Question about Hotpoint 18.2 cu. ft. Top Freezer No-Frost Refrigerator CTX18DABWW
Moved fridge on its side
How long should i let it sit before plugging it in?
  • 410 Answers
Let it sit upright 2-3 hours you should be okay.
Posted on Jan 30, 2009
Kenmore Model No. 253.53322302 side-by-side not cold enough. Incidentally, fridge was unplugged in garage last 2 years until plugged in 2 months ago. Fridge stays at 38 F and Freezer at 27 F, so ice...
Since your fridge/freezer has been in storage the gas has settled, did the fridge/freezer get put on its side at any stage during the move?
This could have caused leakage out the breather pipe, have a look at the condenser at the back of the fridge, down low, you will see two hard pipes coming out of the tank, one leads up into the fridge the other doubles over, is open ended and facing downward, this is the breather and gas can escape from this pipe when the appliance is tilted to far over.
Chances are high that you will need to service this appliance.
its a good idea not to turn on immediately after moving. giving the gas time to settle again before turning on.
It could be the door seals need replacing as they can go hard over time when just sitting and no longer form a good seal on the door.
Feb 07, 2014 | Kenmore Refrigerators
I have moved my bush fridge freezer bsbm166s and now the light is on but its not working
If you have laid it down when you moved it you need to have it in the upright position for 24 hrs. before plugging it in. (so unplug it. let it sit for 24 hrs. then plug it in.)
Sep 20, 2013 | Freezers
Fridge working but not cooling
Sometimes they need to sit for a while after they have been moved, to allow all the refrigerant to settle back where it should be. If you had to put it on it's side / upside down to clean it, then maybe if you give it a few hours sitting upright it might start working again.
Also (I am not familiar with that exact model of fridge) are there any switches or dials that may have been moved during the cleaning process?
Oct 03, 2012 | Engel MD14F Fridge / Freezer 15 Qts
How to restart after laying on the side for moving
Try letting it sit for a bit then plug it back in.
Aug 12, 2012 | Washing Machines
Fridge wont get cold
unplug for 15 min let sit the plug back in u should here it turn on feel the sides of the freezer if getting cold but fridge not the fan for fridge bad also there should be a copper or steel looking wire inside in back for therm
for the temp move it around it mite work if not condecer low or bad
Dec 17, 2011 | Kenmore Refrigerators
I unpluged my fridge for about 1 hr then tilted it on a 60 degree angle on a trolly and moved it about 30 metres from my shed to my house . I let it sit for about another hour and the pluged it in too the...
how old is this fridge?they dont take kindly at being moved ,if its older than 10 years then i would replace it as it will start to give you trouble in the near future,but some older fridges take at least 3/4 days to settle down.adrian,,,,,,,
Dec 05, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whent it was moved to my new house, it was laid down for awhile,not won't get cold?
Hello. When a fridge is laid on side the fluids in it flow away from necessary areas. Always stand the fridge upright for at least 48 hours before plugging it in. My recommendation is to unplug it and let it sit for 48 hours and then plug it in again. regards, Joe
Feb 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Haier hsp03wna not working
The click you heard is the thermal overload. This snaps open when the compressor is too hot.
Unplug the unit for 24 hours and don't move it.
Then plug it in and see if it comes back on temp.
Jun 02, 2009 | Haier HSP03WNA Compact Refrigerator
Just moved my Maytag fridge and it won't restart.
let it sit for about 36hrs without power.Then switch it back on it should start ok.adrian
Mar 28, 2009 | Refrigerators
Frigidaire Fridge PLHS69EESS2
Could be a jammed fan or something could have moved inside to block the opening. Some units have deflectors in the openings...did one of those cover the opening on the fridge side? Did you overpack your freezer and block the air flow from there to the fridge?
Dec 29, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
51 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
