Question about Jenn-Air JED8430 Electric Cooktop
Buy just white cook glass
I have a cartriage a122w and want to buy just the white glass is there a place
  • 750 Answers
You need to replace the whole cartridge!
Posted on Jan 31, 2009
Want to clean electric cook top glass
Watch the provided video on the cleaning procedure for glass cook tops.
Jan 21, 2012 | Jenn-Air JED8430 Electric Cooktop
Tip
Proper Use and Care of Ceramic Glass Cooktops
Here's some helpful tips that can hopefully ensure many years of quality use of your ceramic glass cook-top.
NOTE: It is important to maintain PROPER care of your ceramic glass cook top as they can be very expensive to replace. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most manufacturer warranties DO NOT cover cosmetics. That is, if your cook-top paint starts to wear off from normal use, or from the selection of cookware you choose to use, manufacturers typically WILL NOT replace it. Warranties also DO NOT cover accidents such as dropping something on the top and chipping or breaking it. Some warranties WILL cover, however, blistering, warping and heat related breakage that were no fault of the consumer (as long as you were using the recommended cookware). It is important to become familiar with, and follow, all the manufacturer's use and care instructions that come with your range.
CERAMIC GLASS CHARACTERISTICS:
It is normal for the ceramic glass to change color when heated. This is especially true for lighter colored surfaces. The color should return to normal when cooled. It is also normal for the enameled or painted areas on the cook top to show signs of wear and fade over time. Proper cleaning and cookware selection can extend the cook top appearance.
It is NORMAL for the radiant heat surface elements to glow red and cycle on and off. There is a thermostat associated with each individual element that regulates the temperature. The frequency at which the elements cycle on and off is determined by the heat setting.
PROPER COOKWARE:
Use ONLY flat bottomed cookware for the best results of heat transfer from the surface elements. Cookware with warped, rounded or ribbed bottoms can cause uneven heat transfer which can result in uneven heating of the cooking surface and cause damage to the cook-top such as cracking and/or permanent surface discoloration.
An easy test you can use to determine the flatness of your cookware, is to turn the cookware upside down and place a ruler across the surface. As you rotate the ruler around the surface perimeter, you should not see any light along the ruler edge where it meets the surface. Cookware with slight indentions or expansion grooves can still be used, however.
Make sure the cookware bottom is always clean and dry before use to prevent any foreign matter from burning to the cook-top surface and leaving stains. ALWAYS place your cookware on the cook-top surface BEFORE turning the surface elements on.
Make sure the selected cookware matches the size surface element in use. The cookware surface should NOT exceed one inch beyond the radiant surface element surface.
COOKWARE CHARACTERISTICS:
The material of the cookware you select will determine how well it transfers heat and how evenly it cooks. The ideal cookware should be of medium to heavy thickness.
NOTE: A non-stick surface will take on the characteristics on the base metal used. (i.e., non-stick over aluminum, will take on the heating characteristics of aluminum).
*ALUMINUM - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*COPPER - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*Both aluminum and copper are great when used as a core metal cover with a non-stick or enamel surface. However, when used as a base metal, alone, they can leave metal transfer marks on the cook-top surface which will have to be cleaned immediately following use.
GLASS or CERAMIC - Heats slowly and unevenly, may scratch cook-top surface if there are any rough edges, best results are when using low or medium heat settings.
CAST IRON - Heats slowly and evenly, maintains heat for slow cooking, great for browning and frying, rough on cook-top surfaces, may scratch.
STAINLESS STEEL - Heats quickly and unevenly, a base or core of aluminum or copper can provide more even heating.
DO's and DON''T's:
DO NOT store heavy items, such as jars, cans, pots and pans above the cook-top surface. Any inadvertent dropping on the cook-top surface and cause cracks or shattering.
DO NOT lay hot lids on the cook-top surface. Heated air can become trapped under the lid creating a hot spot as the rest of the cook-top surface cools. The cook-top surface could potentially crack when the lid is removed.
DO NOT slide cookware across the cook-top surface. LIFT cookware as much as possible when moving from surface to surface. This will minimize metal transfer marks and scratching.
DO NOT cook popcorn in prepackaged aluminum containers. The aluminum could potentially melt and may not be able to be removed from the cook-top surface.
DO NOT store anything on the cook-top surface that could melt (such as plastic and aluminum foil). Once melted to the surface, some of these substances may not be able to be removed.
DO NOT store empty pots and pans on the cook-top surface.
DO NOT attempt to use the cook-top surface while the oven is on a self-cleaning cycle. The oven super heats to temperatures in excess of 500 degrees and causes radiant heat to be exhausted from the oven vent on the stove surface.
DO NOT use a cook-top that is cracked. Any spill overs could potentially leak into the radiant heat elements and create an electrical hazard.
DO clean up any spills from the cook-top surface that contains milk or sugar. You may allow the cook-top surface to cool in order to safely clean, but do not allow these substances to remain on the cook-top for extended periods. If not removed, these substances can cause permanent discoloration and stains.
DO wipe down the cook-top prior to, and immediately following use, to maintain the surface appearance.
DO NOT attempt to cook any foods directly on the cook-top surface without a pan!
CLEANING and CARE:
Clean all spills and boil overs immediately.
Any substances that become adhered to cook-top surface can be removed by wiping up excess with hot soapy water and a kitchen sponge.
Use a non-abrasive pad (the green kitchen pads are considered non-abrasive) and a straight edge razor blade, pushing in one direction to remove stubborn particles.
Some metal transfer marks (copper and aluminum) may be removed by simply wiping cook-top surface with a damp sponge. Any remaining marks can often be removed with an approved cook-top cleaner.
Use only approved, non-abrasive cook top cleaner to keep the surface clean and polished.
DO NOT use scouring pads that will dull or damage cook top surface (i.e., steel wool or SOS pads).
DO NOT use any harsh chemicals such as ammonia or bleach that can etch or dull cook-top surface.
on Apr 19, 2011 | Cooktops
I need to replace the glass top on a jenn air JES8850BCS slide in range. How do I do it? Can it be done leaving the range in place or does it need to slide out for the replacement? Thanks.
It looks as if you need to remove the whole cook top to replace the glass top, incidently that is a 400 dollar item, so you have to take care. See: http://www.partselect.com/PartDetail.aspx?Inventory=2341162&SourceCode=5&ModelNum=jed8430#RepairStory
Apr 11, 2011 | Jenn-Air JED8430 Electric Cooktop
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
Was cooking fudge-hot sugary liquid boiled over onto glass cooktop. I tried to clean, but appears as if glass top has been ruined. It is rough. Tried scraping with razor, but does not help. Used cooktop...
Maybe try white vinegar - apparently you can clean glass hobs with it & it might help dissolve the fudge stuff if you pour it on that. I wouldn't use a razor as you might damage the hob more.
Dec 15, 2009 | Jenn-Air JED8430 Electric Cooktop
Roden Gas glass stovetop shattered MODEL GC73H
I have come across this occurence twice before.
With glass stove tops the glass is toughened and can generally withstand most temperatures associated with normal cooking situations. This, of course, assumes that there is sufficient space beneath the cooking utensil (saucepan, frying pan, etc) for air to circulate and the build up of heat to dissipate. If this cannot take place heat will build up to the point that the glass - a refractory material will no longer be able to withstand the internal and external forces created by the differences in internal and external temperatures and will thus shatter.
Though this is generally rare, it is known to take place and users are warned. Incidentally, this is the reason the shape of the glass top is the way it is and not the usual square as with other tops, in order for the heat to dissipate more easily.
In short, you should insist to your landlord that you were not misusing the appliance, but through genuine use this somewhat rare event occurred.
Aug 06, 2009 | Cooktops
Bosch 500 Glass Cooktop discoloration
DeBruce Polish will remove the discoloringin the cook top, also use it on pans to remove any deposits that may transfer to cook top. debrucepolish.com
Jan 04, 2009 | Cooktops
Wearing burner
no fix other than replacing the cook top with a new one
May 05, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
53 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
