Question about Panasonic Lumix DMC-FX01 Digital Camera
Opening a DMC-FX01 case
I had an issue with my LCD display going out on the camera and have since ordered a replacement part, but my problem is this I can't figure out how to open the case. I have removed all the visible screws and the bottom portion of the case opens, but seems to be stuck on or in the top portion of the case. Has anyone taken apart one of these cameras before? Is there a latch or hook or something I am missing?
There is a lock tab at the top next to power switch. Gently pry bottom of back away from body and look at crack along the top. As bottom is rotated up and out tabs should disengage. If needed a slight lift of back opposite switch should do the trick.
Posted on Aug 01, 2007
  • 883 Answers
Most electronic packages today use a combination closure of screws and tabs that interlock at mating points. It appears that you have found the latter method and are "stuck". No, I have not opened one of these, but I would try to determine where the mating tabs are located. Sometimes you can "feel" these tab locations by slight bending of the plastic body. Where it is stiffest to bend, that is usually where a tab is located. Also, sometimes mating parts use an additional "slide-locking" method where the mating parts must first slide laterally to unlock. In worst case if a tab breaks after repeated attempts, you can re-attach the tab using super glue and then (after drying) use a solder iron to make a few "spot" welds to mate the plastic tab by melting it to the shell body.
Posted on Jul 30, 2007
How do i display date on photo?
Hello
  • Press MENU/SET
  • Scroll to TRAVEL DATE
  • Press MENU/SET to turn the Travel Date on
  • Repeat to turn it off
All of these instructions can be found in your online owner's manual.
Here is a link to your owners manual in case you have any quick questions!
http://service.us.panasonic.com/OPERMANPDF/DMCFX01-MULTI.PDF
Hope this helps you!
Cheers!
Feedback is appreciated!
Dec 31, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Aug 23, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Lost Lumix simple viewer C D for Panasonic Camera DMC FX01
If you are looking for drivers in that CD, click Panasonic Support and check drivers list of DMC-FX01 at bottom of page.
and if you need Software CD, please contact nearest Panasonic service center.
May 15, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
The lcd of my Panasonic Lumix DMC-FX01 became grey when i was taking photos. There is no problem with the photos though. The camera works without any problem. The problem is that the lcd is grey and i...
pls try to reset the camera to factory settings
performa a software reset via the menu's using the settings on the 'play' setting on the dial
if it doesnt help then
u can buy screen here and get it fixed or u can fix it is a jack mechanism inside the camera no soldering work it is not that much technical inside these devices all things are with jacks and flex cables and grips so u can do it see the link below for replacement screen from ebay and u go repair it if u go to a repair shop or panasonic they will charge u 200 $ for a 200 $ camera so dont attempt it PLS RATE ME FIXYA for help and one thing more u can check the flex cable and the connector of lcd to board may be it has some condesation and re seating might help bcoz ur LCD is not damaged as u told me no impact not broken so it might be a faulty flex cable
http://cgi.ebay.com/PANASONIC-LUMIX-DMC-FX01-FX1-LCD-DISPLAY-REPLACEMENT_W0QQitemZ220371657188QQcmdZViewItemQQimsxZ20090304?IMSfp=TL090304123003r38786
pls dont forget to rate me FIXYA
Mar 20, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Broken LDC om Panasonic Lumix DMC-LX1
call Panasonic on it it should be 40 to 50 buck at the most id figure.Replacing it is the easy part remove all the case screws pull the back case off lift up the cable tabs reverse the process and your done.
Feb 02, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
I broke the lcd of the camera
There is a guy in South Carolina who has lots of used parts for all the Panasonic Cameras at reasonable prices. I bought the LCD for mine and it works like new. I think his email is gerald.ray@aa-ark.com
Nov 22, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
My pansonic lumix -fx01 digicam isnt responding ...seems sort of hung..
You can call  (044) 22352501
check this website for frequent issues with DMC FX01's
http://panasonic.jp/support/global/cs/dsc/faq/fx01/answer.html#q1
My only direct suggestion is to take the battery out for a few minutes and then replace it. Failing that, try running the camera with charger without battery installed.
Nov 14, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
96 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
