Question about Polycom SoundPoint IP 501 IP Phone
Weird Problem with Polycom 501's
We have a few phones that having problems doing consultative transfers. When we do it, we would call the third party by hitting transfer button then tell the party we are transferring and pressing the transfer button again, sometimes it does not do anything but just sit there. Blind transfers work.
The strange this is if we unplug the phone from the Power Over Ethernet and use it's own power plug, we can do consultative transfers with no problems, well 10 transfers so far. Is this just some weird coincidence?
SIP Version 3.1.2
BootRom: 4.1.2
Thanks,
John Vo
  • jvo5 Jan 30, 2009
    Well, I just tried it and it did not work. It is not the POE.
    Any idea?
    -John
  • jvo5 Jan 30, 2009
    I noticed when Consult Transfer does not work, I get this message in my Syslog
    01-30-2009 16:45:10 69.28.217.46 Jan 30 16:45:06 69.28.217.46 0130164506|so |5|02|SoNcasSubEvCallTransfer -> SoNcasSubEvCallHold
4 Suggested Answers
corydzbinski
  • 7 Answers
SOURCE: failed to get boot parameters via DHCP
You didn't provide any information about your network which is ALWAYS required to provide any type of help, not to mention a solution.
"Failed to get boot parameters via DHCP, xxx seconds until reboot" simply means that the computer isn't getting an IP address from your router. Setting up your router is another entirely separate topic.
This is pretty simple though, one of three things is happening:
1. Your router is not properly configured to provide DHCP to the phone.
2. Your network cable is bad.
3. Your phone is bad (most likely the RJ45 port since the phone seems to work otherwise).
You can check for bad ports or cables by checking the port status within the router. If the port is lit up, most likely the cable and phone port are fine. This is not 100% though, replacing the cable should always be a consideration even with a lit port.
Posted on Jun 04, 2009
Testimonial: "thank you"
SOURCE: Making a Polycom SoundPoint 501 work on an Avaya IPO
As you have probably found, SIP phones are not supported until R5, which just came out.
Posted on Sep 27, 2009
brodie7838
  • 11 Answers
SOURCE: can ping my polycom 501 but cannot open with my
Have you tried a factory reset from the menu interface? Be careful if you do, and only choose "Format File System" as a last resort, and only if you feel comfortable enough setting up a FTP/TFTP boot server to re-provision the phone, as this option will erase everything, and then all it'll do is get stuck in a boot cycle until reprovisioned.
Posted on Feb 26, 2010
Polcom phones stop ringing
go to this website and go to customer support www.polycom.com
Jun 24, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom IP 501 won't reset to default when using MAC address as password
If your phone isn't on a constant reboot cycle and can boot up, then go into Admin Setting and do a Format File System reset. NOTE: Only try this if you know how to download the software files onto the phone via FTP server. Once you download the latest software your phone should be almost as good as new.
Sep 19, 2012 | Polycom SoundPoint IP 501 IP Phone
I have a problem regarding my Polycom Soundpoint IP331. It doesn't boot anymore. It shows only an error which is error.cfg.
You need to reinstall all the files back onto the phone. You can get the files from the Polycom Website. You can also follow the instruction from my Polycom 501 Fixya blog to see how its done.
Jun 15, 2011 | Polycom SoundPoint IP 501 IP Phone
Can ping my polycom 501 but cannot open with my
Feb 22, 2010 | Polycom SoundPoint IP 501 IP Phone
Transfering call to Polycom Soundstation 4000 on CME
What type of phone system do you have? Is the phone registering with the server?
It sounds like the phone is not registering with the server and the extension does not have voicemail. Need more details to diagnose.
Feb 26, 2009 | Polycom SoundPoint IP 501 IP Phone
Nov 11, 2008 | Polycom SoundPoint IP 501 IP Phone
Just installing polycom 501 phones with nextiva
Ohh this mean, you did not register this extension on your phone system. Create this extension on your phone system. Be sure that password given on Phonesystem is also configured on phone too.
Oct 19, 2008 | Polycom SoundPoint IP 501 IP Phone
Dead Polycom 501
u have the cable plugged in backwards
check it
Jul 25, 2008 | Polycom SoundPoint IP 501 IP Phone
I have 13 soundpoint ip 501 phones
R U USING XLITE OR ARE YOU USING ANY ASTRISK SEREVER... IT IS VERY EASY JUST GIVE ME THE INFORMATION..
Dec 05, 2007 | Polycom SOUNDPOINT IP 501 SIP
Polycom SoundPoint IP 501 IP Phone Logo
150 people viewed this question
Top Polycom Computers & Internet Experts
Michael Vincent Cruz
Joe Lane
Darren  Means
Darren Means
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
