Question about Dell 962 Photo All-In-One InkJet Printer
Can't send/receive fax
I have DSL w/ no fax/modem installed in PC. (my DSL phone line comes out of the wall>into DSL modem>out of DSL modem via eithernet cable and >into eithernet card in my PC)
Do I need fax/ modem card installed in PC? How do I configure cable hookup? Owners manual/setup instructions are vague
Thanks!!
  • bfedkenheuer Feb 12, 2009
    i set up the fax with the wizard and send fax, but it tells me that there is no connection. all physical lines are good and set up is good. why won't in connect?
    Genius:
  • 2,120 Answers
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Posted on Jan 31, 2009
HI, I CAN SEND MY FAX TO THE OPPSIT PARTY BUT I DONT RECEIVE ANY FAX, WHEN THE PARTY SEND ME, AS THE PARTY GET THE REPORT AS WE HAVE RECEIVED THE FAX,,,,,,
Please be sure that you have the fax line in the correct jack on the back. Some of the HP modems will actually send a fax if you plug the telephone cord from the wall into jack that is supposed to have a telephonep plugged into it. On the back of the 1522 there are two phone jacks, the upper one is where the cord from the wall plugs in. Also ensure that if you have DSL service that you have a filter in the line for the modem.
Mar 03, 2011 | HP LaserJet M1522nf Multifunction Printer...
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Brother all in printer, fax problem
Make sure you have a DSL Filter installed on the phone line to prevent DSL signals from interfering with the operation of the fax machine. A DSL filter looks like a line splitter or Y-Adapter and you should have received one or more of them with your DSL modem.
Jan 17, 2008 | Brother Multi-Function Center MFC-240C...
All In one Dell printer 926 can't get it to send a fax. There's no place for a phone line to be hooked into it and it tells me there's no phone line but I have dsl and the phone line for home phone and dsl...
You can find information on your product here:
http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=266274#Issue0_3
I recommend you check to make sure you have the most current drivers for your PC modem and that you also download the User Guide for your printer for the guidance on using your printer to send and receive faxes.
You need to setup your system to use the modem in your PC.
Here is how your system should be setup:
http://img144.imageshack.us/img144/6615/nonstandaloneprinterdiaab7.jpg
Note that you will need a DSL filter on the phone line to your computer.
Feb 11, 2011 | Dell Photo 926 All-in-One Printer
My lexmark S405 willnot receive faxes. It is
Assuming "cable modem" as some kind of DSL modem using your phone line for internet. Both your modem and MFU should be connected to the wall by a filter-separator, usually supplied with your DSL modem. Check its presens and proper connection. Remove any other joints or splitters
Jun 14, 2010 | Lexmark X2470 All-In-One InkJet Printer
I have a Arris Modem from time warner cable, no i
do you have dsl filter where the phone line comes out of the wall and goes into the Router.
https://en.wikipedia.org/wiki/DSL_filter
Mar 26, 2017 | 2wire (1000-000057-000) Modem
I've changed my internet providers and have gone from a cable internet svc to a dsl phone line provider. Now my computer fax machine says it is offline. Is there a setting that I need to change?
Most likely cause is you don't have a dsl filter on your fax line. Without the filter, your fax machine's modem can't discern between a dsl signal and a telephone signal Since the telephone line coming into the building is now carrying a dsl signal, a filter is necessary to receive/send faxes.
Aug 25, 2009 | Office Equipment & Supplies
I can only fax my header
Make sure that you are not running on a digital line, on a digital phone system, or using the same line as a DSL modem. This is essentially any phone that uses the same number, not just the jack in the wall. Newer modems use similar frequencies to DSL and digital phone systems even when you are running equipment to scrub the line so they are not compatible and will often interfere with one another.
Nov 29, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lost pc fax capability
The way you should set it up is use a splitter at the wall. One phone cord will go to the modem, a separate phone cord with a dsl filter on it will go to the modem on your pc. This will give your pc the capability to fax provided you have the software.
Mar 01, 2008 | Arris SURFboard SB4200 Modem
Fax config
Actually, you cannot send faxes through a DSL modem. You have to use a phone line or send it through the internet (not directly through the modem), at least from what I know...
Rgds.
Nov 08, 2007 | Computers & Internet
Dell 962 Photo All-In-One InkJet Printer Logo
113 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
