Question about Sony Cyber-Shot DSC-T1 Digital Camera
Shutter release pressed the image captured is all white??
The camera works ok, you can view images etc but when the shutter release is pressed the image captured is all white. I'd appreciate any help
  • Anonymous Feb 16, 2009
    picture are white
  • Sony Master
  • 586 Answers
    The lens bolck assy star malfunctioning.For this you have to change the LENS BLOCK ASSY.
You can contact any sony service centre nearby to you. For your convenience please visit:
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Posted on Jan 31, 2009
When taking photos, the image is not captured when using liveview
Sure you are pressing the shutter realise button half, so the camera can focus?
Only when the middle AF-point (square in the middle) becomes green and you hear a beep, you can press the button compete to make the picture. With live view, you degrade your camera to a point and shoot. Focusing takes longer that way. Can be handy is special situations, but the focusing could be a pain, when you are used of taking pictures trough the view finder.
Nov 28, 2013 | Canon EOS 600D Rebel T3i Digital Camera
How to make a digital copy
o do this:
Press the power switch. (Capture mode)
Press the Play button. (Playback mode)
Press the four-way controller (down). (Playback mode palette)
Press the four-way controller (right) 3 times to select [Image/Sound Copy].
Press the OK button to display the screen for selecting the copy destination.
Press the OK button to copy the data.
Press the Play button or press the shutter release button down halfway to return to Capture mode.
Playback Mode Palette Copy destination selection
* This function can only be selected when an SD (SDHC) Memory Card has been inserted in the camera.
Jun 11, 2012 | Sylvania Hd1z Sdsdhcmmc 720p Hd Pocket...
LCD is almost white , no picture seen, Video section is not responding
This may be due to the LCD Screen issue or the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD image sensor issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option works only if you're able to access the menu of the Camera, otherwise power reset the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Focus problem. Coolpix 5000 mounted on Nikon microsocope for photographing tissue slides. Perfect digital images for years; now 90% poorly focused. Image viewed through microscope in perfect focus, image...
If you are initiating the shutter manually, it is quite possible that the camera has become very slightly loose at the F-mount. So, when you press the shutter button, the movement though it may be extremely slight, is shaking the camera at the exact moment you are taking the picture.
Make sure that the camera is tight to the F mount and that the F mount is secure to the microscope.
If you are initiating exposure via software, it is still possible that there is still some slight movement on your desk.
Remember, the slightest movement is magnified many, many times to the camera.
Dec 18, 2010 | Nikon Coolpix 5000 Digital Camera
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 12, 2010 | Canon PowerShot A530 Digital Camera
Can not capture image
reset the camera back to factory default using the menu. Put camera is p mode, menu, custom reset, custom reset, ok, yes,ok
Apr 06, 2009 | Olympus Evolt E510 Digital Camera
LCD monitor does not light up, and consequently, does not display any image (as some other digital cameras do) during the aiming and focusing processes - sort of prescanning the image - before the shutter...
to my knowledge digital slrs aren't supposed to show you the image on the screen before you shoot because the battery would get used up too quickly this is what the viewfinder is for and the lcd is purely there to tell you info on what the settings are and to view your pics after shooting, I have the 400d and its the same for that.Hope this helps
Sep 23, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Samsungscd23/blank viewscreen for photo memory stick
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Aug 01, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Why does it take so long to take a picture?
You may be pressing the shutter all the way down at once. This forces the camera to focus, make exposure adjustments, and capture the image all at once. By pressing the shutter button partially to focus, then the rest of the way to capture the image, your camera can process pictures more quickly. If you are taking a picture in Uncompressed Tiff mode, the camera takes longer to process the image. Tiff images create large files and can take approximately 32 seconds to process. If you are trying to capture large, high quality images that you can print, try setting the camera to HyPict mode instead of Tiff mode.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Information about a picture's settings
I use Thumber to do it. It tells me everything I want to know - shutter > speed, F stop, ISO, zoom position, date and time down to the second, > plus some other things I don't remember. Thumber was freeware when > I downloaded it.
Sep 06, 2005 | Olympus Camedia C-2000 Zoom Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
54 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
