Question about Samsung SGH-d807 Cellular Phone
Buttons on face plate dont work
The buttons on my faceplate don't work. I took the battery out to look for a reset button and now i can't get it on b/c power button is on faceplate
May not be a solution to this problem in particular but get on ebay and find a new flex cable for like 6 dollars. The flex cables in slider phones break down or come loose easily. Usually this causes your screen to turn white. In your case the buttons have stopped working. It may be another problem altogether. So try replacing it, its cheaper than buying a new phone or taking it to a shop. Hope it helps!
Posted on Feb 19, 2009
Kdc 448u has power but will not work
If you are sure that the unit has power, try resetting the unit. The reset button is on the left of the plug behind the faceplate.
Aug 19, 2012 | Kenwood Kdc448u
SRC button on faceplate doesn't work
yup. that can be a reason.
use a new one and check it.
Jul 22, 2008 | Kenwood KDC-225MR 200W Car/Marine SIRIUS...
Aiwa CDC-x204 stuck in demo mode
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Jul 24, 2012 | Car Audio & Video
How do I get my faceplate to work?buttons on faceplate don't work.
First thing is to make sure the cause. Do you have clock or any display? Is it a new installation? If so, check wiring. If failed, then the face plate itself could be bad. Call customer relations. the phone number is in the user manual.
Mar 07, 2012 | JVC Car Audio & Video
Faceplate wont work
the new face plate needs to be coded to the deck. with the face on you need to press and hold presets #1 and #3 at the same time. keep on holding and press reset continue to hold #1 and #3 until the unit is in all lighting mode. press AM button one time. p-rom ok will display. press and hold #6 and reset at the same time. continue to hold until display comes on.
Jul 18, 2010 | Kenwood eXcelon KDC-X879 CD Player
Power button dose not work
generally its cheaper to buy a whole new reciever than to buy just the face plate as they are not manufactured as seperate components.
Jun 19, 2010 | Clarion DXZ835MP RB AM/FM/CD/MP3/WMA...
My StreetPilot c330 ( 4 years old ) went dead and I can not get it to come back on. I have checked the fuse and pushed the reset button.
PULL OFF SILVER FACEPLATE AND A RESET BUTTON IS BEHIND FACE PLATE COVER PLUG UNIT UP TO POWER SOURCE PRESS RESET BUTTON AND THEN PRESS POWER BUTTON,YES BATTERY MAY BE DEAD BUT AS LONG AS YOU KEEP CONNECTED TO A POWER SOURCE IT WILL WORK.
MINE DID THE SAME THING I JUST KEEP CONNECTED TO CIG ADAPTER IN MY CAR.
Oct 25, 2009 | Garmin StreetPilot C330 GPS Receiver
360 wont turn on
The disk tray button on the unit is probably being pushed in from the outer cover. When you took it apart and put it together you may have pinched the button in. Very carefully inspect the disk tray button area. The button needs its full range of motion. The faceplate is pushing the button in and that is why it works without it. Or the face plate is making the top cover to press in on the button. Go over the area and watch what the pieces are doing when you assemble the front in regards to the tray button. I had the same problem. Remember these pieces are plastic and after being run (heat) the plastic may want to warp a little since new.
Sep 27, 2008 | Microsoft Xbox 360 Console
Error Message AO
I had the same issue, my battery was died due to headlight was ON and later player was showing AO. I am going to reset the unit and see if it will solve my problem.
Mar 09, 2008 | Pioneer DEH-1900MP CD Player
Samsung SGH-d807 Cellular Phone Logo
133 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
