Question about Canon XL1S Mini DV Digital Camcorder
No tape icon when the tape is installed
I tried to use my brother's Canon XL-1 today and it woould not play back a tape we had recorded a few weeks ago and the "no tape" icon is flashing. It won't let me watch pre-recorded tapes or recordon a blank tape. Any suggestions>?
Have you push down the cassette tray before closing the lid?
Posted on Nov 30, 2007
  • Anonymous Nov 30, 2007
    Try cpushing down the cassette tray before closing the lid
  • 515 Answers
Alot of times dirty tape heads can cause this issue. Try loading a Digital Head Cleaning Cassette into the unit, and let it clean the heads. Many times this will solve the problem. Also, make sure it's not the 'wet-type' cleaners, as this will cause damage.
For the record issue, make sure the tapes do not have the prevent erasure tabs set - this is on the bottom of the tape, and is looks like a tab that says ERASE OFF or SAVE.
Not much else that can cause this issue. Never force the tape into the unit, and never hit the unit to get it to work. If nothing works, then I would suggest taking into a service center for diagnosis.
Hope this helps some.
TWEAK A/V LAB
Posted on Nov 09, 2007
SOURCE:
My XHA1s records but won't play back any tapes unless you're in ff or rw. One of the tapes I had just loaded part of on my computer a few days ago with no issues. As far as I know no settings have been...
Sounds like the edge of the tape has been damaged. The edge of the tape has the speed encoded so the playback will know what speed to play the tape. Look at the edge of the tape for wrinkles. If present, throw away the tape so you won't use it for an important recording.
Sep 04, 2013 | Canon XH A1 Mini DV Digital Camcorder
I RECORDED OFF OF TV ON A BRAND NEW 8 HOUR VHS TAPE ABOUT A YEAR AGO AND NEVER PLAYED IT SINCE... TODAY I PUT THE TAPE IN AND THE VCR SHUTS DOWN... WHEN I TURN IT BACK ON, THE DISPLAY SHOWS "EJECT T"......
Well, it's always good to know the exact cause. Your post may help others. I deal in media issues all the time in the data processing world. Though not always the cause, it is unwise to at least examine the media when the hardware won't load it, and try others to certify the hardware functionality.
If your tape isn't actually broken why don't you try loading it and immediately fast-forwarding it past the defect? It should load fine a couple of feet into the tape. You may miss the beginning of your program but it won't be a total loss.
Nov 20, 2009 | Maxell T-160 PLUS
C:32:23
This is a common problem with alot of Sony CamCorders...The solution is simple.....GIVE IT A WHACK!!!
Seriously, Take the battery off the device, Give the camera a smart "smack" on the tape side of the unit and power it back up.
works in 90% of cases!!!
Sep 22, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Image Sensor Problem
Does the black line record on the tape? When you play back on a TV/Computer can you still see the black line. If you do that would be the image sensor.
Good luck!!
Feb 13, 2009 | JVC GR-D850 Mini DV Camcorder
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
Canon camocorder thick gray lines on ever recording
Supreemwun,
Canon support was of no help. They ****! To fix the problem this is what I figured out.
  1. Before you start filming what you want record or just advance the tape 10 secs or so.
  2. Record/ video whatever you planned.
  3. Now when the thick grey lines come up on play back don't freak out.
  4. Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
  5. Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
Jan 13, 2008 | Canon ZR100 Mini DV Digital Camcorder
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Panasonic NVDS60 "no tape error"
Clean the heads - search the Net for 'wet' versus 'dry' tapes.
Sep 19, 2007 | Panasonic NV-DS60 Mini DV Digital...
Canon xl1
I had the exact same problem; my tape icon was flashing red with a line through it and the recorder would not record, no matter how hard I begged it to. After a full day of frustration, I called the videographer who had used it previously. There is a little trick.
1. Open the exterior tape door with the "Eject" button.
2. Wait, dont touch the tape. The little metal encasement will pop over and open within a few seconds.
3. To properly put the tape in, insert tape, push the little metal door that sais "Push this first".
4. Then push the exterior door closed.
Voila! Thats all there is to it!
Sep 09, 2007 | Canon XL1S Mini DV Digital Camcorder
Canon XL1S Mini DV Digital Camcorder Logo
322 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
