Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
How do I set my HCN4226W for 1080i?
I just connected my set with a DVI/HDMI cable and it's working fine but it is set on 480p and I can't find a place to change it to 1080i. Since it is in 480p, the picture is set on WIDE and everytime I try to change it I get a message of "not availbale". I think it is because it is set on 4980p. The picture is fine but in this setting it cuts off the top and bottom portion of the picture. Thanks for your help jegunz
I don't think the set will allow resizing in DVI mode, at least mine never has. I have to switch to the video input or S video to get that to work. I think there is something in the manual about that. On mine, the component input will not work if you have the DVI connected. If you have DTV, try resizing the image on the satellite receiver's remote. Sometimes, in the DVI mode, that works. I am about to pitch this set of mine out, as it now has fried something in the convergence system and won't work at all, so if the new convergence board I have ordered wont fix it, its going up on Ebay for parts !
Posted on Jan 26, 2008
Hdmi will not work only use of component cables will.
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
Dec 16, 2010 | Toshiba 30HF84 30" TV
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
DVI / HDMI problem
This problem is almost certainly on the 8300HD side of your setup. URL for the 8300HD, just in case you need it: --> Dittos for the TV, just in case: --> You're using the HDMI-to-DVI cable to connect, and I see that the manual warns on the bottom of page 11 that some DVI connected HDTVs are incompatible to the signals that are output by the HDMI interface. First thing to try - when you change the settings in the 8300HD, in the "General Settings > Audio", see if you have this problem with all of the possible selections, or if it's only with the "Dolby Digital" setting. Since the HDMI also contains the audio signal, it may be interfering with the DVI recognition in the TV. OR - See if you still have this problem when turning the TV on first, then the 8300HD. Or vice-versa. The power-on order of the two devices may make a difference. OR - With the TV on and with the 8300HD off, press the GUIDE and INFO buttons at the same time. Using the on-screen menu, verify that it is set to HD mode. Press the POWER button on the 8300HD when finished. OR - Replace the HDMI-to-DVI cable with a PrPbY/V component cable, available at Radio Shack, Best Buy and other electronics stores. One of these options should solve the problem. If not, you'll have to start sending e-mails to Sci-Atl and Samsung. Hope this helps! ;)
Jul 29, 2007 | Samsung HCN4226W 42" Rear Projection...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
Adjust the system's video output settings. Select the best output settings for the TV in use.
1. Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1
HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p
Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i
Composite / S Video *3 480i 576i
AV MULTI / SCART *4 480p / 480i 576p / 576i
*1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5. Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
6. Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
7. Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
HDMI output from AVR-4806
You say your connected from the DVD to the Denon with an HDMI cord and the Denon to the TV with an HDMI cord and you get no DVD video? can you get the Denon setup menu? if so change the res. output on the DVD to 480p, 720p or 1080i but not 1080p
Feb 15, 2009 | Denon AVR-4806 Receiver
How do i get my resolution up to 1080i?
If your cable box is not HD you wont get resolution of 1080.
Mar 21, 2008 | Televison & Video
Display resolution through dvi input HELP!
For the record I have a playstation 3 running to tx100 through hdmi to dvi adapter. It does all resolution no probs, including 720p,1080i and 1080p (which tx100 does do smoothly through dvi). My denon upscaling dvd player works fine too. In fact the tx100 looks totally awsome with PS3 games and Blu-ray.
Maybe your dvi lead is the wrong type (i think there are 2 types) or perhaps you could test with a differrent piece of DVI kit in case it's your pioneer causing probs? Hope this helps.
Jan 14, 2008 | Hitachi PJTX100 Multimedia Projector
High Def.
If you are using the component inputs it will select 1080i automatically IF that is what it is being sent. Make sure your device (cable/satellite receiver) is set to 1080i. The TV recognizes 480i, 480p(progressive scan DVD player) and 1080i. It DOES NOT recognize 720p. Since it has no HDMI or DVI input it can't do HD DVD or "upconvert" DVD but it does very nicely with 480p/progressive scan.
Dec 24, 2007 | Mitsubishi WS-65311 65" Rear Projection...
This TV won't support 1080!
Low or poor signal from the cable company. Try another signal source such as a DVD play.
May 12, 2007 | Hyundai Q320 32 in. LCD Television
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Jerry Greenberg
Jerry Greenberg
