Question about Cuisinart DCC-1200 Coffee Maker
Can I adjust the water flow for finely ground coffee?
I have some ground coffee from Germany. However, the coffe grind is much finer than in the USA, so the water flows more slowly through the filter.
Problem is, the filter basket overflows, making a mess and getting coffee grounds in the coffee carafe. Is there an adjustment to slow the delivery of water while brewing? My solution is to interrupt the brewing cycle by turning the machine on and off at three-minute intervals.
I think there must be a possible adjustment. They sell this machine in Europe, don't they?
(I had the same problem with my previous coffee maker, a different brand.)
  • 1 more comment
  • Keith Meintjes Mar 11, 2009
    Thanks,
    I will get a press (or find the one we have somewhere). However, this is not a special grind coffee. It is from a regular supermarket.
    If you want to test what I mean, but a 1 lb vacuum brick of German coffee (as sold in Germany, not grown in Germany!) at an ALDI store. You will see it is ground finer than coffee usually sold in the USA. (The coffee is quite good, you won't regret the purchase.)
    A friend who lived in Germany for two years confirms this: The coffee sold there is ground finer, though the coffee makers appear to be the same. (The voltage is different.) Since my friend and I are engineers, we believe that there must be an adjustment or a replaceable part, like an orifice, to slow down the water flow.
    Keith
  • Keith Meintjes Mar 12, 2009
    That should be: ... BUY a 1 lb vacuum brick ...
    Keith
  • Anonymous Mar 29, 2014
    my single serve coffe maker does not brew.there is power to the switch but no activity.this happened after the unit over flowed with coffe grounds and i cleaned it out.this is the second machine that the exact thing happened.is it just clogged or something?
    President:
  • 2,976 Answers
You probably have coffee ground for a drip coffee pot, not an automatic drip coffee maker. With a drip coffee pot, you put the coffee in and add the hot water on top of that. You might want to try a coffee press. They are fantastic for the finer grinds of coffee. Some Mexican coffees are ground almost as fine as flour and a press works great. You can get a press for about $12 & up.
Posted on Jan 30, 2009
  • David Shaub Mar 12, 2009
    I've used the different grinds of coffee. German, Mexican, Puerto Rican, etc. and that is what made me buy a press. I also have a capuccino machine and that works great with the "Powder grind" coffees. I got my capuccino machine at a dollar store in their bargain room for $17.00. The retail is $75.00.
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
COFFEE COMES OUT TOO FAST
Try making your coffee a finer grind. The finer the grind of the beans, the slower the water will flow through the beans. Also fresher beans will make the water flow slower due to the moisture and oil content in the beans.
Jan 07, 2014 | Starbucks Saeco Italia Digital Barista...
My coffee tastes watery. It seems as though the water flowing through the filter is going too fast. My other Keurig at work brews much slower, and the coffee is delicious.
Hi, Your coffee is ground too coarse. Make the grind finer as this will slow down the flow rate. If you go too fine it will just dribble and over extract the coffee."bitter". Dazza REPAIRER
Sep 23, 2011 | Keurig B60 Coffee Maker
Coffe is too watery, and pucks are very loose
Try adjusting the grind finer. You have to do this while the grinder is running, Try 2 numbers towards fine. Then you will have to brew 2 coffees to get a reading on your adjustment.
Mar 02, 2011 | Saeco Incanto Classic Espresso Machine
My coffee filter for my Keurig, seems to overflow. Making coffee is fine with the pods, but not the filter with which you can use your own coffee... I have tried different types of grinds (ex. fine,...
I have had this same problem when all of some of the coffee is ground too fine. It needs to be the correct particle size and if it is too fine, it will clog the screen and either overflow or not flow at all. Look at the ground coffee you use and check to see if it is uniform size or there are a lot of very fine grounds mixed with the coarser sizing. Try asking a coffee shop to grind you some coffee specifically for your Keurig cassettes. Most pre-grounds drip coffees are too coarse and many grinders in the stores where you grind your own whole beans do not produce a uniform size. I have an OEM Keurig cassettee and two generic cassettes and the screens have different pore sizes, with the Keurig being finer.
Aug 24, 2017 | Keurig Elite B40 Coffee Maker
Flow through head too fast. Coffee packed very tight and ground fine
Try grinding coffee finer.
Check the shower screen to make sure that there is no damage to it, you can use an 8mm wrench or a small flat screwdriver to remove the screen.
Is the coffee fresh ground(within a few days, 2 at the most).
Jun 10, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso water flows too quickly about 7 seconds
  1. check the coffe filter>> it could be teard up and leaking(check it carefuly it is hard to see sometimes)
  2. check the pressure you get from group. 7 - 9 bar pressure you should get to handle. if it is biger than check by pas valve and adjust the pressure, also check up boiler security valve(security valve for water for coffee)
Feb 09, 2009 | Rancilio Silvia Espresso Machine
Silvia
there are two class of expresso coffée: one produce crema and the other none. A 9 sec shot, means you are putting ground coffee that are way too coarse. The Silvia requires coffee grounf extremely fine, near powder texture.
Hope this help
Dec 28, 2007 | Rancilio SILVIAespresso&cappuccino machine
Cuisinart DCC-1200 Coffee Maker Logo
735 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
