Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire Side by Side Gallery Model Refrigerator
Tborn6,
The above frig is not sending water to the icemaker, and therefore not making ice. The outer door dispenses water just fine. Can you suggest a fix?
Thanks!
Jeff
  • 700 Answers
Yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Posted on Jan 30, 2009
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
I have a frigidaire gallery series frig side by side with ice and water in door. The frig part won't stay cold. It also seems to take long time to make ice. The frig part works ok for awhile and then...
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 17, 2009 | Frigidaire FRS23KF7AB Side by Side...
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
No ice
you can feel for water in ice maker. if not then verify inlet valve function. water inlet valve for ice maker side could be seized up
Jun 22, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery side by side not working properly for one week. Won't make ice and the freezer side feels like the refrigerator side. Refrigerator side is barely cool. I emptied the melting ice, cleaned...
You must reset the icemaker. There is an off / on button. You might have to remove the ice container. Mine is above the container at the back of an upper shelf. First, turn the switch OFF for about 30 seconds. Now, turn the switch ON, then push it tightly inward in the ON position for about 30 seconds. This will "jump start" your icemaker and you shouldn't have any more problems.
Jun 21, 2009 | Frigidaire FRS26ZSG
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by side gallery ...water leak
  • it sounds like the water valve is not closing fast enough.
  •  this will cause the ice-maker to overflow a little.
  •  your ice-maker may have an adjustment on it to control how long it keeps the water valve on.
  • it should be a screw with a + and - sing on it. it may be under the ice-maker plastic cover.
  • if it keeps doing it then you may need a new water valve.
Jun 29, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
762 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
