Question about Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White
I can no longer pivot my Delta 470 faucet right or left
The faucet was installed by a plumber. When first installed, the faucet would pivot about 45 degrees from center, to the right and left. It no long will pivot at all.
The problem seems to be in the portion above the sink level, however I cannot remove the top cap - it seems to take a special tool. I tried with a small wrench, but it will most obviously damage the faucet appearance. It functions correctly in every other way. I am afraid that even if I get the cap off, I will have a bunch of loose parts, and may have difficulty re-assembling, but I am pretty handy.
I have viewed the installation instructions and spec sheets on line, along with the Delta tips, but nothing seems to refer to this type of problem. I would appreciate any guidance.
  • 86 Answers
This is a pull out faucet if i am remembering correctly
Posted on Jan 30, 2009
    Genius:
  • 1,605 Answers
Shut off the water first.
use a allen key open the set screw inside of the Delta logo cap under the handle.
losen the lock cap, pullout the cartridge. or replace the cartridge. install in reverse.
2 Suggested Answers
  • 2692 Answers
SOURCE: faucet will not pivot
The cap has to come off. I usually use a channel lock pliers with a thick rag on the chrome cap .After the cap comes off you may have to put some kind of lub in it such as silicone spray lub.  Twist the spout back and forth while raising it up. Yes. I may take quite a bit of strength and many many back and forth motions to come loose. After you have it off you wil see the menerial deposits or damaged o-rings causing the lasck of movement. The o-rings are available at most hardware stores or a plumbing supply store for sure.    If the cap cannot come off w/o damage,would you not be willing to replace it anyway,rather than have it stay stationary?
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
I have the model 470 signature pull-out Delta faucet in my kitchen sink. It was installed about 5 years ago. I can no longer rotate the faucet without applying an extreme amount of pressure. Is there a fix...
Contact Delta at 800-345-3358 and ask for replacement parts. With the lifetime warranty Delta customer service was awesome and sent out parts I needed to fix this same faucet.
Jan 10, 2011 | Delta Model 470: Signature Kitchen...
Need "0" rings for delta 470 faucet
You should be able to find them at lowes or any other hardware store.
Jan 27, 2010 | Delta Faucet Delta 470-BL-DST Signature...
How to fix leak for delta faucet 470 WHRS
To fix the leak in delta faucet is have a repair kit for
Delta 470-WHRS. The repair kit consist of O-rings
replacement. Otherwise, you have to buy a replacement
for your Delta 470-WHRS.
Nov 26, 2009 | Delta 470-WHRS Signature Single Handle...
Delta Kitchen Single Faucet 470 suddenly would not give water
Debris in the valve is a fairly common cause for stopping water flow in single lever valves. You can first check the aereator and remove any debris that may be there at the faucet itself. Then you can try to remove the ball at the control lever. You have to be careful and make sure that you do not drop any parts. Especially if this is a recent installation, you may find a large piece of something there.
Jun 15, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Faucet will not pivot
Jan 30, 2009 | Delta Model 470: Signature Kitchen...
Instructions for the installation of a Delta 470
Here is the owners manual and installation instructions for your particular faucet:
Delta 470
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta Model 470: Signature Kitchen...
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
174 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
