Question about Frigidaire FGB24S5A Gas Single Oven
Digital oven temperate is wrong
My Kenmore electric oven is now reading up to fifty degrees too hot (shows 400 but is only 350 inside). Is this maybe just an oven probe issue or is there a thermostat that connects to the probe that could be the problem. Sears sells the probe for $25 (#316233900) but does not list a thermostat. I don't want to get the wrong part
  • kpagel21 Jan 31, 2009
    Kenmore does do up to a 35 degree adjustment but it is not a constant problem. I'm ordering the probe now. Thanks!
    President:
  • 1,214 Answers
Yes, that is the probe that sends info to the controller.
If it's not bad, then the controller is, but normally it's the probe.
Check that the controller has not been incorrectly calibrated before you change the probe out, although most do not allow a swing of more than 15-20 degrees. Yours may allow more though.
I am guessing you measured the actual temperature, to the set point temperature, with a know good thermometer.
Posted on Jan 30, 2009
  • Mark Egan Jan 31, 2009
    Let me know what you find and I'll be more than happy to help.
    And if you don't mind, kick me up to a FixYa as this one is one that I can't fix over the computer lines, and I've helped you to confirm your suspicions and given you some (hopefully) pro advice. I'll also continue to help you on this until it's fixed.
    Or you can wait until we have it fixed as well.
    Regardless, thanks for letting me be of help to you, and thanks for using Fixya!
Kenmore oven off by 90 degrees. temp sensor replaced. Burners cleaned. Air inlet adjusted.
Are you sure you got the right sensor for your model. Most sensors are thermistors that change resistance with the amount of heat applied inside the oven. Their resistance reading at room temp is different for every brand and model out there. So if you got the wrong one you would have the exact problem you describe. But you could also have a defective main control board since that is what senses the resistance of the sensor. If the sensor IS the right one then I suspect the main control unit where you set the oven temps.
Mar 27, 2015 | Kenmore Ovens
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 | Ovens
Our 20 year old gas Kenmore oven won't ignite. The digital controller indicates the oven is on...displaying 100 degrees, but the oven doesn't ignite... Worth fixing or time for a new one?
its the glow coil getting you to 100 but it isn't getting hot enough to iginite gas so it needs replacement, cost of doing so maybe 50 bucks if you do it yourself
Feb 04, 2010 | Ovens
The oven temperature is way off, 100 degrees under one day and then 75 degrees too hot the next. Its a electric kenmore 790. Can it be fixed cheaply or is it better to replace? Thanks
This should be a cheap repair and is most likely a problem with the thermistor or wiring to the tehrmistor. Call a service man or two for some quotes.
Dec 28, 2009 | Kenmore Ovens
My oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Dec 15, 2009 | Kenmore Ovens
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
Electric Diagram for Kenmore Model 790
Has the oven run out of control or gotten too hot? The 790 series is made by Frigidaire and those fault codes are F0 to F8. F2 indicates the temperature sensor is reading too hot. Now with the double oven models, some manufactures add an extra digit to the fault codes to indicate which oven created the fault.
Your most likely fix is to replace the temperature sensor. The most probable locations for the wiring diagram is taped inside the bottom drawer, on the back or under side of the oven, or behind one of the panels on the back of the oven. This might tell you the room temperature resistance for the temperature sensor so you can test it with an ohmmeter and be sure that it is faulty. Try Appliance Parts Pros for replacement sensors.
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
Dec 30, 2008 | Maytag CWE4800A Electric Single Oven
Oven not hot enough
the thermometer is most likely the problem, the calibratation is probably off. If you have access to a accurate digital thermometer it is relatively simple to do. If you do have one just take and set the knob to 250 degrees and when the oven gets to 255 it should go off and come back on at 245 degrees. If it's a digital there shopuld be a potentiometer that you have to adjust. good luck
Dec 26, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire FGB24S5A Gas Single Oven Logo
212 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
