Question about Sewing Machines
Anna had this problem with her Pfaff 332 sewing machine, I do too
When bobbin case is out, I see that the inner part of where it normally snaps in, spins around, and blocks the spot where the needle is to come
cleanly down and back up with the thread from the bobbin. Is this a timing problem? Can I fix this myself? I have a Pfaff 332 sewing machine.
  • curryhill Jan 31, 2009
    Thanks Ginny, but the needle is fine, a new bobbin case for such an old machine would be difficult to find and that doesn't seem to be the problem. The upper thread gets tangled behind the bobbin receptacle somehow. The fact that the inner part of the bobbin receptacle free rotates seems to be a part of the mystery. I'll keep trying. thanks again.
  • MULLAND May 08, 2009
    I HAVE A PFAFF PERFORMANCE 2058.PURCHASED IN DEC.08. THE BOBBIN THREAD KEEPS LOOPING UP WHEN I SEW A SEAM. MULLAND@VERIZON.NET
    Problem Solver:
  • 15 Answers
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
Posted on Mar 24, 2009
  • Christopher O'Clair
    Christopher O'Clair Mar 25, 2009
    Curryhill,
    Are you up and sewing? Here's hoping so: Let me know if I can help with anything else.
    ~Christopher
    Scholar:
  • 34 Answers
Hi - it is possible that your needle is bent. Insert a new needle and check again - if you have the same problem, your timing is probably off. You could try buying a new bobbin case to see if that solves the problem. If you have had your machine tuned up within the last year or two, I would recommend a tune-up. If you know of a reputable sewing machine repair shop or dealer, the tune up should include correcting the timing and will extend the life of your machine.
Good luck,
Ginny
Posted on Jan 31, 2009
  • talk2ginny
    talk2ginny Feb 03, 2009
    Hi again - is this machine new to you, or have you had it for awhile? When the case is out, are you looking at the bobbin case, or at your machine (where you put the bobbin case when you are ready to sew)? When the bobbin case is in the machine, does the needle move down into the bobbin case, or does the needle hit the outside of case because the opening is in the wrong position? Does the bobbin case spin freely when you insert it into the machine, or does it "snap" in place and remain stationary until you begin to sew?
    If you don't have a manual for your machine, I did locate a site where you can purchase a downloadable manual for $5.00:
    http://gotoes.org/sales/PfaffSewingMachi...
    I also found a site where you can buy a bobbin case for your machine. The price is 18.00.
    http://www.singersewingsandiego.com/pfbo...
    Last but not least, I found a site that sells the service manual:
    http://www.sewingmanuals.net/pfaff-230--...
    I hope this helps. If you have more details for me, please feel free to comment before investing in manuals or a new case and I will try to give you more useful suggestions.
    If the info above isn't helpful, please feel free to rate it as such - ratings help me learn what is helpful and what is not.
    Good luck - you have a wonderful machine. When we get the bobbin problem figured out, the machine will perform well for you. BTW, I also found a site that sells the stitch wheel, which describes how to set the machine for decorative stitching. If you don't have that card - let me know and I'll list the link for that site.
  • talk2ginny
    talk2ginny Feb 07, 2009
    Hi, if thanks for taking the time to leave a rating. If I can be of more help, or if you would like me to refer to another FixYa sewing expert, please let me know and I'll be happy to do so.
    Cheers,
    Ginny
2 Suggested Answers
  • 6 Answers
SOURCE: timing my pfaff 332 sewing machine
There are two parts to the sew hook on that machine. The outer part has the hook point that grabs the thread off the needle. Then there is an inner part which has a post in the center of it that the bobbin case fits on to. The inner part should be held in place with an arm that has a bump on it. It keeps the inner part from spinning around. Sometimes this arm slips loose and a notch in the inner part of the hook assembly slips out from under the knob on the arm. If this is what is happening, you need to loosen the screw holding the arm in place and reposition the notch of the inner part of the hook back under the bump on the arm. There needs to be clearance between the notch and the bump for the thread to pass between the two. And the bump should be in line with the needle when it is in its lowest position.
If this doesn't solve the problem you need to take the machine in for repair.
Wayne
Posted on Mar 12, 2009
What size bobbin for a pfaff creative sensation
Bobbins (10pk), Pfaff #820921096: Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts > Creative 2.0
  1. Cached
  2. Similar
Product Details. Guaranteed to fit Pfaff Sewing Machine Models: Group J: creative sensation, creative sensation pro, creative performance, creative vision, ...
Pfaff - creative sensation™ pro
www.pfaff.com/en-US/Machines/creative-sensation-pro
  1. Cached
Now your PFAFF® creative sensation™ pro can embroider faster than ever ... needed to achieve perfect balance between the needle and bobbin threads.
Pfaff - Accessories
www.pfaff.com/en-US/Accessories?page=5
  1. Cached
Results 161 - 200 - Revel in a wide range of PFAFF® accessories .... blue bobbins for sewing, embroidering or experimenting with the creativeBobbin Case. bobbin for pfaff creative sensation Google Search
Dec 31, 2016 | PfaFF Sewing Machines
How do I unjam a pfaff sewing machine
If possible, try removing the bobbin & bobbin case. That will usually allow access to any thread accumulation.
Sep 26, 2016 | PfaFF Sewing Machines
How do I engage the bobbin winding gear for Pfaff 7570?
To disengage the needle while winding a bobbin do the following: the handwheel on the right end of the machine has an inner knob. hold the outer rim of the handwheel stationary as you rotate the inner knob counterclockwise. Also make sure the bobbin winding peg is pushed over to the right and the bobbin is seated on the peg.
Jul 27, 2014 | PfaFF Creative 7570
Pfaff 1221 sewing machine stuck in reverse
if you can take the pfaff back and tell them what its doing and have them fix it or get another sewing machine..
Sep 06, 2013 | PfaFF Sewing Machines
I have a Pfaff 418 and suddenly the bottom thread keeps snapping after about 5cm. I've altered the tesion & the timing and it's still happening. Any ideas??
try changing the needle
try rethreading the machine
clean under the needle plate & in the bobbin area for lint or threads
if these suggestions don't help, then the machine needs to be checked
to see what wrong with it
May 29, 2012 | PfaFF Sewing Machines
Needle plate on Pfaff 1471 - removed to clean, when I try to put it back on it keeps popping back up. Is there supposed to be a
check to make sure the bobbin is seated correctly in the bobbin case & then try the bobbin cover, it's suppose to click or snap in
Mar 30, 2012 | PfaFF Sewing Machines
Hi, I've recently acquired a Pfaff 230 s#5 150 268, need parts
HI. Sew4Less.com (http://www.sew4less.com/index.php) has parts for your Phaff 230, including belts, a bobbin case, and both service and repair manuals.
SewingManuals.com (http://www.sewingmanuals.com/index.htm) has both the user and service manuals.
Hope this helps!
Happy Sewing!
Robbie
Mar 21, 2010 | PfaFF Sewing Machines
Timing my pfaff 332 sewing machine
Wayne
Sep 16, 2008 | Sewing Machines
Frozen Sewing Machine Arm/Pfaff Tiptronic 6270
Good morning,
A question to help determine what's happening with your machine(s).
Open the bobbin case so you can see the bobbin area. Begin by trying to turn the handwheel towards you and watch as the needle attempts to go up/down. If you cannot turn the handwheel towards you, turn it slightly backwards then forwards. Does the needle hit the bobbin case as it comes down?
If yes, your machine is out of time and will require a professional technician to repair.
If the above is not the case, there may be thread jammed behind the bobbin case or wrapped around the inner parts of the take-up lever.
Either case - a Pfaff authorized technician would be your best bet for a proper repair.
Best of luck with your machines - it's just awful to not have the at the ready for all our projects!
Happy sewing,
Kim & Linnette
Jul 30, 2008 | PfaFF Tiptronic 2040
Sewing Machines Logo
1,121 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
