Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
I have a Dell GX60 and I changed the display resolution and
Now I can't see the monitor! Ive tried to start in safe mode but can't get the computer to start using F11 windows or in Dell. Is there any other way I can get back to my previous display default
  • 1 more comment
  • keith_lmn8 Jan 30, 2009
    I tried an old CRT monitor and that goes to Sleep to. I think I set the display to higher level but the graphics card can not handle the new setting
  • Thomas F. Schneider May 11, 2010
    Woops, didn't read well enough.. Reinstall  the video card software to get back to the correct resolution?.
    Have you tried another monitor to see if it ias the computer system(video card) or the monitor itself?
    Scholar:
  • 51 Answers
So, with The computer, completely turned off, Turn it on, Can't you see the BIOS screen? , or a Dell LOGO?
It is when you see this BIOS or Dell logo Screen that you Need to:
  • PRESS F8
  • Press F8
  • Press F8, again, and again right when your computer turns on.
Then You should be brought to the Window that allows you to boot into SAFE MODE, DO NoT PICK SAFE MODE.
Pick: ------------ENABLE VGA (basically safe mode) Only!.
Once booted, log in and change the resolution to let's say 800x600,
then restart your computer normally.
You should then be able run windows normally, (Without F8 Key) where you can then change the resolution to what you want.
IMPORTANT! Remember this, if you set your display to a resolution that it Does Not
support, and the screen goes blank. DO Not Turn off your computer: ALL YOU DO IS PRESS
the (Esc) ESCAPE Key within 15 Seconds and your monitor's resolution will be set to it's
previous state again.
I Hope This Helps.
Posted on Jan 30, 2009
Dell SE198WFP LCD Monitor SAYS
its LCD's main board issue you must repair or replace it
Jan 24, 2018 | Dell SE198WFP LCD Monitor
We understand that your problem is: Dell Inspiron 570 with monitor(?) issues. Start the computer, get to log in, the screen goes gray, then blue with wording and shuts down. In safe mode, many times it...
Your monitor does not support the resolution of 1900x1080. The ideal resolution for your monitor is 1024x768. To change the refresh rate(hz setting). Open display properties\If you are using Windows XP click on settings ->Advanced-> Click on monitor and click on the refresh rate drop down list and choose 60Hz
If you are using vista, Once the display properties window opens, click on the icon named "Display". Then click on Advanced settings-> Click monitor Tab(as shown in the images below)
Aug 27, 2010 | Dell Inspiron 1525 Laptop
Monitor says "Out of Range"
This normally happens when display resolution is changed to higher resolution and cannot be compatible/displayed by monitor. Either plug in another monitor and lower down resolution or Press F8 and go to advanced boot option and start your computer in safe mode and try changing display resolution. If it still doesn't works and you have the drivers for you display adapter (video card) then uninstall display adapter from device manager by booting in safe mode. Once you get to normal boot mode reinstall drivers for display adapter.
Jun 05, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Input signal out of range power management This box is all that displays?
Start the computer in SAFE mode by pressing F8 repeatedly as it boots up
What you have done is set the resolution for the monitor too high on the computer
Try lowering it to 1024 x 768 to start with.
Change the resolution once you are in to safe mode
Apr 26, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
GX520 screen display message: cannot display this video mode
This means that the windows setting you have set can not display on your current monitor. There are two ways to fix this, one is to boot the computer in safe mode by pressing f8 after the POST screen and change the resolution and the other is to plug the computer into a different monitor to see if supports that resolution and then change the resolution in windows to a lower setting.
In case you don't know how to change the resolution in windows, follow below.
Right click on the desktop
Properties
Settings at the top
Move the slider to 1024x768
Click ok
Try rebooting. If that still doesn't work, try another resolution.
Oct 19, 2009 | Dell OptiPlex GX520 PC Desktop
When i power it on it comes on then screen goes black but power boton shows its on.
You might have the resolution set too high so when it goes into Windows the monitor can't display it. Try booting into Safe Mode to change the resolution.
There is a guide on how to boot into Safe Mode here
Sep 16, 2009 | Dell E176FP 17" LCD Monitor
Out of Frequency error
1. Start Windows in safe mode by pressing F8 and Change the display properties to 800 x 600 16bit
2. Restart in normal mode
3. If the 800x600 screen resolution doesn't work try going into safe mode and trying a lower resolution
Jul 17, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor problem
It sounds as if you have a resolution set that the display does not support. Restart your machine in safe/VGA mode by holding down F8 while the machine boots. Once in safe mode, set the resolution (Right click--> properties--> Settings--> Screen Resolution) to one that your display supports.
Jun 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
180 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
