Question about Dryers
My dryer dont turn it will turn with only 2 or 3 pieces in it what might be wrong with it
I can only guess at this since I can't see the dryer but I had a similar problem once. The dryer drum is turned by a large rubber belt that is driven by a spring loaded pulley sort of thing .If you take the back off of the dryer you should be able to see this . The belt may be off of the pulley and not getting enough pressure on the drum or the spring may be broken. I would not recomend doing this yourself unless you feel comfortable working on this sort of thing. Disconnect power source first and then maybe reconnect after you have the back off and hands are clear so you can see what is happening. Before reconnecting power try feeling how much tension is on the belt and you may be able to determine the reason for not having enough tension. Good Luck!
Posted on Jan 30, 2009
My dryer heats up but is not drying my laundry.. What's wrong?
here is a fuw things to check first,,,, is the vents clear the dryer need to breath freely,,,is the drum turning around freely and not sticking due to belt slip,,, how dry are the cloths going ino the dryer,,,,(as the winer is here the air going in is cooler so takes more heat to warm it up) uk temp -2 degrees??? cold! how much are you putting in it? can it tumble freely,,,(no big knots in it?) try turning the heat up to full heat? and drying for longer,,,if all that fails,,,dont do any more washing??
Nov 28, 2010 | Kenmore Dryers
Dyer will turn on there is power at the source. When start is push nothing happen
Pull out the dryer and unplug . Remove the back cabinet panel , and on the blower housing , you'll see a 1" long white piece ( thermal fuse ) . The part number for this piece is 3392519 . You can jump these 2 wire together and start the dryer , to verify this is the problem .
Apr 18, 2010 | Estate EED4300SQ Dryer
How do I pop the top of the Maytag Dryer?
most dryers have 4 spring clips on the top 2 at the front l&r and 2 near the back usually in front of the console that houses your timer and controls I also use a flat bar known as a stanley wonder bar is similar to a crow bar but is perfectly flat with a curve in it.A good heavy screw driver with a long shank works well use a piece of chipboard or printer paper to avoid scratches
Dec 17, 2009 | Dryers
We have the hotpoint washer/dryer wdl540 but cannot get the dryer to work, all the clothes come out steamed! we'r not overloading the machine and have tried different combinations but still it wont dry -...
The first problem is that you, like myself, bought this piece of trash. The best way to resolve this problem is not sell it on ebay and never even think about buying Hotpoint again.
Oct 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Clothes dryer is squealing when turned on. suspect drum bearing. looking for a diagram for dismantling can i take the top off without removing the back panel( GE 5 cycle dryer)
You dont need a bearing you need the DRYER DRUM SLIDE Part number AP2041815 which is under $6.50 a piece. Take the top of the dryer off and look on the front of the drum. Some GE dryers have 2 and some have 4.Go to Appliancepartspros.com it item 316 they also have a diaphram.
Oct 10, 2009 | GE Dryers
No start
Hi thanks for your question. the most probable caues , Is the thermal fuse. Its located on the air duct at the back of the dryer.. remove the back. Look for a small plastic piece on the air duct. 2 blue wires to thi thermal fuse. replace this part. It wii fix the problem. The appliance doc
Jan 06, 2009 | Roper RGX4634KQ Gas Dryer
Roper rex5634pqo wont heat. Need diagram. dont know location of components.
i think this unit has a lint filter that pulls out the top of the unit. if so then your heating element is in the back and has 2 red wires going to it at the bottom of the element. unplug the unit and remove the element and check it to see if it is broke. the element needs to be in one piece.
if it is good, then check the thermostats that are mounted on the side of the element housing. one at the top and one right by the lower wiring. the thermostats are available in a package with both and those are most likely what is wrong.
Dec 06, 2008 | Kenmore 63942 Dryer
What does a thermal fuse look like
the fuse is a small plastic piece with only 2 wirs connected to it and it will be behind the back cover or the ones that the back dont come off, it is inside the lower panel in front ,,, check your break ,,,, it may have trip it even if it dont look or feel like it.
Larry
Nov 03, 2008 | Kenmore 62602 Electric Dryer
Timer doesn't shut down dryer machine
IT SOUNDS LIKE THE SWITCH IN THE TIMER IS BAD OR STUCK BEFORE BUYING ONE TAKE IT OUT AND TRY BUMPING IT AGAINST A PIECE OF WOULD OR SOMEHTING THEN TRY IT IF THAT DONT WORK YOULL HAVE TO BUY ONE
Feb 10, 2008 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
