Question about Champion Juicers
Cleaning inside shaft of champion juicer cutter
The cutter will no longer slide onto the shaft of my older champion juicer. I'm assuming it's due to a buildup of crisco. How do I clean inside the cutter? Can I use something like a lubricating oil instead of crisco?
The serial number is A46151.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Soak it in Hydrogen Peroxide or vinegar.
Posted on Feb 07, 2009
I just ordered a replacement cutter from champion , with it came instructions that stated that the motor shaft may develop a film or burrs over time and maybe sanded down with a a piece of sine sandpaper.
Posted on Mar 29, 2009
  • boostergold Jan 03, 2011
    Something about having the best juicer just makes you want to start juicing things. Anything that can possibly go into that machines, goes. There is something therapeutic about that. That being said, it sucks when it doesn't work. Maybe try putting it in some hot hot water for a bit to loosen up the crisco. can you do that?
Why is the pulp warm/hot? the screen is clean...
It is caused by friction as the cutter assembly squeezes the pulp out. The tighter the squeeze the more juice that is extracted. Be sure to oil the shaft with only olive or coconut oil as these oils will withstand the high temperature without getting gummy and making the cutter stick to the shaft..
Sep 04, 2014 | Champion Juicers
Problems dismantling champion juicer
It's like a suction is created. I have had this happen. I managed to get mine off with a blunt knife to give a bit of leverage (not ideal I know to put a knife near an expensive piece of equipment but it worked for me) Once you have the blade cutter off I suggest oiling the metal prong that it sits on with something like vegetable oil or olive fairly regularly to avoid this happening again.
Feb 23, 2014 | Champion Juicers
Hello I dropped my juicer and the motor works but shaft won't spin
Hello !
The stainless steel shaft might have misaligned from the motor bushing due to the fall.
But, It would be risky if you tried to open the motor assembly and realign it by yourself, a service man is usually the experts on this.
You can try first to lubricate the shafting with an oil and try to rotate it and see if it moves freely.
You can also inspect if the seal from the shafting is not broken. better replace it if you found one.
The bearing also is most like to be damaged and will need to be replaced.
This link might be helpful if you want to order parts from internet
http://ecommerce.hacres.com/Champion-Juicer-Body-Hub-Oil-and-Seal-White
Nov 23, 2010 | Champion 2000+ Household Juice Extractor
I cannot remove the blades from the shaft. This juicer has been in storage with all the attachments in place. I was able to pry it out about an inch or so but can't get it any further. Is it safe to use...
Do not use WD40. Wear heavy leather work gloves. Lightly tap two flathead screwdrivers positioned opposite each other to initially pry the blade apart from the main body of the juicer. Alternate tapping on the screwdrivers until some of the shaft is exposed. Tilt the juicer towards the blade and drizzle olive oil on to the exposed shaft. Every few hours return juicer to stable upright position and use a hammer to lightly tap a screwdriver positioned at an angle that will not gouge the shaft. Rotate blade manually and tap in different positions. Keep juicer tilted towards blade in between tapping attempts to allow oil to penetrate shaft opening. Continue drizzling olive oil on shaft as it is exposed. Cutter may need replacement after this procedure. Use steel wool to thoroughly clean shaft. Soak Cutter blade in hot soapy water for two days.
Sep 30, 2010 | Champion G5NG853S Household Juice...
Cutter is stuck onto shaft, how can I remove it?
First, check to see if there is a set screw in the side of the cutter which screws against the shaft.
If no set screw, a gear puller would probably do the trick. There are many types -- you might luck out and find one which will fit on your first shopping trip.
Apr 29, 2009 | Champion 2000+ Household Juice Extractor
Cleaning inside the cutter
I've been using my Champion for about 20 years, and have always used a very thin coat of olive oil on the turn shaft before sliding the cutter on. I've also used it before I've used the grain mill, and it has been fine.
If I were you, I think I would get out as much Crisco as I could with a chopstick (or something similar), put in some liquid soap, and some hot water. I would think that would loosen anything that was compressed or stuck. It might take a few times, but that's what I would try....or you could order a new cutter from Champion. I've had to order parts from them in the past, and they have been great.
Hope this helps.....
Jan 30, 2009 | Champion Juicers
Cutter
The manual that came with my juicer suggested putting a drop of cooking oil on the shaft to lubricate it before putting the cutter on. That works well for me.
Jan 06, 2008 | Champion 2000+ Household Juice Extractor
Cutter
This is a response I received from Champion Juicer- I am amazed at how fast they responded. His solution is below- Hello Cathy
To remove the cutter from the Champion Juicer motor shaft, take two small
screwdrivers and place them between the back side of the cutter and the
stainless steel portion of the hub. Apply pressure on the screwdrivers and
the cutter should begin to slide forward. When driving the screwdrivers in,
make sure they are spaced far enough apart so they don't damage the motor
shaft which is located in the center of the cutter. If the cutter does not
come off, leave the screwdrivers in place and insert something under the
rear of the Champion Juicer (like a book) to elevate the rear of the
machine, thus allowing the cutter to tilt forward. Apply penetrating oil
between the screwdrivers. Because the cutter is now angles forward the oil
will run inside the cutter. If this is done for several days the cutter will
come off by applying more pressure to the screwdrivers. By merely pulling on
the screwdrivers you will have to use a plastic hammer and slowly tap on
each of the screwdrivers until the cutter breaks free. Tap one screwdriver,
and when it is snug, tap on the other screwdriver until the cutter breaks
free. When this is done there will always be one screwdriver coming loose
and falling out of the slot. Do not rush the removal process; give the oil a
chance to work. It is possible the hub and cutter will be damaged during the
removal process. Contact us for current replacement prices. Once the cutter
has been removed you should polish the motor shaft to remove any film or
burrs which may have developed. If you contact us with your address we will
mail you a piece of fine emory cloth to polish the motor shaft  at no
charge. You should always apply a slight film of olive oil on the motor
shaft to prevent sticking of the cutter. Do not use other oils, as they tend
to break down from the heat during operation of the juicer. If you wish to
speak to a repair person, please call our company weekdays @ 209-369-2154
between 8:30 a.m. and 4:30 p.m. Pacific Standard Time. We would be happy to
offer any assistance you may need.
Thank you
Carl
Aug 05, 2007 | Champion 2000+ Household Juice Extractor
Juicers Logo
1,361 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
