Question about Zebra TLP 2824 Printer
Cannot print multiple labels
When i try and print multiple labels more than 3 at a time the printer will print 2 then skip one then print 3 then skip another one then stop. etc.
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the printer will calibrate the label..
if still the problem exist .check the notch in the ribbon adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
SOURCE: My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
Posted on Dec 10, 2008
SOURCE: TLP 2844 skips over labels
I've had this same problem on the TLP2844. We are using 3 x 1 labels to print shelf barcode labels, it prints a few then skips some labels then prints more. The number printed and skipped are not always the same.
What I did was recalibrate the printer. Turn the printer off. Hold Feed button and turn printer on. The printer will begin feeding labels, looking for the gaps. After the calibration is complete a configuration page will print. Press Feed after to return to normal mode.
Hope this helps.
Posted on Dec 19, 2008
  • 17 Answers
SOURCE: Calibration problems Zebra TLP 2844-Z
Your printing a 3 accross label, i think your ZPL command is wrong u must define the X and Y Coordinates of each field.
This is a sample of a ZPL command that i'd wrote. Im using a 1.5 x 1 inch. label
^XA ^PRC  ^LH0,0^FS ^LL203 ^MD0 ^MNN ^LH0,0^FS
(Design No. 1) ^BY2,3.0^FO40,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO64,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.2) ^BY2,3.0^FO344,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO368,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.3) ^BY2,3.0^FO649,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO673,136^AFN,45,13^CI0^FR^FDsample text^FS ^PQ1,0,0,N ^XZ ^FX End of job ^XA ^IDR:ID*.* ^XZ
I hope this will help you solve your problem...
Posted on Mar 20, 2009
  • 1049 Answers
SOURCE: Intermec PC4 is skipping over blank labels when it
Make sure that the label is not larger than the printable area, carriage returns and spaces count as part of the label too. Also make sure that in the printer properties you didn't set the page width wider or higher than the actual label. Especially using MS Word, you may have to adjust the label slightly smaller to compensate for margin, header, and footer settings. Also be careful of mail merges which merge data larger than the viewable area on the label.
Posted on Oct 02, 2009
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
Datamax I-4208 not printing allocated amount of labels
Eventually you HAVE to give the printer a break, during inventory times at work, we have to print 50K+ labels, and in order to prevent either serial number skipping or other issues, I print in 250 batches, yes; there is a time gap but it's better than to restart a series of prints because a few numbers were skipped. Try printing 200 and 200 sets to prevent errors or skips.
Jun 03, 2009 | Datamax I-4208 Thermal Label Printer
Mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
Feb 12, 2009 | Intermec EasyCoder PM4i Printer
try feeding just one label the 2 or 3.
if the printer feeds fine, check the format.
there is an unprintable area top and bottom of the label to reflect tolerances on the printer.
I usually like to keep the format 1/8" top and bottom spacing.
If you software, check that you do not have the printing too close to the edge.
Dec 12, 2008 | Zebra 110Xi III Plus Thermal Printer
The first thing I would do is to default the printer then run a width calibration. The instruction are in the user's manual that should have come with the printer. If the instruction did not come with the printer I can provide the instruction.
May 07, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2824 Printer Logo
80 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
