Question about Lexmark X7170 All-In-One InkJet Printer
Phone lie error
I'm not sure the phone line is hooked up right to the phone and the computer
    Problem Solver:
  • 10 Answers
Phone cord should be plugged into slot marked line on the printer
Posted on Mar 17, 2009
Wont prime up
I have seen a couple of different things cause this... Are the fuel lines hooked up and not split and fuel filter routed right in tank.(hanging freely touching bottom of tank lying flat) next if your carb has adj. screws H &L I have seen when the H is cranked snug (lean) that primer won't work right. Last but not least your Needle inlet valve is stuck shut and or the fuel pump diaphram little tabs are not sealing off chambers in carb on fuel pump side. make sure your fuel lines are properly hooked up to the right spots. when you push primer bulb it should squirt gas into the fuel tank, then when you release it ,it should draw fuel from the tank through the filter and thru the carb and then out to tank.
Nov 18, 2011 | Homelite Carburetor Trimmer Blower...
Please tell me abt samsung d600 memory card error
Your problem lies with the memory card itself most likely. I would attach the memory card to your computer through a card reader and reformat it. Make sure you chose FAT32. Once you have done that, reinsert the card into your phone.
Cheers,
aexl
Aug 25, 2011 | Samsung SGH-D600 Cellular Phone
Phone has crackling noise when speaking to people
It can be due to line available or from the service provider side or due to some loose connecting in your phone.
Check the phone line with a new phone and see everything work fine or not.If work fine,the fault lies within your phone machine get it repair to a phone mechanic. If the problem lies with your phone line,you can always called the service provider and get the line check for error.
Note : When phone tapping is done,the caller and the receiver hear cracking noise too.
Dec 21, 2009 | British Telecom Lands Phones
Uniden powermax 24 out of range
Check the line comming into the main handset base. Make sure it is not cracked or your cat hasn't chewed through it.LOL This sounds like the most likley solution. Try hooking the main phone line to an ordinary old fashioned touch tone phone with a wired handset and if that is working then the problem lies in the main base of your new phone. It could be as simple as reprogramming the base.
Jul 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
HP officejet all-in-one...keeps saying phone is off of the hook and will not give me a dial tone to fax. Is there a particular setting I need to check ?????
The very first thing to check with a fax machine is that the line itself is OK. The possibilities are much greater that there is a problem with the LINE and not the HP itself.
Hook up a regular telephone to the fax line, disconnecting anything else that may be on the line. If the telephone doesn't have a dial tone, call the phone company. If you DO have a dial tone, then maker sure that the phone line is connected to the correct port on the HP. There are two, usually. One is for the LINE and the other is for an EXTENSION (a phone that is daisy chained off the fax machine). If you have the LINE connected to the EXT port, it may give you this error.
If you have multiple items connected to the same phone line, try removing all of them but one regular phone, and see if you have a dial tone. If so, add the other items back, checking for a dial tone after each one. If one of them causes a lack of dial tone, replace or repair it.
The phone company may tell you that the problem lies in your inside wiring. I have seen that before. You can take your phone out to the telephone service box on the outside of the building. These usually have regular phone jacks in them. Disconnect the jack wire that runs into your house, and connect the regular telephone into the box itself. If you have a dial tone, then there is indeed a problem with the wiring in your building.
Jul 16, 2009 | HP Office Equipment & Supplies
I can't fax....HELP
Yes. But your fax machine must be hooked up with a standard phone line to the jack on the wall, or to a computer linked to a standard phone line. You can't simply hook the computer up to a dsl ethernet cable and hook the usb cable up to the printer and expect fax services to work.
Hp has an excellent support site for use with it's printers, available by clicking here Please take a look at this fax set up link by clicking here to make sure the fax is set up properly,and if it is and you're still having difficulty, take a look at the main site solutions section to troubleshoot your particular machine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 06, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Faxing error
Plug a regular phone into the wall outlet and listen for a dial tone.
Make sure the phone cord is plugged into the LINE port of the fax machine.
Oct 14, 2008 | Canon Office Equipment & Supplies
Off hook message
Make sure you are plugged into the LINE port and you are not sharing the phone line with a computer.
Sep 25, 2008 | HP 920 Plain Paper Fax
Lexmark 4200 all-in-one problem
I got my old printer hooked up last night. THANKS!!!!!!
Sep 10, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error code 503
All you can do yourself is have your phone/fax lines checked out by your phone company. Make sure that fax has it's own dedicated, non-digital, phone line. If you're dialing in to machines that are on digital lines or is some new piece of equipment, then there may be connection issues and there isn't much you can do about it.
Jan 10, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Lexmark X7170 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
