Question about Garmin eTrex Venture HC GPS Receiver
Trackback on my garmin etrex venture hc does not work
When ever I want to use the trackback feature, all it says is that it is processing the track, and it never stops processing. It saves the tracks, but after that it is useless. All I have on the unit is the base maps, do I have to download more maps? thanks
  • 4090 Answers
SOURCE: My Garmin eTrex Summit HC will not turn on. I
absolutely! Hve yoiu checked that this model does not have a switch on the rear as well as on the front? the one of the front is standby. The other one is main power. Not 100% sure about your model so just check first. Other than that take it back to seller for replacement or instructions
Posted on Jul 01, 2009
  • 3 Answers
SOURCE: the gps keeps turning off
See "My GPS won't stay on"
http://www.fixya.com/support/t2084694-gps_stay
Posted on Sep 20, 2009
  • 3 Answers
SOURCE: I have a garmin etrex this is the 3rd one we have
  • 638 Answers
SOURCE: Hi I have a Garmin eTrex Venture and have
Did you download the maps via your PC into Mapsource and then transfer them to the Venture? You have to unlock the maps on your PC with the code which is specific to your unit.
Posted on Jan 04, 2010
SOURCE: Accuracy issue with Garmin Oregon 400t
Hi rodieeee
Did you ever find out where was the problem? I just got a 400T and indeed accuracy is horrible!
Posted on Jan 06, 2010
Handheld gps just quit.
Go to GARMIN Website and seek help there [from their techys] asap ... ok
Nov 21, 2013 | Garmin eTrex Venture HC GPS Receiver
Webupdater crashed my etrex!!! I did everything they said and it crashed. I need this fixed for my trip up north please help!!!
never use the garmin webupdater, it is unreliable. download the previous version 3.10 firmware from http://www.tramsoft.ch/gps/garmin_etrex-venture-hc-firmware-upgrades_en.html, extract to c:\garmin, plug in your gps via usb, hold the front button in the down position until update process completes, run the updater.exe program and let it complete. You will see an error message at the end of the update process, ignore and let the garmin reboot and it should work again after that.
Jul 30, 2011 | Garmin eTrex Venture HC GPS Receiver
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
Garmin Etrex Venture HC will not power up/stay on.
You are not alone it appears. Follow the link below.
Try here.http://www.fixya.com/support/t2084694-gps_stay I had the same problem as you and I followed the advise to do a "bootlock" to download new software via Garmins WebUpdater. http://www8.garmin.com/support/download_details.jsp?id=931
But please note if the unit switches off during update it may cause problems.
Or you could just return to Garmin for a replacement.
Feb 17, 2010 | Garmin eTrex Venture HC GPS Receiver
Barmin ETrex Hc won't turn on
I had the same problem as you with the unit switching off.
I found this link http://www.fixya.com/support/t2084694-gps_stay
I held down the joystick button to perform a "Bootlock"
I don't know if it will work for you.
I got Garmins WebUpdater here http://www8.garmin.com/support/download_details.jsp?id=931
Feb 01, 2010 | Garmin eTrex Venture HC GPS Receiver
How do I calibrate my compass in the eTrex Venture HC. The book says to go to the tje menue and then press calibration. My GPS does not give me this option.
I will be happy to help you with this. Unfortunnately, the Etrex Venture does not have an Electronic Compass, therefore you cannot calibrate it. What this means is that this unit will show the correct direction of travel as long as you are moving. The unit takes satellite reading every 1 seconds and compares it's location with the last location. This way it can read the direction of travel. It will not give correct readings unless you are moving.
I hope this helps.
Dec 31, 2009 | Garmin eTrex Venture HC GPS Receiver
My etrex Venture HC will not power up after changing batteries. Unit has been "on the shelf" for some time. HELP
I can only suggest that you insure that you have fresh batteries, and that they are installed properly. If you had batteries sitting in it, and they leaked, you might want to examine the contacts and make sure they are clean, and not corroded.
The Etrex are sealed and water-tight. Opening the unit will make them no longer able to resist water as well, and if there is anything wrong internally, it should be sent back for factory repair.
Nov 06, 2009 | Garmin eTrex Venture HC GPS Receiver
I can solve this by not solving it. First I tried reset the unit to default settings: hold down the power, page, and enter buttons at the same time, a message, "do you really wan to reset..." will appear. Select "yes." If the unit reboots, hurrah. If not, call tech support (1.800.800.1020). Get an RMA, send it back to them for repair. I had purchased mine over 30 days ago but less than 60: Amazon wouldn't replace it, Garmin will either replace or repair. If you want them to send a new unit while the old is in transit, just ask; they will charge and then credit a card once they have the old unit is in hand. Good luck.
Apr 25, 2009 | Garmin eTrex Venture HC GPS Receiver
Garmin eTrex Venture HC GPS Receiver Logo
500 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
