Question about Meiko DV 80.2 Dishwasher
Meiko dv80.2 error 201 - Meiko DV 80.2 Dishwasher
  • 170 Answers
Error code 201 Indicates the incorrect water level...in that the level was not achieved during filling...check the following.
Correct water level was not reached during initial filling.
Check that the water hose is correctly attached and is free of “kinks” or pinching. Also check that the water supply is turned on.
I hope this helps...thanks for rating my effort....the Fang
Posted on May 13, 2009
Fresh water supply insufficient (water faucet closed) Aquastop hose kinked Inlet strainer soiled Aquastop defective Boiler switch defective
Posted on Apr 06, 2011
2 Suggested Answers
  • 257 Answers
SOURCE: error 201 on the Meiko
Check that the water hose is correctly attached and is free of "kinks" or pinching. Also check that the water supply is turned on all of the way.
Posted on May 26, 2011
I have a Meiko Fv40.2 with two codes coming up, 302 and 325. Can you tell me what the codes mean.
Error 302: Drain pump output low/defective/unplugged, drain hose kinked, no signal from I/O board, wash tank level sensor malfunction.
Error 325: Tank has overfilled, drain pump active to decrease level. Allow machine to drain.
These are straight out of their tech manual.
Mar 01, 2017 | Meiko Dishwashers
Error 305 on meiko dv200.2 what does it mean?
Could be a faulty booster level / pressure switch. Do you hear the air gap cup filling in the back? Could be a faulty fill solenoid (aqua stop hose with solenoid at water inlet.)
Aug 31, 2013 | Meiko DV200.2 Door-Type Dish Machine
Meiko DV80.2 error 307
307 Wash tank level sensor defective (short circuit) Check connection, defective sensor, I/O board defective.
Per service manual.
Apr 03, 2013 | Meiko DV80.2 High Temp Door Type...
MEIKO DV 80.2 ERROR CODE 305
305 Booster content is insufficient for rinsing
See error code 301, booster tank level sensor defective/disconnected, water inlet strainer is soiled, booster tank vent is clogged, anti siphen flap.
301 Level 1 not reached when filling (number of cycles exceeded)
Booster pump output low/defective, rinse nozzles clogged, wash tank level sensor soiled, moisture in sensor tube, hose kinked or not water tight.
Mar 23, 2012 | Meiko DV 80.2 Dishwasher
Meiko dv80.2 message: info 124 we don't know what
you have opned the hood close the hood the error will disapear
Jun 13, 2011 | Meiko DV 80.2 Dishwasher
Error 201 on the Meiko 40.2 undercounter. I am thinking that it is the float switch somewhere, the sump basin is filling up just fine. anybody have this problem?
May 26, 2011 | Meiko FV 40.2 Dishwasher
What does error code 205 mean on the Meiko FV40.2
This error code means your booster heater is not getting up to the proper temperature. You can check your amp draw across your booster heating element to verify it is in fact heating and not blown. Also, check your temp sensor for resistance. At room temperature, you should read about 1000 Ohms. At 180 degrees, you will read about 1500 Ohms.
Mar 15, 2010 | Meiko FV 40.2 Dishwasher
Keep getting error 202 just replaced the booster rinse motor and the heating elements meiko dishwasher
it's inlet water not sufficient. 1)check inlet water is entering in to machine. 2)may be inlet water solenoid defective. 3)check the rinse water pump is working.
Jun 24, 2009 | Meiko FV 40.2 Dishwasher
Error 111 meiko dr80.2
it's water leakage inside the machine(or)water leakage switch defective.
Jun 20, 2009 | Meiko DV 80.2 Dishwasher
Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Mar 10, 2008 | Meiko FV 40.2 Dishwasher
Dishwashers Logo
3,488 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Trevor Turner
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
