Question about Canon PIXMA MP130 All-In-One InkJet Printer
Ink absorber full on Canon MP130
Can no longer print and I called a local repair person who wants $120 - I can buy a new printer for that, plus I like this one and have a year's worth of ink.
Can't anybody do this?
I cannot believe the Canon people built this in!!
This is What MightyFalcon Wrote in 2007.
The waste Ink absorber is a small, deep sponge, located where the cartridges rest when the printer is idle. Although you can technically reset the counter on the amount of ink held in the absorber, if you overfill it, over time you will start to have color staining on your cartridges, since your carts clean up on it after every cycle, at the extreme, you can have ink residue build up under your printer. Online printer supply shops can sell you a replacement absorber cheap.
However, since I am skilled in the art of "frugal" you can also do things this way. You will need some rubber gloves, rubbing alcohol, and a small prying tool.
1) Locate the absorber at the bottom right of the cartridge path
2) With gloves on, pry up the absorber (if you have the almost full warning, be prepared for some good splatter.)
3) In a small dish with a small amount of rubbing alcohol, shake the absorber around for a short while to moisten the outer ink.
4) Rinse the absorber in a metal sink (porcelain can stain) with more alcohol, then leave it to dry.
5) Replace and make sure the absorber is seated the same as when you took it out.
Then you want to reset the counter for the absorber.
1) Enter the Service Menu by keying = Menu,Scan,Copy,Scan.
2) Use the arrows to navigate to Service Menu Counter Access. then press OK.
3) Use the arrows to navigate to ABS-M Dot Count, press Copy.
4) Use the arrows until the count is zero, press OK then Reset.
5) For good measure, turn the printer off and on.
Bada boom! like brand spankin new!
Posted on Feb 03, 2009
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
Abrosorfull
Hi there. You will basically have two options for the waste ink absorber being full. You can call canon and find a local repair center to replace the ink absorber pad or you can junk the printer and buy a new one. A person can try to dis-assemble the printer and purchase the ink absorber kit from somewhere online but you run the risk of messing up things inside the printer if you don't know what your doing.
Best of luck..
Have a Happy and Safe Holiday Season.
Dec 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Excess ink absorber tank
Have the service manual for your model, but replacing the ink absorber doesn't look easy. You might want to consider seeing a Canon repair person.
If it is possible to e-mail the service manual I will do so to you if it helps!
Apr 27, 2010 | Canon Pixma MP450 All-In-One InkJet...
Ink absorber full on canon mp460
I found this at the Canon website. Doesn't sound good - You are not alone, I have the same printer.
Solution: Ink absorber replacement options - MP460
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
  • Obtain Support by Email
  • For toll-free technical support*, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).
    * There will be a pay for support charge if your product is out of warranty (see next section, below).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support is available for Customers in Canada at 1-800-OK-CANON
If your printer is no longer under warranty :
  • For technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays). Pay for support is required on all units outside their original warranty, unless covered by a Canon Extended Service Plan. The charge will be $9.99. If it is determined that the problem you are experiencing is due to a failure of the printer's hardware, the pay for support charge will be canceled. If your out of warranty printer is determined to have a hardware problem, you have the option to purchase, at discounted pricing and free next business day shipping , a new or refurbished product from our current product line, which includes units with Canon?s new ChromaLife inks, PIXMA Technology, and a limited manufacturer?s warranty.
So we may better assist you, please make sure that you can access your Canon product and have the following information available when you call:
  • Product model name and serial number.
  • Computer's operating system; for example Windows XP.
  • Message displayed when the problem occurred.
  • Steps you've already taken to try to solve the problem.
We look forward to helping you rectify the issue you are experiencing and are always available to provide any assistance you may need.
Aug 21, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I am getting an 5800 error
Ink Absorber Replacement OptionsThis printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to release the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
the 5800 code. uplug cord from outlet. wait 1 full min, then plug in and let go through self test.
reply for more help.
have a great day and please rate bama46, thank you
Aug 17, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber canon mp130
Hi. It happens when there is some problem with the cartridges tank, either full or not seated properly. I found that Canon recommends following methods (directly from canon) to fix it.
Method 1:
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Method 2:
* Obtain Support by Email
* For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).
* Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
* Technical Support is available for Customers in Canada at 1-800-OK-CANON
* For technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays). Pay for support is required on all units outside their original warranty, unless covered by a Canon Extended Service Plan. The charge will be $9.99. If it is determined that the problem you are experiencing is due to a failure of the printer's hardware, the pay for support charge will be canceled. If your out of warranty printer is determined to have a hardware problem, you have the option to purchase, at discounted pricing and free next business day shipping , a new or refurbished product from our current product line, which includes units with Canon?s new ChromaLife inks, PIXMA Technology, and a limited manufacturer?s warranty.
Aug 01, 2009 | Canon PIXMA MP130 All-In-One InkJet...
What does ink absorber full mean on Canon Pixma 1700?
my Canon pixma keeps coming up ink absorber full cannot print
Oct 30, 2008 | Canon PIXMA iP1600 Printer
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Waste ink absorber full
i have a problem with my canon iP1880 ink absorber is full. i already change the waste pad but the problem still exist. can you help me how to reset this problem?pls email me at assuted03ph@yahoo.com
Jan 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
53 people viewed this question
old marine
old marine
