I dropped my laptop...is it the hard drive??
I dropped my laptop and some programs dont load up properly and sometimes the computer restarts. Some programs run much slower especially during start ups, shutdown,and program loadings. Sometimes Hard Disk Drive Protection pops up at the bottom right hand corner. Sometimes I hear little noises but not sure...Is it the hard drive that needs to be replaced??
Thanks
  • 86 Answers
Could be. check if the hd is properly connected. could be off due to the fall.
Posted on Jan 30, 2009
My MacBook Pro keep running never finish to load the system
If it gets stuck on the loading screen its a chance that it can be one of 3 things.
1. The Hard Drive is bad. This can happen when a sector of the hard drive is corrupted and the information contained on it was vital system files for loading the Mac OSx system.
2. The RAM. Sometimes when loading the OS, it loads into the RAM. This executes some of the short programs that can cause the system to get stuck.
3. Sometime the operating system just craps out. This will require you to enter recovery mode. Just restart your computer and hold down the R key and it should load into the recovery partition.
Apr 07, 2014 | Computers & Internet
Display dont switch on
Please connect the cable properly and restart the notebook.
Laptop Hard Drive Data Recovery
Laptop Hard Drive Data Recovery Laptop Data Recovery
Mar 05, 2014 | Compaq Mini Cq10-525dx Netbook Laptop...
Unistall windows 8 pro
You have to install another operating system
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
or
Formatting a hard drive to erase its contents does not mean the files are necessarily gone forever. Using data-recovery software, someone still could retrieve sensitive data and files from your hard drive even after you've formatted it. Instead of simply formatting your hard drive, use disc-cleaning software to permanently erase its contents. Disc-cleaning programs work by repeatedly overwriting the contents of a hard drive with random data patterns, making it virtually impossible to recover the original files. Download and install the freeware program Active@ KillDisk (see Below). http://www.killdisk.com/downloadfree.htm Click the Windows "Start" button and select KillDisk from the "All Programs" list. Click the check box next to the hard drive you want to erase in the "System Local Disks" menu. Press the "Kill" button. Select the erasing method you want to use from the "Erase Method" drop-down menu. Active@ recommends using the "US DoD 5220.22-M" method. Click "Start" to begin erasing the hard drive. Download and install the freeware program Hard Drive Eraser (see Below). http://www.harddriveeraser.org/ Click the Windows "Start" button and select Hard Drive Eraser from the "All Programs" list. Check the radio button next to the hard drive you want to erase under "Select Drive to Erase." Select the erasing method you want to use from the "Shredding Scheme" drop-down menu. The developers of Hard Drive Eraser recommend "DoD 5220-22 M" Press the "Start" button to begin erasing the hard drive. Download and install Iolo DriverScrubber (see Below). Click the "Windows" Start button, "All http://www.iolo.com/ds/3/ Programs" and then the DriverScrubber program icon. Click "Wipe all contents of a drive," and then click "3.5-Inch Floppy Disk." Insert a blank floppy disk and click "Next." Restart your computer with the floppy disk still inserted. Your computer will boot directly to DriveScrubber. Press the down arrow on your keyboard to highlight the hard drive you want to format in the "Available Physical Drives" menu. Press the space bar to select the hard drive. Press "Enter" to continue. Press the down arrow to highlight "Seven Overwrites" in the "Available Data Wiping Methods" menu, and then press the space bar to select it. Press "Enter" to continue. Press "CTRL," "ALT," "Shift" and "W" at the same time to wipe the hard drive. Hope this helps.
b>
Dec 30, 2012 | Dell Computers & Internet
Suddenly the computer and all the programs froze and it does not restart, I always a black screen with a mse telling me to reboot the computer or to insert the hard drive device to reboot... I insert the...
note yet..............the hard disk is the problem.
did you by mistake drop the laptop or someone did. It may have sloted out of place and sometimes makes it not function well. sometimes a little tap at the disk compartement side could solve a shifted disk which can be the case here or try opening the hard disk compartment with the appropiate screw drivee, remove the disk and reinsert it again and make sure it fits firmly. if you are within warranty period do return it to be atttended to by a technician or counsult a local technician for help.
good luck.
Jul 04, 2010 | ASUS N61Jq A1 Notebook
Powers up then shuts down after a couple of seconds.
Apparently you damaged an internal component.
Your BIOS program performs a POST (Power On Self Test) on each of your computer's devices before it will allow the operating system to boot up. The POST protects your computer from damage to more devices if it runs into a fatal error with one.
I suspect that your hard drive may have been damaged. Hard drive is not the first thing checked, which would account for the few seconds that the POST runs. And, hard drives are easily damaged.
SInce your POST shut down your computer so early, it's hard to tell what else might have been damaged, but I would think it would be worth replacing the hard drive and trying to boot the computer up again.
Good luck with it!!
Oct 06, 2009 | Acer Aspire 5315 Notebook
Xp won't load to hard Disk
Your RAM modules could be faulty or needs reseating. If reseating doesn't work, try swapping them around from the other laptop to see if that works.
Apr 22, 2009 | HP Pavilion dv8235nr Notebook
XP won't load onto hard drive.
Start the computer and press the f8 key as if to start in sage mode, but select the "Disable system reboot on error" (not sure of the exact wording on that). Then when the BSOD hits it will stay there so you can get the error number and message.
Alot of times these are memory errors so I would also suggest that you download a program called memtest 86. It is a small ISO file that will create a bootable cd to test the memory. You can get it from:
http://www.memtest86.com/download.html
Hope this helps
Apr 20, 2009 | HP Pavilion dv8235nr Notebook
My laptop doesnt work anymore suddenly!
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Apr 10, 2009 | Acer Aspire 4720 Notebook
How do i format the seagate 5400 160 gig hard drive?
Configuring the BIOS
After completing the drive installation, restart your computer. Your computer
may automatically detect your new drive. If your computer does not
automatically detect your new drive, follow the steps below.
1. Restart your computer. While the computer restarts, run the system
setup program (sometimes called BIOS or CMOS setup). This is usually
done by pressing a special key, such as DELETE, ESC, or F1 during
the startup process.
2. Within the system setup program, instruct the system to auto detect
your new drive.
3. Save the settings and exit the setup program.
When your computer restarts, it should recognize your new drive.
There ya go ya tubby *****.Give me a shout this weekend, Mike
Mar 29, 2009 | Seagate Momentus 5400.3 Hard Drive
SONY VAIO PCG-7G1M Wont boot
First you understand yourself is that after the windows logo screen apperars and its get restart means there is some changes or malfunction happened to your hardware - Although you changed your hard disk will not solve your problem. Please clarify as follows
1) did you load you operating system to this hard disk by any other computer help - if you load it with the same system try to reinstall the system.
If the problem existing 100% your motherboard is partially damage I think the uniprocessor side voltage variation is happening while you press keyboard some charge (voltage) you are supplying to the motherboard, sometimes some key pulse is more than 5 volt so that pulse support to get moved some points
First check your windows try to reinstall agian - I predict that you got this hard disk installed through some other laptop so the hardware configuration is different.
Thanks Hothawk
Jul 17, 2008 | Computers & Internet
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
