Question about Pioneer DEH-1400 CD Player
Can not get power to radio
Have removed factory stero and trying to get power to a pioneer stero on a 2003 ford ranger edge truck
    President:
  • 1,990 Answers
Have you got an Aftermarket Harness to Connect to the Factory Harness that is inside the Dash for this Install????
Posted on Jan 30, 2009
How do you remove headliner on 2003 ford ranger standard cab? i need to replace roof drip guard.
I can give you some advice from the perspective of doing my Cadillac but have never done a ranger. Go around the cab and take off all of the fittings that come in contact with the head liner. Remove the dome light and you should have to remove the visors as well. Once that is all done this piece is most likely has small amounts of adhesive to hold it up. There should not be much as it is only used for placement. Careful around the edges not to break or fracture them. If you get frustrated stop and think it through. Once you get all the edges free you can drop it down and pull it out.
Feb 25, 2015 | 2003 Ford Ranger Regular Cab
What is the number 5 cylinder 2003 Ford Ranger 3.0?
They are numbered as follows:
Front passenger's side = 1
Front driver's side =4
Middle passenger's side = 2
Middle driver's side = 5
Rear passenger's side =3
Rear driver's side = 6
Aug 18, 2014 | Ford Ranger Edge/Edge Plus Model 2001-2003...
Lost power to the stereo unit and the door dingers
you original car stero could have been creating a power loop and that may be the reason, or maybe you caused a shorth while removing the old stereo, check you radio fuses, hope this helps
Nov 17, 2011 | 2003 Oldsmobile Alero
I just reassembled my truck dash after installing a new heater core and now my stero speakers do not work, there is power to the actuall stero though. what is the problem.
From what you say I would check to be sure the factory stereo speaker plugs are plugged in tightly and deeply into the radio or radio harness. If you check this and still have no sound find the speaker wires at the radio and try to put an after marker speaker on the wire. There are two wires from the radio to each speaker so be sure you get the right ones. Let me know how this goes.
Jan 17, 2010 | 1998 Ford F150 Regular Cab
Radio on 03' ranger edge does not come on
check the antenna wire in the back of radio
Jul 02, 2009 | 2003 Ford Ranger Regular Cab
Need fuse diogram for 2003 ford ranger edge, no power to green wire on towing harness
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
here you go
Apr 27, 2009 | 2003 Ford Ranger Regular Cab
03 ford ranger edge stalls with ac on only
your idle engine speed is set too low. there is a idle speed screw on your carb if it is a carb model or on your throtle body
Mar 06, 2009 | 2003 Ford Ranger Regular Cab
Stero installation
need wiring harness clip and install kit. It is pretty easy after that if you aren't installing amp or subs. what is your question, how to get factory radio out?
Aug 31, 2008 | Pioneer DEH-1600 CD Player
Pioneer DEH-1400 CD Player Logo
199 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
