Question about Lexmark X7170 All-In-One InkJet Printer
Phone line error
When I try to fax it comes back phone error. I don't know if the phone line is connected to the computer and the phone jack correctly
  • mommagiggles Feb 25, 2009
    I actually have the same problem when I try to fax. I have the phone line going directly from the phone jack to the back of the all-in-one in the LINE port, but I still get an error when trying to fax. I verfied with a phone plugged into the phone jack that there was a dial tone, but for some reason I'm unable to send faxes out. Does anyone know what I'm do wrong and why it isn't working?
    Genius:
  • 2,120 Answers
Phone line goes to the LINE port. Check for a dial-tone with a regular phone.
Posted on Jan 31, 2009
We cannot dial out when sending a fax. You can hear the line open but no dialing tone. Any ideas?
  1. Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
  2. Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
  3. Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
  4. Try sending and receiving faxes on a different fax line.
  5. Try using a different telephone cord.
  6. Have the phone company test your line for static or noise problems.
  7. Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly.
Regards
Riztech
Nov 26, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Faxing problem with HP Office Jet 7130 all-in-one
hi-
chances are you need to change the setting on you hp printer, i mean the fax settings for it and by the way have you tried reseating or unplugging the wire that connects from the wall to your hp office jet? try to unplug and replug it then try sending another fax, update me for any unusualities, thanks!!
May 20, 2008 | HP OfficeJet 7130C All-In-One InkJet...
On lexmark 7170 printer-when trying to fax-always get ''phone line error''-- connection is good from directline--phone works- Can't fax even without using pc I am using a Lexmark7170 printer with windows...
Hello. The "phone line error" usually comes up when the printer/fax is not connected properly to the fax line. Try to check behind the printer. There are two phone ports - Ext. and Line. The telephone cable should be plugged in to the Line port of the printer and the other end should go straight to the phone jack in the wall. If it is, try to use a different phone cable. Also, make sure that you assigned the correct fax number in your printer. Hope this helps.
Mar 20, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Our HP Office Jet 4255 all in one suddenly won't receive faxes for some reason. It has been working fine up until now. We can send faxes, but for some reason the phone just keeps ringing and won't...
CHECK THE TELEPHONE NO.
Verify that you are dialing the number correctly. (i know its funny to ask)
Verify that you are dialing the number correctly. You must dial all of the numbers required to make a phone call from the same line. This includes numbers that must be dialed to access an outside line or to access long distance services.
TRY DIALING FROM THE FRONT PANEL
manually dial the number from the front panel of the fax.
If you have been using a speed dial or are faxing from the computer, print the page to be faxed and manually dial the number from the front panel of the fax. If the fax can be sent when dialed from the front panel, recreate the speed dial setting and insert some pauses.
Check the connections
Check the TELEPHONE LINE
Check LIU
Remove the SPLITTER
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Jan 05, 2010 | HP OfficeJet 4255 All-In-One InkJet...
I've been trying to send fax for a couple days now. The fax is connecting, then it never connects and a sheet prints show Error 388. I've tried plugging fax into new jack and all, but it still doesn't...
This error shows that there is too much noise / interference on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Check that the phone cord is plugged in correctly on the printer and in to the telephone Jack. Also check that the phone cord is not damaged in any way. If you have other devices sharing the phone line on the premises or sharing the phone socket than disconnect them to see if this allows the fax to be sent successfully. This could also be a general problem with the phone / fax line outside of your premises and could even be at the receiving end. Try faxing a message to someone else. Then retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Oct 09, 2009 | HP Officejet 6500 Wireless All-in-One...
Error Log Result 232... The telephone connection was lost.
Error 232 Definition A communication failure occurred between the two machines. The user at the remote machine might have pressed the Stop key. The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine. The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted. Check the following items: Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol. Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product. Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines. Try sending and receiving faxes on a different fax line. Try using a different telephone cord. Have the phone company test your line for static or noise problems. Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly Solutions If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Set the host machine to receive at a slower transmission speed. Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Jun 09, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
5.Try using a different telephone cord.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Cant fax
Are you sure the FAX line is connected to a working phone jack and plugged into the correct jack (line not phone) on the machine?
Step by step FAX instructions can be found here on the HP website.
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Discription of connecting jacks at back of printer
It's the "Line" jack that you want to be using.
If there's a "Tel" or a port marked with a picture of a phone, that's for connecting a phone handset to.
Jan 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark X7170 All-In-One InkJet Printer Logo
118 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
