Question about Electrical Supplies
Wall Lights from outside
Now that I have fitted some wall lights to the lounge thanks to the superb advise from "justaskjoe" I now want to fix wall lights to a wall where the back of it is an outside wall.Again to save channeling cables and redecorating I intend to drill through the wall and wire up in the garage but run the cables from the garage to the outside and back to the wall lights.
Is this allowed and if it is do I need any special cable or can I use 1mm as before?
  • 1 more comment
  • restcote Jan 31, 2009
    Thanks for the advice sparky2021.
    Would it be alright to use pond pump cable. Focus do a" Mains round rubber flex 3183TRS 3 core 0.75mm sq. HAR approved H05RN-F cable"(Whatever that means)
  • restcote Feb 13, 2009
    Hi Robsfun62,
    No they are 240v,however I have since installed them using correct
    armored wire.
    Thank you for your interest.
  • Rob Bridges May 11, 2010
    are these 110v lights or low voltage lights?
    Problem Solver:
  • 18 Answers
No special cable needed 1mm will be fine
Posted on Jul 09, 2009
  • 37 Answers
Normally it is not allowable to run a regular cable (such as a Romex) where it will be exposed. Which it sounds like this cable will be run. Your best bet to make it a legal and safe install is to use a metal clad, or armored type cable (called MC, BX, or "greenfield" by some).
Posted on Jan 31, 2009
My house fuse box is fitted with a master RCD. A feed off a lounge socket goes threw the wall and feeds an external weather proof RCD box which when switched supplies my garden lights. If a garden light...
Appears the main box RCD is just as fast as the secondary RCD and it sensed the same fault that triggered the outside unit and it didn't wait around to see if that outside unit did the job.
Sep 07, 2013 | Kitchen Ranges
I bought a full sized mirror in a garage sale and really want to use it but my lounge is very small. Any advise?
You can use full size mirrors to create a very dramatic effect. As long as it's framed, you don't have to hang the mirror but can put it on the floor and rest it on the wall. It will help create the illusion of space of light throughout the small room.
Jan 10, 2013 | Home
How to connect 2 lights from wall unit to wall plug
the electrical department in Home Depot or Lowe;s have double , triple adapters for outlets. BUT You need an Electrican to rewire wall switch for a switch control of an outlet....just like in a living room when you enter from outside.. it turn your lamps on.
Dec 04, 2011 | Pioneer Audio Players & Recorders
How do i replace a pull cord with light switch
Ok so, L (line) N (Neutral) and E (Earth ground), and no idea what this rose is. I suppose you mean Junction Box when you say JB. You can use the original junction box for the wall switch connector, but the Black and white wires coming from the switch must be disconnected from power to be used, if power is already present in your light's original junction box (which is usually the case when using a pull switch light). Then you connect the white and black wires to your wall switch and use them to break the circuit at the light itself by wiring it between the light and the power lead.
Mar 24, 2010 | Plumbing
My hp printer psc 1209 suddenly stopped working. No power on lights. Nothing at all. What is the first thing to check. Pls advise. thank you.
That the plugs are all attached, to the computer, the wall etc [has the cat/dog walked passed and pulled the plug out.?]
Does another item work in the wall plug.
Have you reloaded the software.?
Nov 04, 2009 | HP PSC 1209 All-in-One InkJet Printer
How do i fit the flue to the wall?
The flue fits through the wall and fits to the vent on the outside, the vent should be screwed to the outside wall.
Feb 22, 2009 | Smeg KSED65X-1 Kitchen Hood
Need a faceplate for the timer
this is a common item. I would try a home depot or lowes first then an electrical supply house. or go on line to
Jan 05, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
Do I need an air vent through the wall for a dryer
If it is a condenser dryer, then you need no vent at all, as the steam condenses back into water, which is collected in the m/c\so you can place it anywhere.
If however it is a normal dryer, then it is advisable to have it vented.
You do not have to have it vented through a wall if you don't want to, you can hang the hose through an open window or open door,so long as the steam gets out of the dryer.
Obviously it is better if you can go through a wall, then you don't have any pipe to see, but it is not imperative that you do so..Hope this helps you..
Plz rate my suggestions .
Thanks, and a merry xmas.
Dec 20, 2008 | Dryers
New Garden Light installation
You would get power to your switch from another light switch. They would be all on the same circuit. Run more wire from another light switch to your new switch.
Sep 10, 2008 | Garden
Electrical Supplies Logo
137 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
