Question about Sony VPL-VW100 (Ruby) Multimedia Projector
Golf mk 4 drivers side window regulater
My golfs window dropped down the other day and from what i can tell the plastic clips that sit at the bottem of it has broken but what i need to know or see is how the cable goes back on the pullys? or what ewver thay are called from the window regulater.
  • 115 Answers
I had to buy 4 regulators. The 5th one I made a
whole new clip out of aluminum. It was pretty hard. You'll most likely have to buy a new regulator. Here are the removal instructions.
reverse to install
Posted on May 20, 2009
  • James Williams
    James Williams May 21, 2009
    As I posted in the Passat questions.
    The jetta may slightly differ.
    Yes. If your window has fallen down and will not roll up.
    99% Chance you car is suffering the Infamous VW plastic clip.
    The door panel comes off With a T-10 torx or a Hex (Allen) wrench
    that will fit and A large Philips Screw Driver..
    Remove the Plastic cover on the inside Door handle.
    And the Screw or Screw along the Bottom of the door panel.
    Then remove the screws that hold the handle the the door.
    They are located behind the Plastic plate you removed with a tiny screw driver earlier... Be careful not the mark up the cover whaytprying it up. It is best to pry from underneath. Where marks if made can not be seen
    After the screws are out 4 I believe. The Use of a CLip tool ir best.
    For getting behind the panel to pop it off. A screw driver will work.
    After all the clips are released. Pull the light at the bottom of the panel down and out. Disconnect it ur push it back thought the hole it came from..
    Now you need a 10mm socket, or wrench to remove the 12 bolts that hold the metal plate to the Door. Remove all the 10mm bolts, If the widow has not already fallen in the door. It should be released. By removing the Black 2" plugs. THe loosen the bolts that clamp the window the the arms. DO NOT LOOSEN THEM ALL the way, .
    Disconect the all the wiring.. THe Door lock cable,can be a pain.
    I think it pulls down,.
    Next remove the Metal plate. that is the regulator.
    reverse to install
Mk 4 golf, remote key not locking/unlokcikg doors?
unlock with key and hold key over for 30 secs(windows may go down)then lock with key and hold over for 30 secs(windows may go up)then press remote unlock button and hold for 30 secs,you have just reset system...the closer you have to get to the car for the remote to work the lower the battery power.sensor on top of dash(little black dimple)rarely,if at all, goes wrong.....
Jun 11, 2010 | 2003 Volkswagen Golf
Drivers electric window suddenly fell down inside of door
thw window either came off the window slider or the slider bracket, this can be determined by removing the door panel. this could also be cable driven and the cable has disconnected or broke, can also be determined by removing door panel.
Oct 01, 2009 | 2001 Volkswagen Golf
I need to replace the glass in my 2001 golf mk. 4 drivers wing mirror, how do I remove the glass.
get a screwdriver in behind the glass and gently lever the old glass out, it just clips in with a spring clip
Sep 29, 2009 | 2001 Volkswagen Golf
Mk 4 vw golf gti front door lock problems
Those components are probably part of a new lock assembly. Maybe locate a used lock to take those pieces from.
May 17, 2017 | 2001 Volkswagen GTI
How do i get the window winder off to remove the door pannle
remove outer cover with a very small screwdriver.Then unscrew.Some have clips have to use a hook made from a piece of wire and draw it up.
Jun 06, 2009 | 1995 Volkswagen Golf
Geargox for mk 4 1.8 gti
The way to find this out is simple, on the housing of the trans there is a code, a serial number, that will tell you what type of gearbox is required for this model.
Mar 02, 2009 | 2000 Volkswagen Golf
1998 Volkswagon golf window regulator
sounds like your regulator is shot. you can buy a new one from the dealer or an after market repair kit like this...29152ff.jpg as far as the route the cable takes, here is a pic. of a factory regulator. if you need more info. post back and i'll see if i can help.92b1c48.jpg`
Jan 30, 2009 | 1998 Volkswagen Golf
Passenger side window (VW Golf mark 4-1999)
Hello, I'll try guiding you through a possible remidy. Is there a round plastic dot or a cover behind the door opener/pull catch you may have to carefully prise it off to reveal a screw. the door handle has hidden screws too? usually one at the top (Possibly hidden again behind blank cover) look under the arm rest of the handle there maybe 1 or 2 hiding. Have you a rod that goes up and down when door is open or closed? if so unscrew/twist the plastic shaft that goes down behind the door card.
The card itself has push in hidden plastic clips all the way around its circumference/outside edge, these are fragile you'll need to prise the card away gently, if you break a few they're easily available eBay for pennies. Hopefully that should get you almost there but be sure to keep looking for mysterious hidden screws on the way through.
Good Luck and A Merry Christmas.
Paul 'W'
Dec 16, 2008 | 1999 Volkswagen Golf
Sony VPL-VW100 (Ruby) Multimedia Projector Logo
609 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
