Question about Car Audio & Video
Engine management light
Van cut out when under load management light come on management flicker before van can restart
    Scholar:
  • 125 Answers
This is common problem with load sensing ecu to get rid of problem make sure your running proper size wiring guages and good ground for everything electric and if your audio system is greater then 1000 watts add a power capacitor to give a buffer for loading electrical system you can purchase a capacitor and proper wiring at wholesale pricing at this address.
www.godspeedaudioheaven.com
Posted on Feb 04, 2009
The engine on my 2000 MPV cuts out and dies when I press the accelerator. After it sits for an hour or so, I can travel for 20 min. or so before the problem starts again. HELP!
if its been a while change the fuel filter and then have the fuel pressure and volume checked.these symptoms are very common for a fuel pump problem.
Feb 07, 2012 | 2000 Mazda MPV
Van won't start
a fusible link could have blown, or check the fuses under the dash or under the hood.
Jul 14, 2010 | 1985 Chevrolet Sportvan G30
Took the Van in for inspection and it failed. Had
Check all vacuum sources for a leak. I wouldn't race engine over 3000 without a load on it.
Mar 15, 2010 | Pontiac Montana Cars & Trucks
2002 express 1500 van, will not start
remove dog house locate test port and install guage should be 45-60 psi
Mar 03, 2010 | 2002 Chevrolet Express
Peugeot expert 1.9 diesel van 2005 non turbo/ engine wiring fault
If the engine management light is on you should get it plugged in to a diagnostic tool.Also check the wiring with an ohm meter .
Mar 03, 2010 | 2005 Peugeot 405
Dash lights flickered then van dies. Has new
possible crank position sensor fault .It's also likely that some of the dash gauges work intermittantly, or not at all.
Oct 09, 2009 | 1996 Plymouth Grand Voyager
Lights dimming and brightening on 2000 Chevy Venture
2000 chevy venture run good but my lights flickers and have to jump. After I jump the van and put my meeter on the battery its reading 14.volts at idle. I can drive around to store cut the van off come out it starts fine leave it overnite and it don't started.
Nov 21, 2008 | 1999 Chevrolet Venture
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
