Question about Vivitar MAGNACAM Binocular
Camera came with broken disk how do i get a new one?
It was cracked on the back side you cant tell from the front
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 18 Answers
Http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230370306552
you need to have the software drivers installed..buy the cd..otherwise nothing will download or upload
Posted on Aug 23, 2009
My computer won't come all way on
yep !! its done 4 ! seems it cant see the hard disk drive either by disconnection or failure of it or hard disk controller , a quick test of using someone elses hard disk drive and see if the message changes would tell you what it is
Aug 13, 2016 | Cameras
I CANT SEE MY SCREEN ON MY PHONE
What kind of phone?
It will help to put your model here.
With out the model, we are somewhat lost.
General ideas....
Make sure the battery is charged.
Go to the menu options and make sure the LCD is on, if there is an option to shut off the lcd.
The screen LCD may be broken or cracked.
One way to test for a cracked or broken screen is to put it in the sunlight with the power off. Slowly turn the phone from side to side and up and down looking at the screen. If it is broken or cracked you may see a difference in coloring of the surface under the glass or plastic cover.
If the phone works at all, and if you have a camera on it. take a picture, then down load it to your computer to view it. If the picture takes okay, then your lcd is either broken or cracked or disconnected within the phone, or some cable could be loose as well.
Anyway, hope it works.
Jul 10, 2011 | Cameras
Inserted new sandisk ultraII 2gb into camera. error message, disk locked. unlocked, still error message
Hi!
Does it work with other cards? There's a small switch on the memory card reader inside the camera which tells the camera that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Tom
Sep 27, 2009 | Canon PowerShot A540 Digital Camera
Need to remove the broken bumper on the back of a 1994 Ford Taurus, buy a new one, and put it on. help.... also need to fix a crack in the front windshield.
check out the junk yard for the bumper it will be a lot cheaper and only 4 bolts on each side of bumper. sometime if the crack isnt big you can put a dab of crazy glue on the crack to keep it from spreading but it s smarter to replace the windshield
Aug 16, 2009 | 1994 Ford Taurus
Cant get it off movie mode whats wrong
You can open the case (take the six small screws out two on the bottom and two on each side) Both the front and back will come off you may have to work it a little to get them apart. Look at the back and you will see a three position switch if it is to the far right move the switch to the center position and turn the camera on see if you are out of movie mode if you are verify that the plastic switch cover on the back of the case is not broken (it may just have been misaligned. If after moving the switch and you are still in movie mode you have a component problem and you will most likely need to send it in or buy a new camera. Hope this helped
Jul 22, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
I crushed the screen of my Canon Powershot SD450 camera. Pls. estimate cost of screen repair. Is it on the screen thats cracked cozi can still take photos but cant see them.
Many screen breaks happen to ruin the LCD from visibly displaying a picture. On some cameras, the screen is attached to the back plate of the camera and are very easy to replace with a new one. Some screens are attached to a video pc board and may ruin the board from displaying anything. Your best bet is to have it repaired professionally by one of our top repair providers and get an estimate first. I have repaired many good digital cameras with a LCD replacement, but I also had to purchase a broken used one for parts because new parts became to expensive to repair the one with a broken LCD. BTW: all digital cameras contain many PC boards and if you can still take pictures means the boards that control your lens, motors, CCD, and I/O boards are still intact and functional. Hope this helps - fotobean
Feb 20, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Samsung l200 digital camera screen broken
Actually, it's super easy to replace the screen. You'll need to order a new one (around 35$, or so). You'll also need a small screwdriver and a small pair of tweezers (actually, eyebrow removing ones will work just fine).
Before you do anything, TAKE OUT THE BATTERY.
Unscrew the screws, remove the front and back casing. Flip the broken screen out of the holder. Follow the orange conductive ribbon round to the other side of the camera, and using the tweezers, gently tug it out of the printed circuit board.
Carefully remove the broken screen.
Take the new one, thread the orange strip back through, and insert it in the PCB slot. Put the lcd screen in it's case, and then put the front and back on, and screw it together.
Watch out for them screws, their small and tricky. don't let them get away from you!
There's a number clips on youtube of someone doing this to a similar camera, but not this model.
This really isn't hard to do, so, yknow, I'd recommend it to anyone.
Dec 04, 2008 | Samsung L200 Digital Camera
Broken plastic top by power button
Remove two screws and then remove C-CASE-ASSY
Dec 10, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Sony DSC W70 Problem
You will need to describe what you see on the LCD in more detail in order for me to tell you what the problem is. There are two different issues that can cause things like what you are seeing. 1: Cracked LCD. You will see lines which resemble cracked glass. You will see bright vivid colors with specks of black or stark white all over. The image problems may be only in one portion of the screen. The LCD is made of glass, so if you look closely and see patterns that look like broken glass - this is your issue. Replace the LCD. 2: Bad LCD connection. You will see distorted colors, the screen may blank out and flicker when you shake the camera or press on the housing near the screen. If neither of these describe what you are seeing, post back and give more details and I will respond further. David Millier Advance Camera Repair
Feb 21, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Vivitar MAGNACAM Binocular Logo
103 people viewed this question
Top Vivitar Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Vivitar Optic Expert? Answer questions, earn points and help others
