Question about Air Tools & Compressors
Smoking air compresser
I have a 7 hp. 150 psi. max craftsman professional air compresser, after using it for a while it starts smoking and oil soaks the filter after the fresh air filter. It soaks the top of the head also. Is the oil to thin ? It Runs good, what kind of oil should I be using ? The recomended sears oil dose not seam to be doing the trick, I think its to thin. I didnt over fill it, but it seams to be getting by the valves. This is the second one thats doing the same thing. Do I have a good back up under the work bench. It has a 60 gal.tank, and 240 volt motor.
  • Anonymous Jan 30, 2009
    the compresser motor has about 20 hrs. on it, I dont think its blow -by or rings, or valves. the first one ran for about the same amount of time and did the same thing, but it was over 1 yr. old so for 174 bucks I just bought a new compresser unit. the reason I Think its a oil problem, is they use 30 weight oil. Is that to thin? I took the head off of the first one and other than some black stuff on them feeler gauge looking valves everythlng looked fine. It runs fine, dont knock or anything,but oil seams to make its way up to the intake side of the jug, should I try some gear lube? whats the recomended oil for the crankcase?
  • Rick Wymer
    Rick Wymer May 11, 2010
    Can you be more specific on the Model? Do you have a Model #?? "Sounds" Like you Have Internal Compressor Problems here, don't think Oil is the Problem. You are experiencing "Blow-By", Bad Piston Rings, or Valve Guides.
  • 142 Answers
I use valvoline sae30, and mine doesn;t smoke,
are the rings ok, ie does it bulid up to full pressure in normal time?
just one other thing, these have to be kept level, or they will smoke.
Posted on Jan 30, 2009
, about 1 litter per 1000 km.No smoke, no leaks, no loss of power. I fill oil in ( about 200ml) then oil level show correct. after driving a distance then oil level is low again.What can the cause be
have a wet and dry compression test done on the engine
compression pressure should be around 150-165 psi with a variation between adjacent cylinders or not more than 10%
If the compression is down to say 120 psi wet then the problem will be a worn engine
the smoke is there but the cat converter is doing its job and burning it off
Jan 18, 2016 | Cars & Trucks
Both Gauges stay at same pressure when trying to adjust outlet pressure to tools
it seems like you might be adjusting a valve before the regulator. the outlet pressure from the compressor vessel should remain celatively constant. if you are adjusting the pressure whilst using the airtool and when you stop the regulator gauges return to/or close to/ the 150 PSI then this also points to you not adjusting the regulator.
Some compressors have 2 outlets... one regulated and the other not.
Feb 11, 2018 | Craftsman 15 gal Air Compressor 3 hp UMC...
I used compressor 3 wks ago and worked great.Now will not compress air above 25 psi.changed regulator OK,removed air intake filter,it has suchion.removed outlet tube,bloweds air.Oil in site glass.I did...
Mike:
If you have air blowing out of the oil filler cap, I would suspect that the piston rings are shot. The piston rings are supposed to keep the compressed air above the piston, and air seems to be leaking past the piston rings into the crank case.
Sep 17, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My craftsman air compressor #919176820 2 HP 12 gallon 200 max psi will not compress over 125 psi
If your compressor is oil-less type, most likely pressure is leaking past piston ring. To verify, remove cover to expose bottom of cylinder (unplug compressor and let out all air). With flashlight, examine the upper-most part of the cylinder (turn motor by hand till piston is at top of stroke). If top of cylinder is scratched, then pressure is leaking past.
For many years now, stores are in a race to have more HP and PSI to attract customers. Customer is really the loser because components used to make the units can not handle the higher pressure. Normally small 115v compressors are set to cut out at 125psi and larger two stage units will cut out at 160psi. Small compressor set to 200psi makes for short lived compressor. Could be compared to driving your car at 100mph all day every day. Longest life is attained when unit is being used at about 60 to 75 % of capacity.
To allow your compressor to reach cutout pressure and keep working for a while, lower cutout to 120psi (pressure switch may be adjustable). To restore to 200psi, replace cylinder/ ring.
If your compressor is oil type, suspect leaking reed valves.
Nov 27, 2011 | Ingersoll Air Tools & Compressors
1 hp 3gal craftsman compressor will only build up to 20lbs pressure in tank. how much compression should single cyl have on compression stroke?
A piston in any engine should be around 100 psi I would guess. A Chevy 350 used to be around 150 psi. An air compressor that only pumps enough air to reach 20psi is obviously too low on compression. Nailers and the like need 80 or more psi. The intake valves may be shot, the unloader might be stuck or piston rings are worn.
Dec 08, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Started using oil and smoking severely, all at once .
the best compression for a B&S is between 50 psi and 60 psi. if it's below 40 psi there is a problem with the rings or the tappet clearance (not letting the valves close all the way) but if it's smoking i would start with the rings...good luck
Apr 09, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Husqvarna yth1848xpt with a kawaskie 20 hp puffs black smoke
I had the same problem with my YTH1848XPT . Believe it or not it is simply a dirty air filter....you must remove the filter and blow it out with an air compressor...or better yet replace it. you can not clean it well enough without the force of the air compressor. Mine works great now.
Jun 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Air Tools & Compressors Logo
194 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
