Question about Targus Bluetooth Laser Mouse (814227014180)
Mouse stalls in the middle of page almost seems caged in a 2" cir
Mouse will stall. I leave it for a few minutes and it will start up again. It works for a while then stalls again changed batteries does the same thing. This mouse is only 1 week old?
  • gcromp Feb 01, 2009
    I was not running more than two apps. Returned the mouse and got the same model. Hope it was just a fluke. Thanks for the reply
Are you running too many things in the back ground? If you are hooked up to the internet and have a file sharing program installed on ur pc, this can cause ever app to run slowwww!
Posted on Jan 31, 2009
Truck starts runs for a few minutes then stalls sometimes starts again sometimes wont start
Can either be fuel filter is dirty or fuel pump is going and there may be a short or burnt wire on the fuel relay. they should all be located in the same area.
Feb 29, 2016 | Cars & Trucks
My cursor is stuck in the middle of the screen. i try to move it but it doesn't work the mouse seems to be fine( i got a wireless mouse) i tried to reboot a few times still doesnt work and the keyboard is...
restart and go to SAFE MODE (press f8 until boot) check if now works fine, if yes you have a conflict between drivers, restart again press F8 and select " LAST GOD KNOWN CONFIGURATION " try again to see if work good everything if yes restart as normal and leave to boot.
please vote for my solution
Aug 13, 2010 | Computers & Internet
Dragging and stalling mouse
Are you using a rechargeable battery for your mouse? simply try to use non-rechargeable if it does
Dec 27, 2017 | Logitech Cordless Mouse
Y son-in-law purchased a wireless keyboard/mouse combination for me this weekend. The mouse seems to be very slow? Am I doing something wrong? And it seems to go to sleep when I leave it for a few...
If it is a laser mouse (light on bottom) try it on a different surface, they don't always like mousepads. They sould also be the fastest responding mouse you can get.
Aug 31, 2009 | Computers & Internet
The curser is frozen in the middle of the screen. mouse doesnt work.
check if you have the right drivers installed for the mouse that you are trying to use
May 29, 2009 | Acer Aspire One PC Notebook
Microsoft wireless mouse 4000 doesnt select tabs/icons
Normal 0 Try disconnecting the camera from the USB port and reinstall the CD software program that came with the mouse. When the program asks you to connect the camera to the USB port, do so and it should work. Hope this helps. Bud
Jan 21, 2009 | Microsoft Wireless Optical Notebook Mouse...
2002 sequioa sudden stall
Often when the battery is disconnected or replaced the computer will lose it's learned idle settings. You could try letting the engine idle in park until the engine temperature comes up to normal and leave it like that for a few minutes, then put the Air con on and let it idle again for a few minutes, then switch the air con off and put it into drive. If it does not stall, let it idle in drive for 2 minutes or so, and then do the same with the Air con on. This should relearn the base idle settings and stop it from stalling on you. Before you carry out this procedure you should make sure that when you replaced the battery you didn't remove any other plugs or knocked anything that may be causing the fault. If you try this procedure and it still stall when you select drive, you will need to get a Mechanic to check the vehicle over.
Hope this helps,
Nov 02, 2008 | 2002 Toyota Sequoia
Logitech mx518
To work around this problem, turn off the Enhance pointer precision feature: 1. Click Start, click Run, type control mouse, and then click OK. 2. Click the Pointer Options tab, click to clear the Enhance pointer precision check box, and then click OK.
Also see this article from Logitech.
The surface on which you use the mouse plays an important role in its tracking. The optical sensor must use the pattern on the surface to track the position of the cursor. Therefore, using the mouse on a glass or otherwise see-through surface will inhibit the ability of the sensor to track the cursor. Also, if you are using the mouse on a reflective surface, such as a mirror or shiny metal desk, you may experience tracking problems. In both these situations, try using the mouse on a mouse pad or piece of paper. By using the mouse on a white sheet of paper, you can also conserve battery life. Other surfaces that have been known to cause tracking problems are:
  • Some wood grains
  • Grooved surfaces
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
May 22, 2008 | Logitech MX518 931352-0403 Mouse
Inspiron B130
Well start a bit slower then.
go into the bios at startup F2, and navigate around does it freeze there. if no then
start windows in safe mode F8 when windows logo shows.
freezing ?
If its not freezing then turn off the startup programs.
Start/run/msconfig and then uncheck load startup items
and start normally, click the dont show me this again /ok
any freezing.
If its freezing you may have a hardware issue.
if you have 2 sticks of memory remove on and or /reseat them
boot the dell diagnostics cd and check the cpu and memory.
report back
Jan 30, 2008 | Dell Inspiron B130 Notebook
Targus Bluetooth Laser Mouse (814227014180) Logo
165 people viewed this question
Top Targus Computers & Internet Experts
J John
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
