Question about Whirlpool Calypso GVW9959K Top Load Washer
OB Code and water leakage
I too have had the same OB code but also have water leaking out soaking the floor. Will this still be a case where we can inspect the pump and fix the problem ourselves?
I too had the Sears guy out and he said the pump needed replacing and also the outer wash plate(?). I don't see a problem with it and have looked at 3 other Calypso's and they all resemble mine. Hmmmm!
Thanks for any help you can provide.
Judy from Oregon
  • 99 Answers
This is joyce
This is probably the thing to do is to replace the pump, and yes you can replace the pump yourself if you are mecanically inclind, you can probably order the pump online if you need to and they will send to your house. you dont want the water to continue to leak onto your floor.
Posted on Feb 06, 2009
Why is my lg dishwasher leaking and not draining completly
Chances are that the water pump seal has deteriorated to the point where the water has leaked into the pump (and the floor) and caused problems with corrosion.
You might have had an E1 error code on the panel as well, if not, check out all the hoses for kinks etc then check the water pump condition for leakage. If it leaks, you will have to replace it as it is a sealed unit.
Jul 17, 2014 | LG LDF6810ST Stainless Steel Built-in...
Water leak 1998 Buick Regal front passenger side soaks floor board
Your heater code is leaking. This is located behind the glovebox. You will see the core is rusted through and will require replacing.
Aug 31, 2011 | 1998 Buick Regal
The floor on the front passenger side is staying soaking wet with water the water is not dripping down on floor
Suspect leaking AC condensate drain line, unless it smells like anti-freeze, in which case its the heater core.
Jun 19, 2011 | 2003 Dodge Caravan
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Water leaking into passenger side floor --seems like something is clogged with my AC lines --temp excellent but water is leaking into passenger side floor board
where your battery sits look inside there maybe some twigs and leaves blooking the drainage holes look all along there i had similar problem on vw passat no arm in looking hope this helps?good luck
Aug 03, 2009 | 1998 Nissan Altima
Water leaking onto floor of front passenger side of vehicle
Water on the floor indicates a heater core leak. You may also find a mist coming from the inside of the car when you run the heat and or AC. If this is the case, have your heater core checked out. Best of luck.
May 29, 2009 | 2000 Jeep Cherokee
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
OB code plus water leakage
yes its most likely a defective pump...but do some homework,,,calypso was recall a couple of years ago...start a this site
Jan 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Wet carpet under front Passenger seat
You have drain blockage in the condesor case itself. There is a small tube that will drain the condensor case, the big black plastic case that contains most of your a/c system inside the car. This case collects moisture and that must drain normally from the case drain to the outside of your car onto the ground.. If this drain is plugged, you will have leakage on to the floor. If the moisture is allowed to remain in the carpet, mildew will set in and then you will have to replace the carpet.
Nov 19, 2008 | 2001 Volvo V70
I'm also having trouble with the Elite Calypso as it seems many mnay people are, what can we all do, Sears won't do a thing without charging top dollar
After discovering the high cost professional repair, I accessed this website to determine whether the problem might be a quick fix. Thank you very much for your expert advice! Thanks to you, I saved hundreds of dollars.
Symptoms: Cycle halts with little/no draining, followed by error displays, especially "ob" and "ld". Occasional leakage of several cups of water.
Problem: Several underwires from various females' undergarmets had become lodged in the last drain compartment, just before water exits to the drain hose.
Solution: Once the clog/wires were removed, the machine functioned normally.
Process: First disconnect power and water supplies to the unit. Next, determine if someting is stuck in the drain hose or in the compartment that empties into it by removing the back panel. In my case, I could see wires and clogs of lint through the translucent yellow plastic of the bottom compartment.
To acces the clog, I drained most of the water by lowering the end of the drain hose as much as possible before disconnecting it, then sucked the rest up with a wet/dry vac when I removed the hose. Then I was able to pull the wires out through the drain holes (it was necessary to disconnect the other three hoses from that compartment) using a coat hanger bent and twisted appropriately.
Total time for a "handy" amateur that had never worked on a major appliance before: 1-2 hours. $ saved on a repair housecall: $200-300
Aug 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
