Question about Toshiba 27DF46 27" TV
Toshiba SD-V295KU DVD/VCR Setup
Where in the instruction manual does it tell me how to program the channel number that I want to record? I've been trying now for two days. Thank you for any information. David Keene
I have a SD-V295KU DVD and cassettre recorder that will not turn on after a storm I need to know what size fuse I need to get as I have missed placed the fuse
Posted on Sep 17, 2011
    President:
  • 2,992 Answers
Hi, David.
This unit does not have a TV tuner built in. It can record only from a video/audio source such as a satellite receiver or cable box. That's why you can't find anything in the manual about programming a channel. It doesn't offer that capability.
Not the answer you were looking for, but that's what they give you. The only solution I can offer is to keep your old VCR or pick one up at a thrift shop, and use it as the signal source. Program it to come on at the desired time on the channel you want, and use its video/audio outputs as the source for your recorder. Program the recorder to start at the same time.
Kinda klunky, but it would work.
Posted on Feb 07, 2009
How Can I record a TV program using my SD-V295KU. Where Can I chose the chanel number? Can You hepl me please? This is a DVD Video Player & Video Cassette Recorder.
The SD-V295KU has no tuner. You will need to connect it to a set top tuner, a cable or satellite receiver box. One of the digital-to-analog converters would work for OTA programs from a digital station. The basic ones that were available with the government coupon give SD output; this is sufficient since composite video is limited to SD.
Then connect the composite (audio and video) out from that box to the DVD/VCR composite in (the rightmost jacks). Then set the channel on the box and record content on Line 1 (Press Input Select on the DVD/VCR's remote to get to that input after you set the recording speed.)
Most TVs do not have a composite out option so the tuner in the TV can't be used to feed the program to the DVD/VCR.
I wish that I had better news for you.
Jun 04, 2011 | Televison & Video
Need missing owner's manual; cannot find on Toshiba's site
The manual can be found here:
http://www.managemyhome.com/mmh/owner_manuals/search?query=Toshiba+SD-V295KU
Apr 26, 2009 | Toshiba SD-V295
I cannot program the vcr to record i just do not know how to I can play tapes or wath the disk but cannot recore
make sure the tv is on channel 3, and the vcr also on channel 3 -if trying to record from cable or satalite. then make sure tape is rewound all the way. do a test by hitting record on vcr. let it record for a few minutes. rewind it, then just hit play. Dont change any channels until you are ready to record the program of choice. After this test. And recording is successful. Rewind the tape again. And change the channel to your choice. Hit record at time of or go into menu of your vcr and set up a time to record shows.
Jan 04, 2009 | Symphonic WV806 DVD Player/VCR
VCR Issue with Toshiba SD-V295KU
This may be a bit late but I just ran across these posts. All these problems can be caused by bad tapes. Commercially-made tapes will usually play properly. But home recorded tapes, or very worn tapes, may not play back properly in every VCR. If the VCR isn't getting the right information off the tape for proper playback, it's muting the sound and the screen so you don't see any snow. It's also possible that the VCR heads already need a cleaning. It takes just one worn-out or defective tape to clog up the heads and cause the "no picture" problem, although in this case sound isn't usually affected.
Dec 21, 2008 | Toshiba SD-V295
Connecting VCR to TV
If you have the original remote controller, try to switch inputs. It must be on the f-connection ( coaxial) at the moment. You need to switch it to RCA or S-Video Inputs.
Aug 30, 2008 | Toshiba 27DF46 27" TV
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Turning on VCR for 2nd time recording
Have you fixed your problem?
If not, just try pressing the dvd/vcr button, so the vcr becomes the primary device. Now you can press setup and go back into the vcr menu.
Nov 11, 2007 | Toshiba SD-V394 DVD Player/VCR
Connecting to a DVD/VCR player/recorder
In the menu of the Philips dual unit,select set-up then look for channel auto-program instructions. Be sure to hook-up a tv channel signal source before beginning auto-search.Hope this helps.
Oct 03, 2007 | Mitsubishi CS-27205 TV
Toshiba 27DF46 27" TV Logo
226 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
