Question about Panasonic NV-GS17 Mini DV Digital Camcorder
Problem with Panasonic NV-GS3 camcorder
When I place a DV cassette in my camcorder it says "incompatible tape". I have tried using another dv cassette but same error. It wont let me record or play the DV tape. I left it for two hours to rest and tried it again, but same problem. Can you help, has anyone had a similiar problem. Jinn
  • 73 Answers
Use cleaning cassette , before a brand new blank tape ( may have a worn or damaged tape in your library ) ;
Posted on Jul 31, 2007
SOURCE:
No playback on my nv-dx100
Try putting a DV Head cleaning cassette into the unit, should work a treat!
Oct 02, 2012 | Panasonic NV-DX100 Camcorder
Playback flickering
The most common cause of this is dust, debris or contamination on the heads.
Firstly, it's extremely important that you use only DRY LUBRICANT type DV tapes on the Canon branded camcorders.
Different manufacturers design their heads to be used with either Dry or Wet (coating lubricant type) tapes - NEVER BOTH. Canon is DRY type.
Consumers are led to believe that they should be using well known branded DV tapes, such as Sony. This is fine, if your camcorder is a Sony. However, you should NEVER use Sony tapes in your Canon - Sony tapes are of the WET type.
So, the question is, "Are you currently using Dry or Wet type tapes, or a mixture of both?" If you have used either a WET tape, or a mixture of both in your Canon, then this may have contaminated your heads.
If this is so, then don't panic - simply run a special Head Cleaning cassette (for Dry tapes) in your Canon for no more than 5 secs. Note: your heads are very delicate, so only run the cleaning tapes for a few secs at a time.
Also, try to avoid recording over the cassette too many times, as the quality will sometimes degrade each time.
An example of the Dry tapes are the Panasonic ones (Myself and other Pro Videographers often use Panasonic Prof, Studio or Master Quality tapes, as these are some of the better quality Dry tapes on the market).
As your XL2 is a Pro Camcorder, I recommend you stick with Studio quality (or higher) cassettes.
See this link for Dry DV tapes: http://cgi.ebay.com/Panasonic-mini-DV-digital-video-cassette-AY-DVM63SQ-5pk-/170645949017?pt=US_Camcorder_Tapes_Discs&hash=item27bb4a8a59
or
http://cgi.ebay.com/5-Panasonic-Master-HDV-HD-video-tape-HC9-Mini-DV-/220519311691?pt=US_Camcorder_Tapes_Discs&hash=item3357f9a94b
See this link for Head Cleaner cassette: http://cgi.ebay.com/MiniDV-mini-DV-Panasonic-Head-Cleaner-Cleaning-Tape-/220683036059?pt=US_Camcorder_Tapes_Discs&hash=item3361bbe59b
If the problem still exists after head cleaning, then suspect either a faulty cassette (most likely) or damaged heads requiring service.
Let me know how you get on...
Scott
"If this has helped you, please be kind enough to leave a testimonial"
Jul 09, 2011 | Canon XL2 Mini DV Digital Camcorder
Do all video camera called "mini DV" use cassette tape to record? If so what is the memory cards on some models for?
no the cassette tape style mini s are now superceded, all the newer models use CF or SD card storage and many can accept cards up to 16Gb
Please rate my help++++Thanks for using FIXYA
May 08, 2010 | Panasonic NV-GS25 Mini DV Digital...
Panasonic NV-DS65 won't eject a tape
It sounds that what's happened is your idler wheel is slipping or even your main drive belt.
When you loaded the tape it was taken by tape guides around the video drum. When you pressed eject the tape guides returned to their proper places but the tape stayedin a loop around the mechanism because the take up spool had no drive to pull the tape back into the cassette. When you've tried to pull the cassette out of the camera that loop of tape has snagged on part of the mechanism and that's what is stopping the cassette from being removed. I'm afraid the tape would be damaged at that spot so you may as well simply snip it with a pair of long bladed scissors and the cassette will pull straight out.
What is then required is either the drive belt changed or the idler wheel assembly changed. Either way a service center will be required unless yourself or a friend is able to buy the parts (not expensive) and do the work required.
Good luck
Apr 24, 2010 | Panasonic NV-DS65 Mini DV Digital...
I cant eject my Panasonic NV-GS55 Mini DV Digital video cassette
Try ejecting cassette whilst powered from AC Adaptor. Secondly, try operating Eject from powered off mode. If operation LED starts flashing after any of these attempts, the mechanism is probably jammed or has become mis-timed. Unfortunately this requires professional intervention to avoid further damage to your equipment.
I hope this information is of assistance!
Jan 01, 2010 | Panasonic NV-GS55 Mini DV Digital...
No sound or vision playback of dv tape
From my poin of view cyliner (rotary head) have poor conection or this parts will be replace.
Aug 06, 2007 | Panasonic NV-GS11B Mini DV Digital...
Panasonic NV-DS27 - "playback blank"
try to clean the video head using a blank new tape and fast forward it 5 times if needed...dont use a video cassette cleaner it will ruin your video head...
Aug 01, 2007 | Panasonic NV-DS27B Mini DV Digital...
Panasonic Nv-GS3
I have the same problem, i was just using my camcorder and when i changed the tape, it says incompatble tape and now it wont play or record at all. It has happened to me today.My friend told me to leave for a while and try again. Hi C8dee, is your camcorder working, any updates, did you find a solution. [email protected]
Mar 30, 2007 | Panasonic NV-GS3B Mini DV Digital...
Panasonic NV-GS17 Mini DV Digital Camcorder Logo
194 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
