Question about HP C7438A (Refurbished) DAT Tape Drive
HP C7438A, tape drive doesnt compress data - HP C7438A (Refurbished) DAT Tape Drive
    Scholar:
  • 74 Answers
Several things might cause this.
1st off is that your drive will only compress if the backup software tells it to - so ensure your software is asking the drive to compress.
There is also a dip switch on the bottom of the drive that will disable compression - i think it it switch 3 on the underside of the drive on the main pcb
Posted on Aug 24, 2009
Its capacity, speed and price?
The new HP StorageWorks LTO-5 Ultrium Tape Drives, with up to 3TB* capacity per cartridge, include HP TapeAssure which provides comprehensive information about the status, performance, utilization, and health of the tape drive and media.
s.gif » DAT Tape Drives s.gif Affordable and reliable backup for entry-level servers and workstations
dat72usb-100x70.jpg s.gif • Capacities up to 320GB of compressed data per cartridge • Proven track record for dependable backup • Remarkably low media prices contribute to a very low cost of ownership s.gif s.gif » Ultrium Tape Drives s.gif Based on LTO technology for highest capacity, performance and reliability
ultrium960-100x70.jpg s.gif • Capacities up to 3TB of compressed data per tape • Ideal for midrange and high-end servers • Investment protection through two-generation backward read compatibility and a roadmap for future generations • Choose from high-performance full-height or affordable half-height drives s.gif s.gif
Feb 28, 2011 | HP Computers & Internet
Anytime I try to backup or copy a 33GB data file on a 40GB or 72GB Data cartridge, it requests for more data cartridge even after formatting the data cartridge prior to starting the process. Sometimes, the...
Because the DAT72 can copy 72GB with 2:1 compressed, and it's native capability is 36GB in the most. So you can try to copy less than 30GB data to it or try to enable the drive's compress mode.
Nov 26, 2010 | HP StorageWorks DAT 72 Tape Drive
How to configure or enable hardware compression in DW065B LTO1 Drive. When trying to take backup in H/w compression mode the tape (100/200 GB Tape) is ejected.
The L&TT support ticket contains drive configuration information such as whether hardware data compression is enabled or not.
Use L&TT to pull the ticket then look in the Drive->Drive Configuration section for details.
Here's an example:
|__ Drive
||__ Data compression : Enabled
||__ Current block size : Not available
||__ Detect WORM tampering : WORM not supported
||__ Reads after WORM tampering : WORM not supported
||__ Media removal (software controlled) : Allowed
If data compression is not enabled then it is likely that it has been turned off by the backup application. Check the options in your application to ensure that software compression (done by the server) is turned off and hardware compression (done by the drive) is turned on.
Data compression can be turned on in the drive by
  • The application ( the application will usually override the drive configuration so configuring the application correctly is of prime importance)
  • Resetting the drive
  • Power cycling the drive
  • Using the L&TT Set Drive Configuration utility (use the options to enable compression -see the L&TT user guide below)
NetBackup usersCaution NetBackup will turn off hardware compression in the drive at the end of each backup, so when you look at it with Library and Tape Tools it will be off. This is actually normal for NetBackup, so please check the configuration of NetBackup to make sure that compression is configured correctly. In this case see 'Measure Compression Ratio' (go back one level) as that will show whether compression has been in operation in the drive.
Click here to download the free L&TT utility (www.hp.com/support/tapetools) - this will also access the L&TT user guide
Use the L&TT FAQ to find out how to pull a ticket.
Click here for the L&TT FAQ. (www.hp.com/support/lttfaq) Look for How do I generate a support ticket? in the contents.
Aug 03, 2010 | HP HEWLETT-PACKARD DW065B ULTRIUM 232...
/dev/st0: Cannot open: Input/output error
Just the fact that /dev/st0 exists indicates that the OS sees the tape drive. When you say you are "moving the data to tape drive" just how are you doing this? Have you read the dump man page?
Jan 25, 2008 | HP C7438A (Refurbished) DAT Tape Drive
Tape Drive Block Size
Bit of an odd one but i agree that block size could cause an issue.
Try this link for the HP tech manual for this drive.
http://www.tag.com/tech%20support/System%20Resources/Drivers%20&%20Utilities/Drivers/Current/7.2/HP%20DAT%20Storage%20Works/guides/unix.pdf
It may help with your issue and does detail block size changes on some systems.
Dec 06, 2007 | HP C7438A (Refurbished) DAT Tape Drive
Tape drive does not recognize or eject tape
Yeah the Ultrium 4 tape drives only r/w to ULT3 and ULT4 tapes.
We put a Ultrium 2 tape in our 4 drive and it seems to be locked permanently.
Oct 26, 2007 | HP C7438A (Refurbished) DAT Tape Drive
HP C7438A (Refurbished) DAT Tape Drive Logo
426 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
