Question about Champion Juicers
Cleaning inside the cutter
I have a 20 year old champion juicer. The cutter will no longer slide into the turn shaft. I assume this is due to a buildup of crisco. What is the best way to clean the opening down the center of the cutter?
Is it possible to use a lubricating oil in place of crisco?
    New Friend:
  • 38 Answers
  • Fill the inside hole with a degreaser solvent. WD40, mineral spirits, Goo Gone, etc. Soak for 24 hours then use a brush to scour it out. A wire battery terminal brush works good. So does a wire brush made to clean the inside of copper tubing before soldering. If you don't have a wire brush, try a plastic brush with scouring powder.
  • Polish the shaft with very fine sandpaper to remove all crud.
  • Only oil the shaft with olive oil or coconut oil. The juicing process friction causes high heat and other oils will break down and become gummy.
Posted on Jan 28, 2016
I've been using my Champion for about 20 years, and have always used a very thin coat of olive oil on the turn shaft before sliding the cutter on. I've also used it before I've used the grain mill, and it has been fine.
If I were you, I think I would get out as much Crisco as I could with a chopstick (or something similar), put in some liquid soap, and some hot water. I would think that would loosen anything that was compressed or stuck. It might take a few times, but that's what I would try....or you could order a new cutter from Champion. I've had to order parts from them in the past, and they have been great.
Hope this helps.....
Posted on Feb 05, 2009
Why is the pulp warm/hot? the screen is clean...
It is caused by friction as the cutter assembly squeezes the pulp out. The tighter the squeeze the more juice that is extracted. Be sure to oil the shaft with only olive or coconut oil as these oils will withstand the high temperature without getting gummy and making the cutter stick to the shaft..
Sep 04, 2014 | Champion Juicers
Problems dismantling champion juicer
It's like a suction is created. I have had this happen. I managed to get mine off with a blunt knife to give a bit of leverage (not ideal I know to put a knife near an expensive piece of equipment but it worked for me) Once you have the blade cutter off I suggest oiling the metal prong that it sits on with something like vegetable oil or olive fairly regularly to avoid this happening again.
Feb 23, 2014 | Champion Juicers
I cannot remove the blades from the shaft. This juicer has been in storage with all the attachments in place. I was able to pry it out about an inch or so but can't get it any further. Is it safe to use...
Do not use WD40. Wear heavy leather work gloves. Lightly tap two flathead screwdrivers positioned opposite each other to initially pry the blade apart from the main body of the juicer. Alternate tapping on the screwdrivers until some of the shaft is exposed. Tilt the juicer towards the blade and drizzle olive oil on to the exposed shaft. Every few hours return juicer to stable upright position and use a hammer to lightly tap a screwdriver positioned at an angle that will not gouge the shaft. Rotate blade manually and tap in different positions. Keep juicer tilted towards blade in between tapping attempts to allow oil to penetrate shaft opening. Continue drizzling olive oil on shaft as it is exposed. Cutter may need replacement after this procedure. Use steel wool to thoroughly clean shaft. Soak Cutter blade in hot soapy water for two days.
Sep 30, 2010 | Champion G5NG853S Household Juice...
Cutter is stuck onto shaft, how can I remove it?
First, check to see if there is a set screw in the side of the cutter which screws against the shaft.
If no set screw, a gear puller would probably do the trick. There are many types -- you might luck out and find one which will fit on your first shopping trip.
Apr 29, 2009 | Champion 2000+ Household Juice Extractor
Cleaning inside shaft of champion juicer cutter
Soak it in Hydrogen Peroxide or vinegar.
Jan 30, 2009 | Champion Juicers
Cutter
The manual that came with my juicer suggested putting a drop of cooking oil on the shaft to lubricate it before putting the cutter on. That works well for me.
Jan 06, 2008 | Champion 2000+ Household Juice Extractor
The shaft
Use steel wool to clean it, then be very diligent about putting olive oil on.
Dec 17, 2007 | Champion G5NG853S Household Juice...
Cutter
This is a response I received from Champion Juicer- I am amazed at how fast they responded. His solution is below- Hello Cathy
To remove the cutter from the Champion Juicer motor shaft, take two small
screwdrivers and place them between the back side of the cutter and the
stainless steel portion of the hub. Apply pressure on the screwdrivers and
the cutter should begin to slide forward. When driving the screwdrivers in,
make sure they are spaced far enough apart so they don't damage the motor
shaft which is located in the center of the cutter. If the cutter does not
come off, leave the screwdrivers in place and insert something under the
rear of the Champion Juicer (like a book) to elevate the rear of the
machine, thus allowing the cutter to tilt forward. Apply penetrating oil
between the screwdrivers. Because the cutter is now angles forward the oil
will run inside the cutter. If this is done for several days the cutter will
come off by applying more pressure to the screwdrivers. By merely pulling on
the screwdrivers you will have to use a plastic hammer and slowly tap on
each of the screwdrivers until the cutter breaks free. Tap one screwdriver,
and when it is snug, tap on the other screwdriver until the cutter breaks
free. When this is done there will always be one screwdriver coming loose
and falling out of the slot. Do not rush the removal process; give the oil a
chance to work. It is possible the hub and cutter will be damaged during the
removal process. Contact us for current replacement prices. Once the cutter
has been removed you should polish the motor shaft to remove any film or
burrs which may have developed. If you contact us with your address we will
mail you a piece of fine emory cloth to polish the motor shaft  at no
charge. You should always apply a slight film of olive oil on the motor
shaft to prevent sticking of the cutter. Do not use other oils, as they tend
to break down from the heat during operation of the juicer. If you wish to
speak to a repair person, please call our company weekdays @ 209-369-2154
between 8:30 a.m. and 4:30 p.m. Pacific Standard Time. We would be happy to
offer any assistance you may need.
Thank you
Carl
Aug 05, 2007 | Champion 2000+ Household Juice Extractor
Motor not working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Apr 16, 2007 | Champion G5NG853S Household Juice...
Juicers Logo
589 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
