Question about Microsoft Xbox 360 Console
Left Trigger o.k i've had my Xbox 360 for some time now and it still hasn't caused me any problems. But now my Left Trigger of my controller is stuck. It may not be pressed but the 360 belives that it is being pressed. How do i fix my contoller?
    President:
  • 2,961 Answers
If you undo the screws from the underside of the controller and gently part the body just enough to see the back of the button, then spray a very small amount of WD40 or any lubricating liquid around the button and press button gently in and out to lubricate it.
Posted on Jul 31, 2007
SOURCE:
My xbox 360 wired controller's right trigger is always activating without it being pressed
If the potentiometer for the trigger is bad or is not making good contact with the circuit board, say through a poor solder connection, this could be your problem. If the controller isn't getting any signal from the electronic trigger component it sees that as a pressed trigger and becomes grenade happy. This has happened to me.
Bob.
Oct 11, 2012 | Microsoft Xbox 360 Controller
My xbox 360 controller left bumper trigger wont work. I have opened it but it looks like nothing is wrong and it doesnt wiggle or move at all? please help
The contact point on the left trigger might have failed already due to wear and tear since there are moving parts, and if there are moving parts there is friction thus likely could damage the contact point of trigger whenever being pressed. The might need to be replaced in that case.
May 27, 2010 | Microsoft Xbox 360 Controller
Xbox 360 turns on by itself
Your controller has the ability to turn on the Xbox by pressing and holding the guide button. Check to make sure it is not stuck on any of your controllers. The Xbox can also pick up regular remote signals. One of your other remotes (if you have any) may be interfering with it. If your Xbox came with a media remote, make sure none of its buttons are stuck. Also, fluorescent lights (the swirly bulbs and the long, narrow bulbs) can sometimes trigger things. Another thing could be a Wii remote (if you own a Wii). There could be the rare possibility that it or the light bar is causing this problem. Sorry for the long message. I hope this helps!
Oct 18, 2009 | Microsoft Xbox 360 Console
When using the left trigger it won't select anyone. it works but I can't interact. it used to work just fine and works on new heroes. is there a waycto fix this.
if you have a habbit of pushing it many time that might be the problem so its probly broake so u should use a nother controler or get a new one
Jun 25, 2009 | Microsoft Fable 2 for Xbox 360
Xbox rockband and guitar hero sign in issues....
no you have to do the switcheroo sorry man i have to do it as too and it sux haha
Sep 29, 2008 | MTV Games Rock Band Bundle for Xbox 360
Video output on wrong setting and cant see screen
for PS3, hold the power button for at least 5 seconds or until you hear a second beep.
for Xbox 360,
Turn the console on.
Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller.
Note Make sure that you use the player 1 controller when you do this. The player 1 controller is the controller where the upper-left quadrant light is on.
As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console. So it's OK when the Xbox 360 console restarts.
Sep 05, 2008 | Video Game Consoles & Games
Broke
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
1.Remove any discs from the disc tray.
2.Turn the console off.
3.Turn the console on.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console.
Aug 09, 2008 | Microsoft Xbox 360 Console
Xbox 360 problem
Try this:
1. Remove any discs from the disc tray. 2. Turn the console off. 3. Turn the console on.
Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller. Make sure that you use the player 1 controller when you do this. The player 1 controller will have the upper-left quadrant light illuminated. 4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. 5. The Xbox Dashboard resets the display settings to the default settings, and then automatically restarts the console.
Mar 25, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
205 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
