Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Can't get wireless router to work
I have a Linksys WRT300N Wireless Broadband Router. I am trying to get my new wireless printer to work with my new Apple IMAC. I don't remember the password for the router. How canI get it to work?.
    Scholar:
  • 141 Answers
Call Linksys for the password. If they cannot help try this http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
Am using Linksys WRT300N v1.1 wireless router but all LEd are glowing except power led. and i am unable to connect through wired ethernet ports and also wireless is not working.
Try to reset the configuration of your router from the reset button and try that you getting the console with its default username and password.
Jun 18, 2011 | Linksys WRT300N Wireless Router
I have a linksys wrt300n router. It works fine when set to b/g only. But when set to mixed or n-only I can't get to the internet. I have an Inspiron 1721 with dell wireless-n and another inspiron with...
WRT300N router has issues with firmware. Upgrade the firmware of the router.
Download the new firmware from the web site www.linksys.com/download . save it on your computer. open the set up page of the router.
Upgrade the firmware of the router. Once you upgrade the firmware , reset the router for 30 seconds. Release the reset after 30 seconds. wait for 1 minute. unplug the power and plug it back in. wait for 1 minute.
Now you will need to reconfigure the router.
Click here for more information
Mar 29, 2010 | Linksys WRT300N Wireless Router
I just rewired all my network connections, my wrt300n wireless indicator is not lit. The network is set up on a linksys broadband router on a cable modem and wrt300n was functioning properly when it was...
Try first resetting the router by pressing the reset button of the router fro 10 seconds while power is ON and then after that reconfigure the router.....
Dec 07, 2009 | Linksys WRT300N Wireless Router
Linksys wrt300N wireless light not blinking
the wireless connections says limited or no connectivity when it does not get IP address from the router.
There might be problem with the wireless settings of the router.
if your network is a secured network then you will need to check the network key.
You can try to upgrade the firmware of the router. that will be a good option.
Click Here for step by step solution
Oct 29, 2009 | Linksys WRT300N Wireless Router
How do you connect the new PSP Go to Linksys WRT300N router?
On the PSP make sure the WLAN Switch is turned on. To connect to your router, go to System Settings > Network Settings > Infrastructure Mode then select the Network that you want to connect. If it's Linksys, select Linksys and press X. Select Scan and choose the wireless network and Enter. If it asks you for network key, type your wireless network key and connect. That should do it.
Oct 06, 2009 | Linksys WRT300N Wireless Router
WRT300N is no longer detected
Hook up your ether cable to a port other than the WAN port.
Type this into a browser...
http://192.168.1.1
Linksys WRT300N Wireless Router. ... Default IP address: 192.168.1.1
Oct 01, 2009 | Linksys WRT300N Wireless Router
WRT300N wont connect wireless
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Linksys WRT300N Wireless Router
Linksys WRT300N router issue
you have to power down all three items , turn on the computer then the modem then the route if this fails hit the reset button on the modem this shoul work for ya
Dec 25, 2008 | Linksys WRT300N Wireless Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
