PC)
2. Pull the trigger to start the scanner. It works on two beeps.
Notes: 1. The charging port on the scanner is for battery charging only. Do not connect it to data cables.
2. The LED light at the scanner bottom is on and red under charging and off when charging is finished.
3. During working, the scanner will auto shut down in case of not in use for 20 second.
4. The receiver was paired to the reader at factory. Do not pair again unless necessary. When self pairing is needed, please first read the code CHANNEL SETTING. (Before setting, please reset the receiver until the light turns long green. Reset it to the light off when setting is finished.
Package Including: 1 x Wireless Barcode Scanner 1 x Receiver 1 x Charging Cable 1 x Instruction
Sep 08, 2016 | DBPOWER 2.4GHz Wireless Handheld Automatic...
My canner ls4278 is making a sound and turnin red when i scan
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
Jun 10, 2014 | Symbol LS 4278 Barcode Scanner
Why does my LS 4278 scanner beep when cradled?
It sounds like the power is dropping along the 15 foot length of the cable. You could try connecting a power supply to the cradle and should not hear those beeps any more. The part number of the power supply is PWRS-14000-253R. All of this assumes you are using the STB4278 or CR0078-SC cradle to connect. If you have a CR0078-P cradle it needs a different power supply.
Apr 30, 2014 | Symbol LS 4278 Barcode Scanner
Wont scan and just beeps four times at me
The scanner is not connected to the cradle. Scan the pairing barcode on top of the cradle.
Apr 17, 2014 | Symbol LS 4278 Barcode Scanner
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
I have a brand new SAM4S ER-180 cash register. If I plug in the power it immediately goes to error mode & beeps at me. The LED screen is reading E Lo0000 or E Lo0.00. I have tried everything & dont...
A beeb normally means defective (hardware failure) DOA. Go back to your store for a warranty replacement.
Does it start without the scanner?
http://tinyurl.com/69hd8kf
Does computer beep when you turn it on? Information on beep codes bleeps on booting, boot codes led flashing flashes 1 2 3 4 5 once twice three times on and off times on boot. power on self test fail, boot failure.
Quick help guides and LED flashing errors codes search for error codes using your
Service manual.
Maybe more info here
http://www.goodson.com.au/service/FrmService.htm
Feb 13, 2011 | Computers & Internet
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
3 Beeps after trying to scan
If you are receiving three quick beeps (all the same tone) before a scan the battery is low. If the scanner is more than two years old the battery may need to be reconditioned. It is recommended the battery be reconditioned once a year. The latest revision of the LS4278 manual is here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=134112767&stateId=0%200%2014115220
Print page 28 of 414 and scan the Battery Recondition barcode. The scanner will discharge the battery then charge it up again. It goes through this two times so you need to leave it on the charger a while for this process to complete. Hopefully this will resolve your issue. If not, you may need a new battery.
If the beeps are low, medium, high the procedure above still may work, but you might want to call Motorola for assistance. Sometimes hearing the beeps helps to diagnose the problem.
Oct 05, 2009 | Symbol LS 4278 Barcode Scanner
Are you able to please give me the reset instructions for a symbol scanner? model: LS4278
Hi, I would be happy to assist you in resetting your LS4278, but it would be helpful to know how you are connected. The Set Defaults barcode will reset all of the scanner settings, but it will also cause you to lose the "pair" (communications) between the scanner and cradle. If you try scanning a barcode at this point you will receive a single beep followed by four error beeps. This just means the scanner is not talking to the cradle. Scan the barcode on top of the cradle. The scanner should give a high low high low series of beeps followed by a short low short high. The short low short high indicates the scanner is talking to the cradle again and you are ready to scan.
If you are connected through the USB port and scan a barcode and get one beep, but do not see data on your host try unplugging the black power supply cable from the cradle. Try scanning your barcode again and it should show up on the host.
Jul 09, 2009 | Symbol Cobra LS1902 Handheld
Metrologic Instruments MS9535 VoyagerBT Barcode Scanner Logo
178 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
