Question about Refrigerators
Location of Defrost Control timer on GE Refer
I need help locating where the Defrost control timer is located on a GE GTS22ECPBRBB refer. I had a technician diagnos the problem but he wanted way too much to fix. I have the part but can't figure out where it goes. I'm defrosting the unit now.
  • 410 Answers
I cant find an exact amtch for the model number provided. for the next closes model i can find it looks as if the all the controls are up front in the refrig section. if you will look on the underside of the control housing you will see recessed holes with retaining screws. usually there are 2 (1 on right side of housing 1 on left side). once these are removed then the console should drop down and expose the timer. in some older boxes there were more screws in the rear of the console but try the front ones first. if this doesnt sound like your refrig please recheck your model number for me and message me back. thnks peyton
Posted on Jan 30, 2009
  • peyton thompson
    peyton thompson Jan 31, 2009
    Jus t checking back with you, were you able to get your new timer installed ok? Is there any way I can help you? just let me know thx Peyton
  • 700 Answers
Look around where the thermostat is . do you see a 1/2 inch hole where there's a small button where a flat screwdriver can turn it then that's the defrost control. remove the upper panel and you should have access to the control. Good Luck
How to replace defrost timer on gts22jcp
Hi Thomas,
The timer is located in the housing with the cold control within the ceiling of the refer section. Part number you seek is WR9X565 its a white box with two ***** mounts. Once you bring down the control housing it should be directly behind the cold control in the middle. Good Luck
Mar 11, 2016 | GE Refrigeration 21.8 Cu. Ft. Top-Freezer...
Model gss25jetabb. Where can I find the defrost timer?
The defrost timer is built into the control board and is likely not the problem with a defrost problem. Item location 801 in this photo is the control board=> HERE The most likely problem on your model is the=> Defrost Thermostat WR50X10068 and the=> WR51X10059 Defrost Heater location 240 and 230 in the photo=> HERE Appliance 911
Jan 03, 2016 | GE Refrigerators
Defrost timer location on GE Gss25IFPE BB
most ge timers are located on the main control board on the back of frg.it is covered by a 4x6in plate
Apr 10, 2013 | GE Refrigerators
Compressor and fan stop working
There is a possibility that the defrost timer turned the compressor and fans off and stuck in the defrost lobe of the defrost timer. I want you to try turning the defrost timer slowly clockwise. The defrost timer is in location 257 behind the control panel inside the fresh food compartment. Here is a photo of the parts location HERE
If doing this causes the refrigerator to work again then replace the=> WR9X489 Defrost Timer
If this does not work I want you to try something else so let me know what happens Thanks
Sea Breeze
Apr 05, 2013 | GE Profile Performance 25.2 cu. ft....
Fridge stopped cooling but freezer works what could it be
Most likely the=> WR09X10041 Defrost Timer
found inside the fresh food section and behind the control panel. Click HERE for the location. Part location number 648 is the defrost timer. Location number 618 is the=> WR51X10038 Defrost Heater Assembly
If you change the defrost heater then you should also change the WR50X10071 Defrost Thermostat
and that is the location number 620 found HERE First I want you to try turning the defrost timer slowly clockwise until compressor and fans stop. Leave like this up to about 30 minutes. You should hear crackling and sizzle noise inside the freezer. If after 30 minutes the compressor and fans do not restart this will indicate the defrost timer and that part will need replaced. Try that first and let me know what happens. I will be here to answer questions if you like, Thanks Sea Breeze
Aug 15, 2012 | GE Refrigerators
I have a GE profile Fridg PSS26NSTASS where is the defrost timer located
The PSS26NSTASS does not have a defrost timer. The defrost on that model is controlled by the motherboard=> WR55X10942 Board Assembly Main Control On your model if not defrosting it will most likely be caused by the=> WR51X10055 Defrost Heater It also does not hurt to replace the=> WR50X10068 Defrost Thermostat
while inside freezer changing out the defrost heater. Click here=> PSS26NSTASS Freezer Components
In that photo location 230 is your defrost heater and location 240 is your defrost thermostat. Here is a=> PSS26 Service Manual if you don't already have Adobe Acrobat Reader Click HERE I will be here should you have any questions, Thanks Sea Breeze
Feb 16, 2012 | GE Refrigerators
Location of defrost timmer
The defrost timer on your model is inside the fresh food compartment and behind the controls. Just above the top shelf. Click Here=> FRS23W3A Control Panel
Location 23 in that photo is the timer part Number=> 215846602 Defrost Timer
Some model's have the=> 240375803 Adaptive Defrost Control
Either way should you have questions I will be here to help you. Please rate this solution, Thanks, Sea Breeze
Jun 20, 2011 | Frigidaire FRS23W3A Side by Side...
FROST BUILD UP IN FREEZER AND REFER NOT COLD ENOUGH
hello.
  • Defrost the freezer
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • If you recently adjusted the temperature control, loaded the refrigerator or are in a humid location, it is not uncommon for a refrigerator to run for 24 hours or more before getting cool.
  • Mar 15, 2009 | Refrigerators
    Defrost timer sticking
    Your model doesn't have a defrost timer. Everything is controlled by the main motherboard in the back. The ONLY way to get an acurate diagnosis is to call GE FActory Service at 1-800-432-2737. There is proprietary software and the tech will be able to plug in a laptop to your refer to find out what is going on. No other companies have this or have access to this software. By the way that deforst thermostat you think you found isn't what you think it is. It looks like one but it only a saftey device. Trust me...!
    Dec 16, 2008 | GE GSS25LGM Side by Side Refrigerator
    need to know the make and model...
    GE are in the top right back
    Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
    Aug 25, 2008 | Refrigerators
    Refrigerators Logo
    311 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
